[MapProxy-dev] Integration of new features in mapproxy
Malapert Jean-Christophe
Jean-Christophe.Malapert at cnes.fr
Wed Mar 9 04:37:34 PST 2022
Dear All,
My name is Jean-Christophe Malapert and I am engineer in CNES and also the co-chair of the Planetary DWG at OGC (https://www.ogc.org/projects/groups/planetarydwg).
Currently, I am setting up a Surfaces Planetary data center in France with all scientific laboratories in Planetology. My community (in general planetology) is divided in two parts :
- Scientific/engineers coming from Astronomy world and using IVOA standards (https://ivoa.net<https://ivoa.net/>)
- Scientific/engineers coming from Geosciences world and using OGC standards
Each world uses its own clients (e.g leaflet for OGC ; Aladin for IVOA) and no one wants to implement the access protocols of the other world. In this context, we have realized a study and a prototype to map the access standards from OGC/IVOA for images. Thanks to this prototype, QGIS/leaflet can access to astronomical data and Aladin can access to data distributed by WMS/WMTS servers.
It would be great if :
* 1/ the contribution could be integrated in mapproxy. I am attaching the study report (https://docs.google.com/document/d/1fJJYVNYg2uWhCaN3fxlBLg09vFND0YLLUiGRJ_fCh5c/edit?usp=sharing) .
* 2/ the Integration of the IAU CRS in mapproxy can be done
services:
wms:
srs: ['IAU:1000']
sources:
test:
type: wms
supported_srs: ['IAU:1000']
req:
url: https://....
layers: blah
The statement srs: ['IAU:1000'] at the service level passes (if I don't put which, I see it as a possible CRS in the GetCapabilities, but without an associated BoundingBox), but not supported_srs: ['IAU:1000'] at the source level, which crashes with:
File "/home/even/spatialys/cnes/2021/hips/mapproxy/mapproxy/config/loader.py", line 804, in source
supported_srs=self.supported_srs(),
File "/home/even/spatialys/cnes/2021/hips/mapproxy/mapproxy/config/loader.py", line 578, in supported_srs
supported_srs = [SRS(code) for code in self.conf.get('supported_srs', [])]
File "/home/even/spatialys/cnes/2021/hips/mapproxy/mapproxy/config/loader.py", line 578, in <listcomp>
File "/home/even/spatialys/cnes/2021/hips/mapproxy/mapproxy/srs.py", line 96, in SRS
srs = _srs_impl(srs_code)
File "/home/even/spatialys/cnes/2021/hips/mapproxy/mapproxy/srs.py", line 320, in __init__
self.proj = CRS.from_epsg(epsg_num)
File "/home/even/spatialys/cnes/2021/hips/mapproxy/venv/lib/python3.8/site-packages/pyproj/crs/crs.py", line 370, in from_epsg
return cls.from_user_input(_prepare_from_epsg(code))
File "/home/even/spatialys/cnes/2021/hips/mapproxy/venv/lib/python3.8/site-packages/pyproj/crs/crs.py", line 479, in from_user_input
return cls(value, **kwargs)
File "/home/even/spatialys/cnes/2021/hips/mapproxy/venv/lib/python3.8/site-packages/pyproj/crs/crs.py", line 326, in __init__
self._local.crs = _CRS(self.srs)
File "pyproj/_crs.pyx", line 2352, in pyproj._crs._CRS.__init__
pyproj.exceptions.CRSError: Invalid projection: epsg:1000: (Internal Proj Error: proj_create: crs not found)
At some point MapProxy assumes that the CRS is an EPSG apparently.
IAU CRS
IAU (International Astronomical Union) CRS is based on the report of this group https://astrogeology.usgs.gov/groups/IAU-WGCCRE. Based on this report, the WKT-crs group (https://www.ogc.org/standards/wkt-crs) from OGC has modified (a simple addition) its standard in order to be compliant with the CRS defined in IAU. In addition, we are working at OGC to integrate the IAU crs within the OGC standards (e.g : https://github.com/opengeospatial/NamingAuthority/issues/113)
In addition, proj has now IAU CRS definition : https://github.com/OSGeo/PROJ/pull/2876 . Same thing for GDAL : https://github.com/OSGeo/gdal/pull/5287. Based on this pull request, mapserver can also accept SRS=IAU:xxxx as input parameter for WMS requests https://github.com/MapServer/MapServer/pull/6484 . The last version of QGIS also integrates the IAU CRS.
Please let me know if you could integrate these 2 features in your roadmap and if you need any help from CNES to help you
Best regards,
Jean-Christophe
[cid:image002.png at 01D833BA.D50B97B0]
Jean-Christophe MALAPERT
Expert Dev. Segments Sols Scientifiques
DTN/CD/SC
18 avenue Edouard Belin 31401 Toulouse Cedex 9
[http://publi.portail.cnes.fr/sites/CNES_Pratique/DocumentsCNES/signature%20version%20finale/signature_cnes_fr_externe_fichiers/phone.png] +33 (0)5 61 28 14 45 / [cid:image006.png at 01D833BA.D50B97B0] +33 (0)6 42 94 63 10
[http://publi.portail.cnes.fr/sites/CNES_Pratique/DocumentsCNES/signature%20version%20finale/signature_cnes_fr_externe_fichiers/email.png] jean-christophe.malapert at cnes.fr
[http://publi.portail.cnes.fr/sites/CNES_Pratique/DocumentsCNES/signature%20version%20finale/signature_cnes_fr_externe_fichiers/web.png] cnes.fr<http://cnes.fr/>
[http://publi.portail.cnes.fr/sites/CNES_Pratique/DocumentsCNES/signature%20version%20finale/signature_cnes_fr_externe_fichiers/facebook.png]<https://www.facebook.com/CNESFrance/> [http://publi.portail.cnes.fr/sites/CNES_Pratique/DocumentsCNES/signature%20version%20finale/signature_cnes_fr_externe_fichiers/instagram.png] <https://www.instagram.com/cnes_france/> [http://publi.portail.cnes.fr/sites/CNES_Pratique/DocumentsCNES/signature%20version%20finale/signature_cnes_fr_externe_fichiers/twitter.png] <https://twitter.com/cnes>
URL: <http://lists.osgeo.org/pipermail/mapproxy-dev/attachments/20220309/fd92bbb3/attachment-0001.html>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/mapproxy-dev/attachments/20220309/fd92bbb3/attachment-0008.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/mapproxy-dev/attachments/20220309/fd92bbb3/attachment-0009.png>
Type: image/png
Desc: image006.png
URL: <http://lists.osgeo.org/pipermail/mapproxy-dev/attachments/20220309/fd92bbb3/attachment-0010.png>
Type: image/png
Desc: image008.png
URL: <http://lists.osgeo.org/pipermail/mapproxy-dev/attachments/20220309/fd92bbb3/attachment-0011.png>
Type: image/png
Desc: image010.png
URL: <http://lists.osgeo.org/pipermail/mapproxy-dev/attachments/20220309/fd92bbb3/attachment-0012.png>
Type: image/png
Desc: image012.png
URL: <http://lists.osgeo.org/pipermail/mapproxy-dev/attachments/20220309/fd92bbb3/attachment-0013.png>
Type: image/png
Desc: image014.png
URL: <http://lists.osgeo.org/pipermail/mapproxy-dev/attachments/20220309/fd92bbb3/attachment-0014.png>
Type: image/png
Desc: image016.png
URL: <http://lists.osgeo.org/pipermail/mapproxy-dev/attachments/20220309/fd92bbb3/attachment-0015.png>
More information about the MapProxy-dev
