[Mapguide_users] Site Server usage for load balancing
Traian Stanev traian.stanev at autodesk.com
Tue Jan 2 10:25:48 EST 2007
Hard to tell if site servers will help at all without knowing what's in
your map.
You should also consider simplifying your layer styles, having less
layers visible, converting data to SDF files (which are faster than
other data sources), not using joins, converting all data to the same
coordinate system, etc.
Traian
-----Original Message-----
[mailto:mapguide_users-bounces at lists.osgeo.org] On Behalf Of Kencana
Sent: Thursday, December 28, 2006 7:50 PM
To: Mapguide_users at lists.osgeo.org
Subject: [Mapguide_users] Site Server usage for load balancing
Hi all,
is that possible to install more than 2 site servers to load balancing
the map performance?
or is there any other way to do it so that i can increase the
performance?
Thank you
Regards,
Kencana
View this message in context:
http://www.nabble.com/Site-Server-usage-for-load-balancing-tf2892869.htm
l#a8082397
Mapguide_users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide_users
More information about the Mapguide_users mailing list
