[Mapguide_users] MapGuide OS Package to Ent Inpot Issues with Cord Systems
Chris Gountanis cgountanis at mpower-tech.com
Mon Jan 8 16:56:24 EST 2007
When a MapGuide project is packaged (MGP) from an Open Source MapGuide seems
there is issues viewing layers once imported to Enterprise. Is there a work
around to fix the cord systems so once imported to an Ent Server everything
works the same. I am sure others might run into this working with diff
customer needs and such.
*******************ERROR*******************
The coordinate system is invalid. PROJCS["NAD83 Ohio State Planes, Northern
Zone, US
Foot",GEOGCS["NAD83",DATUM["D_NAD83",SPHEROID["Geodetic_Reference_System_of_
1980",6378137,298.2572221009113]],PRIMEM["Greenwich",0],UNIT["Degree",0.0174
53292519943295]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["standard_p
arallel_1",41.7],PARAMETER["standard_parallel_2",40.4333333333333],PARAMETER
["latitude_of_origin",39.6666666666667],PARAMETER["central_meridian",-82.5],
PARAMETER["false_easting",1968500],PARAMETER["false_northing",0],UNIT["Foot_
US",0.3048006]] Could not convert OGC WKT to Mentor. wktFlvrNone - WKT
string referenced datum named 'D_NAD83'. This datum name could not be mapped
to a dictionary definition wktFlvrOgc - The PROJECTION specification
contained within the text presented as a WKT definition specified an
unsupported projection (Lambert_Conformal_Conic). wktFlvrGeoTiff - The
PROJECTION specification contained within the text presented as a WKT
definition specified an unsupported projection (Lambert_Conformal_Conic).
wktFlvrEsri - WKT string referenced datum named 'D_NAD83'. This datum name
could not be mapped to a dictionary definition wktFlvrOracle - The
wktFlvrGeoTools - The PROJECTION specification contained within the text
presented as a WKT definition specified an unsupported projection
(Lambert_Conformal_Conic). wktFlvrEpsg - WKT system named NAD83 Ohio State
Planes uses a parameter arrangement unsupported by CS-MAP. None of the
Mentor flavors could parse the specified OGC WKT.
Zone, US
Mentor flavors could parse the specified OGC WKT. Exception occurred in
method MgCoordinateSystem.MgCoordinateSystem at line 76 in file
c:\build_tux_area\mgdev\common\service\coordinatesystem\CoordinateSystem.cpp
Chris
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20070108/4a0e78b6/attachment.html
More information about the Mapguide_users mailing list
