[Mapguide_users] RE: mapguide, php, and linux
Willem Schwarte
willem at giskit.nl
Wed Jan 10 06:03:03 EST 2007
I have had much better performance on Linux. Where on Windows it took 4
seconds for zooming, on Linux it took about 2 seconds...
Read this:
We also tried comparing a Windows to a Linux based server on identical
hardware and Linux was faster by quite a margin. Not sure why, it's some
kind of a mystery.
Traian
Sent: Tuesday, July 25, 2006 7:40 AM
Subject: RE: [mapguide-users] Using Symbols strange behaviour... BUG?!
We now installed Mapserver Enterprise on Linux (RedHat), and strangly
enough the symbols are shown correctly here?! Isn't that strange? I
packaged the map from the windows server and loaded it on the linux...
Also, the Linux version is about 3-4 times more quickly than the windows
server. The linux now has a PIII proc, while the windows has a Xeon.
When map loading time on Windows is about 15-20 seconds (depending on
the map of course) the same map on the Linux server loads in 8-13
seconds!!!
I now have set up a map that loads in 5 seconds. Zooming and panning
takes about 2 seconds. And it has not failed to load yet!
I only hope that we can still use access databases...
Willem
-----Oorspronkelijk bericht-----
Van: mapguide_users-bounces at lists.osgeo.org
[mailto:mapguide_users-bounces at lists.osgeo.org] Namens Andy Morsell
Verzonden: woensdag 10 januari 2007 2:38
Aan: Mapguide_users at lists.osgeo.org
Onderwerp: RE: [Mapguide_users] RE: mapguide, php, and linux
I don't have any benchmarks or anything on servers with similar
hardware,
but from what I've seen so far, Windows seems to perform a little bet
better. Again, that's purely anecdotal and not based on any real
testing.
Andy
-----Original Message-----
[mailto:mapguide_users-bounces at lists.osgeo.org] On Behalf Of Kencana
Sent: Tuesday, January 09, 2007 4:38 PM
To: Mapguide_users at lists.osgeo.org
Subject: Re: [Mapguide_users] RE: mapguide, php, and linux
Hi Trevor,Andy
Thanks for the explanation. can I know which will give better
performance?
linux or windows?
Thank you
Regards,
Kencana
Trevor Wekel wrote:
> Hi Kencana,
> Yes. The PHP WebExtensions API is the same on Windows and Linux. If
> your page / URL references are relative then you should be able to
> simply copy the code to Apache and package or copy the Server
> repositories to Linux.
> Thanks,
> Trevor
> _______________________________
> Hi all,
> as previously i done my code in php,windows server 2003, IIS, i was
> wondering if i migrate it to a linux server will it works?
> and instead of working with IIS, i was wondering mapguide will work on
> tomcat or apache in linux server.
> so, my plan is to migrate to a linux server using PHP,Tomcat or
apache?
> will everything works just like in windows server 2003?
> Regards,
> Kencana
> http://www.nabble.com/mapguide%2C-php%2C-and-linux-tf2943556.html#a823
> 10
> 50
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Mapguide_users mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide_users
http://www.nabble.com/mapguide%2C-php%2C-and-linux-tf2943556.html#a82500
50
More information about the Mapguide_users
