[Mapguide_users] CGI QueryMapFeatures
Bruce Dechant bruce.dechant at autodesk.com
Thu Jan 11 18:20:26 EST 2007
Scott,
There is no document for the HTTP operations at this time. If you are
brave you can look at the web tier code as all of the operations are
listed there.
A good place to start would be the source files located here:
..\Web\src\HttpHandler
The above folder contains all of the current HTTP operations.
Thanks,
Bruce
-----Original Message-----
[mailto:mapguide_users-bounces at lists.osgeo.org] On Behalf Of Scott
Hameister
Sent: January 11, 2007 9:45 AM
To: Mapguide_users at lists.osgeo.org
Subject: RE: [Mapguide_users] CGI QueryMapFeatures
Is there any documentation on the FCGI OPERATIONS and params Yet?
Since the WebAPI is so wrapped around it it would be nice to no what
parameters are available...
When I goto http://localhost/mapguide/mapagent/index.html
"OPERATION=QueryMapFeatures" isn't even an option...and I'm assuming
even
this site doesn't give all the options of FCGI params either.
Hameister
Sent: Wednesday, January 10, 2007 6:47 PM
Subject: [Mapguide_users] CGI QueryMapFeatures
I can't find documentation on the FCGI operation QueryMapFeatures
When I change the ViewerAPi Code where it filters by the selectable and
visible layers " LAYERNAMES=" + encodeURIComponent(GetVisSelLayers())"
To a list of Non-visible layers it doesn't work....
....I want users to be able to select features using the geometry on
layers
that are not visible as well for parsing purposes? Can I use this
Operation
for that
Mapguide_users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide_users
More information about the Mapguide_users mailing list
