[mapguide-users] POOL:DWF or AJAX
Axel Gross axel.gross at iaeste.at
Tue Sep 26 09:48:46 EDT 2006
actually there are two big ones: subclipse (tigris.org) and subversive....
hth,
axel
On 2006-09-26 at 12:47:35 +0200, Kenneth, GEOGRAF A/S wrote:
> SVN and CVS are both version control system, but they do not interoperate.
> So, no you can't use eclipse cvs for the checkout.
> Maybe there is an SVN plugin for eclipse?
> Regards, Kenneth
> Tony Feng skrev:
> >Hi,
> >Can eclipse cvs check out the source code?
> >I wanna use the eclipse like the p4 client.
> >Best Regards:
> >Tony
> >*From:* Trevor Wekel [mailto:trevor.wekel at autodesk.com]
> >*Sent:* Tuesday, September 19, 2006 11:41 PM
> >*To:* Jason Birch; users at mapguide.osgeo.org
> >*Su**bject:* RE: [mapguide-users] POOL:DWF or AJAX
> >Hi Jason,
> >Check to see if MgCoordinateSystem.dll and proj.dll are in the server
> >bin directory.  It may also be worthwhile to see if the PROJ_LIB
> >environment variable is set.  I have seen strange behaviour like this
> >if the coordinate system libraries are not loaded and initialized
> >correctly.
> >Thanks,
> >Trevor
> >*From:* Jason Birch [mailto:Jason.Birch at nanaimo.ca]
> >*Sent:* Friday, September 15, 2006 3:53 PM
> >*To:* users at mapguide.osgeo.org
> >The version that I have currently does not appear to be stable.  This
> >command:
> >http://myserver/mapguide/mapagent/mapagent.fcgi?OPERATION=GETMAPIMAGE&VERSION=1.0.0LOCALE=en&MAPDEFINITION=Library%3A%2F%2FSamples%2FSheboygan%2FMaps%2FSheboygan.MapDefinition&FORMAT=PNG&SETDISPLAYDPI=96&SETDISPLAYWIDTH=512&SETDISPLAYHEIGHT=396
> ><http://myserver/mapguide/mapagent/mapagent.fcgi?OPERATION=GETMAPIMAGE&VERSION=1.0.0LOCALE=en&MAPDEFINITION=Library%3A%2F%2FSamples%2FSheboygan%2FMaps%2FSheboygan.MapDefinition&FORMAT=PNG&SETDISPLAYDPI=96&SETDISPLAYWIDTH=512&SETDISPLAYHEIGHT=396>
> >is crashing with:
> >An unclassified exception occurred. Exception occurred in method
> >MgServerRenderingService.RenderMap at line 449 in file
> >d:\osgeo\mgbuild\server\src\services\rendering\ServerRenderingService.cpp
> >Unfortunately, I don't know if this is because of the way that I'm
> >compiling/installing the application, or if it's an intrinsic bug.
> >Jason
> >*From:* Ivan Milic(evic' [mailto:ivan at ineo.hr]
> >*Sent:* Friday, September 15, 2006 09:51
> >Oh my... I'll have to wait to get home (i'm downloading from train).
> >That's too much.
> >Can you put somewhere buildered instalation's? Please. I promise, when
> >I get home (2-3 days) I will complete build "matrix-alien" procedure
> >and every 20 days compiling new verions for other people.
> >I'm sure that many would like to have new verion's od FDO and Mgserver.
> >If you want, i can send you a usrname and password for ftp onmy server.
> >Thanx a lot Jason.
> >*Sent:* 15. rujan 2006 18:45
> >No, you don't need all of the providers, just SDF and
> >GenericRDBMS.  The build process skips missing providers.
> >My svn directory (including all the SVN overhead) is:
> >Size on Disk (yes, I have large clusters):  2.77 GB
> >Files:  123372
> >Folders:  19307
> >The build directory (after building) is:
> >Size on Disk: 3.02 GB
> >Files:  27719
> >Folders:  2006
> >I should note that I don't the export SDE provider to my build
> >directory because I don't have the SDK.
> >It looks like if you only download the SDF and RDBMS providers you'll
> >save about 665 Mb on the download.
> >*Sent:* Friday, September 15, 2006 09:31
> >Oh... what a mess....
> >I must download everything? I just need odbc driver.. And sdf.
> >Huh.. What is size of your osgeofdodev directory?
> >*Sent:* 15. rujan 2006 18:21
> >You may need to explicitly check it out.  The FDO checkout process
> >(look at the svncheckout.bat file in the root) is somewhat convoluted.
> >svn checkout https://fdocore.osgeo.org/svn/fdocore/trunk -N
> >"D:OSGeoFDODev" --username YourOSGeoUsername --password YourOSGeoPwd
> >svn checkout https://fdocore.osgeo.org/svn/fdocore/trunk/Utilities
> >"D:OSGeoFDODev\Utilities" --username YourOSGeoUsername --password
> >YourOSGeoPwd
> >svn checkout https://fdocore.osgeo.org/svn/fdocore/trunk/Thirdparty
> >"D:OSGeoFDODev\Thirdparty" --username YourOSGeoUsername --password
> >YourOSGeoPwd
> >svn checkout https://fdocore.osgeo.org/svn/fdocore/trunk/Fdo
> >"D:OSGeoFDODev\Fdo" --username YourOSGeoUsername --password YourOSGeoPwd
> >svn checkout https://fdoshp.osgeo.org/svn/fdoshp/trunk/Providers/SHP
> >"D:OSGeoFDODev\Providers\SHP" --username YourOSGeoUsername --password
> >YourOSGeoPwd
> >svn checkout https://fdosdf.osgeo.org/svn/fdosdf/trunk/Providers/SDF
> >"D:OSGeoFDODev\Providers\SDF" --username YourOSGeoUsername --password
> >YourOSGeoPwd
> >svn checkout https://fdowfs.osgeo.org/svn/fdowfs/trunk/Providers/WFS
> >"D:OSGeoFDODev\Providers\WFS" --username YourOSGeoUsername --password
> >YourOSGeoPwd
> >svn checkout https://fdowms.osgeo.org/svn/fdowms/trunk/Providers/WMS
> >"D:OSGeoFDODev\Providers\WMS" --username YourOSGeoUsername --password
> >YourOSGeoPwd
> >svn checkout
> >https://fdoarcsde.osgeo.org/svn/fdoarcsde/trunk/Providers/ArcSDE
> >"D:OSGeoFDODev\Providers\ArcSDE" --username YourOSGeoUsername
> >svn checkout
> >https://fdordbms.osgeo.org/svn/fdordbms/trunk/Providers/GenericRdbms
> >"D:OSGeoFDODev\Providers\GenericRdbms" --username YourOSGeoUsername
> >svn checkout
> >https://fdogdal.osgeo.org/svn/fdogdal/trunk/Providers/GDAL
> >"D:OSGeoFDODev\Providers\GDAL" --username YourOSGeoUsername --password
> >YourOSGeoPwd
> >Definitely not a god.  Had to struggle a bit to figure it out.
> >*Sent:* Friday, September 15, 2006 09:00
> >Jason,
> >I dont have thirdparty directory! How is that possible?
> >*From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> >*Sent:* 15. rujan 2006 17:41
> >*Su**bject:* Re: [mapguide-users] POOL:DWF or AJAX
> >right
> >Ivan Milic(evic' wrote:
> >Ok, thanks!!!
> >And just one more thing...
> >3. Ensure that the Windows Environment Variables are set as follows:
> >        SET FDO=[FDO OpenSource]\Fdo
> >        SET FDOUTILITIES=[FDO OpenSource]\Utilities
> >        SET FDOTHIRDPARTY=[FDO OpenSource]\ThirdParty
> >        SET XALANROOT=%FDOTHIRDPARTY%\apache\xml-xalan\c
> >        SET XERCESCROOT=%FDOTHIRDPARTY%\apache\xml-xerces\c
> >        SET NLSDIR=%XALANROOT%\Src\xalanc\NLS
> >Q: What is variable and what is value? For example? Is FDO variable
> >and [FDO OpenSource]\Fdo value? Is that correct?
> >*Sent:* 15. rujan 2006 17:30
> >*To:* users at mapguide.osgeo.org <mailto:users at mapguide.osgeo.org>
> >I don't think that it's published anywhere in an easy-to-read format.
> >You can either mine the Project Tracker (this is used extensively) for
> >items with a target release of 1.0.2:
> >https://mapguide.osgeo.org/servlets/Scarab
> >or search through the Issues or Commits mailing lists depending on the
> >amount of detail you want:
> >https://mapguide.osgeo.org/servlets/SummarizeList?listName=issues
> >https://mapguide.osgeo.org/servlets/SummarizeList?listName=commits
> >Jason
> >*From:* Ivan Milic(evic' [mailto:ivan at ineo.hr <mailto:ivan at ineo.hr>]
> >*Sent:* Friday, September 15, 2006 08:17
> >Jason, where can i find a list of changes from 1.0.1. until today
> >(talking about mapguides server)?
> >*Sent:* 15. rujan 2006 17:09
> >You can actually use these tools in conjunction.  I have both
> >installed, and will sometimes use the Tortoise tool when I know a
> >single file has changed and I don't want to go through the whole
> >process.  However, I prefer the commandline tools because they allow
> >me to script the update/export/build process.  My process is something
> >like:
> >- Update FDO (using a version of the batch file provided in the
> >repository, changed from checkout to update)
> >- Export FDO to a build directory
> >- Build FDO third party tools
> >- Build FDO
> >- Update MapGuide
> >- Export MapGuide to a build directory
> >- Install FDO into the MapGuide OEM structure
> >- Build MapGuide
> >- Transfer MapGuide to my VMWare server.
> >With command line tools, I've been able to script most of this, with
> >the exception of building MapGuide.
> >Ivan, you've probably figured this out from the path that Kenneth
> >provided, but this is the command to check out MapGuide
> >svn checkout https://mapguide.osgeo.org/svn/mapguide/trunk/MgDev
> >"D:\OSGeo\MGDev" --username YourOSGeoID --password YourOSGeoPwd
> >Jason
> >*From:* Kenneth, GEOGRAF A/S [mailto:ks at geograf.dk]
> >*Sent:* Friday, September 15, 2006 07:26
> >If you feel uncomfortable using commandline tools, I would recommend
> >that you try
> >TortoiseSVN, which is an Explorer extension.
> >http://tortoisesvn.tigris.org/
> >That way, you can check out, or update simply by right clicking on the
> >folder in Explorer.
> >Using this approach, you only need the URL of the repository, which
> >can be found on the osgeo website under "Subversion".
> >FDO: https://fdo.osgeo.org/svn/fdo/trunk
> >MapGuide: |https://mapguide.osgeo.org/svn/mapguide/trunk|
> >*Andrew DeMerchant*
> >*Computer Technologist*
> >ph.1-877-4GEMTEC x.163
> >fax 506-453-9470
> >/GEMTEC Limited <http://www.gemtec.ca>
> >/191 Doak Road
> >Fredericton, NB, Canada
> >E3C 2E6
Mit freundlichen Grüßen,
  Axel Gross
More information about the Mapguide_users mailing list
