[mapguide-users] Invalid stream header exception.
Kerndata.com Support
support at kerndata.com
Sat Sep 30 01:10:18 EDT 2006
Well... I hadn't tried that.
I changed the file to .zip - unzipped it (well - started). I can see the files - when I start the unzip I get this warning:
Warning: skipping "0p1_SETRESOURCES_CONTENT.xml". The 32-bit CRC stored in the local header for this file is not the same as the 32-bit CRC stored in the central header.
After skipping that file I receive "Error in file #2: bad Zip offset (Error local header signature not found): disk #1 offset: 319.
Etc.
Any insight?
Eric Brown
Kerndata.com
----- Original Message -----
Sent: Friday, September 29, 2006 9:56 PM
Subject: RE: [mapguide-users] Invalid stream header exception.
Are you absolutely sure that the package is making it intact?
If you have access to the console on the server, try renaming the package to .zip and unzipping it. If not, try downloading it and unzipping it on your local computer.
Jason
From: Kerndata.com [mailto:support at kerndata.com]
Sent: Friday, September 29, 2006 17:06
Subject: [mapguide-users] Invalid stream header exception.
All,
I've recently purchased Mapguide Studio 2007 and have been starting over - recreating everything from scrath on my Mapserver Opensource 1.0.1.17812
I have a rather large Parcel layer (100mb) and so I'm creating a package and ftp'ing it over to the server. However, when I go to load the package in the admin it gives me an error before I can even get to it - the error is "Invalid stream header exception." And the package isn't listed.
After several different attempts (my first assumption was that the package became corrupted during transport) I decided to package up a smaller file to see what would happen with that.
The small package also fails to load with the same error.
Any advice would be very helpful.
Thank you,
Eric Brown
Kerndata.com
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060929/b7c3af6f/attachment.html
More information about the Mapguide_users
