[MapProxy-dev] Trigger seeding in mapproxy via REST
André Henn
henn at terrestris.de
Tue Apr 19 01:51:50 PDT 2022
Hi all,
seeding for tile generation can currently -afaik- only be started using
the mapproxy-seed - script and a corresponding seed.yaml.
But sometimes, it might be useful to trigger re-seed / cleanup for
certain areas or caches by an external application without calling the
reseed script directly.
For example, cache handling for frequently used layers that are updated
only in a certain area could be such a use case.
I think, a (small) WSGI application (like wsgiapp.py) providing a REST
endpoint (HTTP POST) could be a solution. This endpoint would handle a
json body containing (maybe a shortened) seeding configuration, for
example like this:
"seedConfig": {
"cleanups": {
"cleanupPolygon": {
"caches": [
"layer_cache"
"coverages": [
"changes_entity_area1"
"coverages": {
"changes_entity_area1": {
"bbox": [
638207.82,
5683208.6,
638666.91,
5683227.69
"srs": "EPSG:25832"
"config": {
"dry_run": false,
"concurrency": 2
Do you think, such a REST endpoint might be included in mapproxy core,
or would this be some kind of "plugin" / custom build?
If you are interested, I could provide a corresponding PR draft for this.
Kind regards,
André
Dipl.-Ing. André Henn
- Anwendungsentwickler -
terrestris GmbH & Co. KG
Kölnstraße 99
53111 Bonn
Tel: +49 (0)228 / 96 28 99 -557
Fax: +49 (0)228 / 96 28 99 -57
Email: henn at terrestris.de
Web: https://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin: terrestris Verwaltungsgesellschaft mbH vertreten durch:
Torsten Brassat, Marc Jansen
Informationen über Ihre gespeicherten Daten finden Sie auf
unserer Homepage unter folgendem Link:
https://www.terrestris.de/datenschutzerklaerung/
More information about the MapProxy-dev
