MapServer 4.4.1 released
    Daniel Morissette
    dmorissette at DMSOLUTIONS.CA
    Wed Dec 22 18:31:55 EST 2004
MapServer 4.4.1 has been released just in time for Xmas. This new
release addresses a few issues that were found in version 4.4.0 and
contains no new functionality. The list of fixes is included at the end
of this message.
The source package is available in the downloads page of the website as
usual. Due to the (bad) timing with the holidays, it may take a few days
before Windows binaries are available for this version.
Happy holidays everyone!
Daniel
Daniel Morissette               dmorissette at dmsolutions.ca
DM Solutions Group              http://www.dmsolutions.ca/
Version 4.4.1 (2004-12-22)
- Spacing between hatch lines (new HATCH symbol type) is now consistent
regardless of angle.
- Oracle Spatial:
Fixed problem with LayerClose function.
Added token NONE for DATA statement.
Thanks Valik with the hints about the LayerClose problem and Francois
with the hints about NONE token.
- numpoints and stylelength members of the symbol object need to be in sync
with the low level values after calls to setpoints and setstyle (Bug
1137).
- Use doubles instead of integers in function php3_ms_symbol_setPoints
(Bug 1137).
- Fixed msFreeFileCtx() to call free() instead of gdFree() as per bug 1125.
Also renamed gdFreeFileCtx() to msFreeFileCtx().
- Fixed MyGIS build error introduced when adding msLayerIsOpen() (bug 1116)
- Fixed segmentation fault when generating PDF output (bug 1105)
- Fixed wms 1.1.1 capabilities issue: Point to WMS_MS_Capabilities.dtd
instead of capabilities_1_1_1.dtd (Bug 1097)
- Fixed problem with accumlated error stacks in fastcgi mode.  Bug 1122
- Fixed support for SIZEUNITS based scaling of text when map is rotated.
Bug 1127.
More information about the mapserver-announce
