[mapguide-users] 3D data (or something similar) in mapguide
Zeeshan mshailze at yahoo.com
Fri Sep 22 00:51:51 EDT 2006
NO , I know to expect 3d render or something like rotation on axis is too
early, and this stage i do not required real time interaction.  Even if i
get to show shaded view which LOOKS like a 3D that would be great.  (Rasters
load very slow ) so i thought of DEm or TIN
About the Monitoring Stations points - They are point features , plotted
using  Map 3D and stored as a sdf in the mapguide repository. (here is one
more thing, Can i convert this shp data to Oracle spatial, i have  Map3d
2006)
Thanks a lot
Zeeshan wrote:
> I had posted this message before but i guess replied and followed a wrong
> thread.
> HI
>  I have a different dataset .
>   It is about mountain elevations and a whole lot of stations which
> monitor soil sediment and other factors
>  Though i can get all these stations as points on mapguide , the real
> thing we would like to see is surface- if we can put either DEM or TIN
> Data.
>   we want to show surface elevation / surface layer in mapguide
>  yes Contour lines can be put as a layer , but those are flat and do not
> give the real object feel
>   While raster seemed to be the only option,  it really does not suit our
> application were the dataset keeps changing.  Morever Rasters would be
> slow..anyday
>  Is there any way of showing DEM or TIN data ? or anything close
>  Too much for asking .... but  really worth thinkng of !
> Thanks
View this message in context: http://www.nabble.com/3D-data-%28or-something-similar%29-in-mapguide-tf2309838.html#a6441062
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
More information about the Mapguide_users mailing list
