[mapguide-users] Linking to external data (Raster and Shape)
robert fritz robert-fritz at web.de
Fri Sep 29 04:38:49 EDT 2006
Hi Tom,
I created the XML files again and checked them with XMLSpy. I deleted one wordwrap and added an "\" at the end of the data-path to the raster-images.
Now it works (German XPPro). So, I'm sorry, it  was my fault. But the problem with the Shapes files still exist - i can load and display the shapes file using Studio (via Load Procedure), but I can't display them using the external link - but thats not so important now.
regards, Robert
Hi Robert,
For the Raster Data, the de-serialize problem is due to a "," vs "." as
the decimal point in the OS.  A fix has been submitted for this in the
1.0.x branch codestream.  In the meantime, you may need to install on an
OS language that uses "." as the decimal point; I'm not sure if anyone
else got it to work any other way.
For the SHP data, if you use a Studio load procedure to load the data,
can you see it in the preview in that case?  Are there any error
messages in the server error logs?
Regards,
Tom
-----Original Message-----
Sent: Thursday, September 28, 2006 6:40 AM
Subject: [mapguide-users] Linking to external data (Raster and Shape)
Dear List,
I tried to link to external data as descripted in the WhitePaper by
Autodesk (see:
http://images.autodesk.com/adsk/files/linking_to_external_data_autodeskm
apguidewhitepaper.pdf).
Raster Data
In MapGuide Studio I can see the new data source, but if I try to create
a new layer and open the data source I get the error message "Feature
source is invalid,...,Failed to de-serialize the spatial contexts from
configuration". If I try to load the 4 raster images directly in Studio
everything works fine - I can see the images. I tried to change the
coordinate system (german gauss krueger to X-Y), i checked the bounding
box several times - nothing.
Shape Data
In MapGuide Studio I can see the new data source, and I can see the
shapes in the "feature data setup" / "feature class" of the
Layer-definition, but they are not displayed in the layer preview.
Any ideas?
regards, Robert
_______________________________________________________________________
Viren-Scan für Ihren PC! Jetzt für jeden. Sofort, online und kostenlos.
Gleich testen! http://www.pc-sicherheit.web.de/freescan/?mc=022222
More information about the Mapguide_users mailing list
