[mapguide-users] Invalid stream header exception.
Kerndata.com Support
support at kerndata.com
Sat Sep 30 21:00:16 EDT 2006
I got to playing with this packaging issue - and decided I should try to package the Sheboygan demo files to see what would happen. Same issue - when I port it over to the server and move it to the package folder - the admin indicates "Invalid stream header exception." - I'm not sure what would cause that issue - except perhaps a conflict between Mapguide Studio 2007 and Mapguide Open Source 1.0.1.17812.
In the above scenario I was able to change the .mgp file to a .zip and unzip - whereas my prior file resulted in some sort of corruption internally in the archve. However - as stated - the server error remains.
In that same stream of thought I decided to play with the Sheboygan demo - and I receive the same types of errors when attempting to apply any type of filtering on any layer. I receive a script error when i try to refresh any layer that has any type of filtering applied. " Expected ')' "
Do I need to change the server version? Is there some sort of patch? I can't imagine that I'm the only one experiencing this issue.
Eric Brown
Kerndata.com
----- Original Message -----
Sent: Friday, September 29, 2006 9:56 PM
Subject: RE: [mapguide-users] Invalid stream header exception.
Are you absolutely sure that the package is making it intact?
If you have access to the console on the server, try renaming the package to .zip and unzipping it. If not, try downloading it and unzipping it on your local computer.
Jason
From: Kerndata.com [mailto:support at kerndata.com]
Sent: Friday, September 29, 2006 17:06
Subject: [mapguide-users] Invalid stream header exception.
All,
I've recently purchased Mapguide Studio 2007 and have been starting over - recreating everything from scrath on my Mapserver Opensource 1.0.1.17812
I have a rather large Parcel layer (100mb) and so I'm creating a package and ftp'ing it over to the server. However, when I go to load the package in the admin it gives me an error before I can even get to it - the error is "Invalid stream header exception." And the package isn't listed.
After several different attempts (my first assumption was that the package became corrupted during transport) I decided to package up a smaller file to see what would happen with that.
The small package also fails to load with the same error.
Any advice would be very helpful.
Thank you,
Eric Brown
Kerndata.com
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060930/d9429069/attachment.html
More information about the Mapguide_users
