[mapserver-commits] r7152 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Dec 7 03:52:01 EST 2007
Author: tbonfort
Date: 2007-12-07 03:52:00 -0500 (Fri, 07 Dec 2007)
New Revision: 7152
trunk/mapserver/maplabel.c
revert last commit (was the wrong file) duh....
Modified: trunk/mapserver/maplabel.c
--- trunk/mapserver/maplabel.c 2007-12-07 08:34:56 UTC (rev 7151)
+++ trunk/mapserver/maplabel.c 2007-12-07 08:52:00 UTC (rev 7152)
@@ -39,62 +39,6 @@
MS_CVSID("$Id$")
-char *centerText(char *text) {
- char *textptr=text;
- char *newtext,*newtextptr;
- int numlines=1,curline=0,curlen=0,maxlen=0,i,newlen;
- int *lens;
- char glyph[12];
- //count number of newlines
- while(*textptr) {
- if(*(textptr++)=='\n')
- numlines++;
- if(numlines==1) return NULL;
- lens=(int*)malloc(numlines*sizeof(int));
- textptr=text;
- while(*textptr) {
- msGetNextGlyph((const char**)&textptr,glyph);
- if(*glyph=='\n') {
- lens[curline]=curlen;
- curlen=0;
- curline++;
- else
- curlen++;
- lens[curline]=curlen; //last line isn't terminated with \n
- for(i=0;i<numlines;i++) {
- if(lens[i]>maxlen)
- maxlen=lens[i];
- newlen=strlen(text)+1;
- if(lens[i]!=maxlen) {
- newlen+=ceil((maxlen-lens[i])*3/4.); //number of spaces needed for padding the current line
- newtext=(char*)malloc(newlen);
- textptr=text;
- newtextptr=newtext;
- int nstart,j;
- nstart=ceil((maxlen-lens[i])*3/4.);
- for(j=0;j<nstart;j++) {
- *(newtextptr++)=' ';
- while(1) {
- *(newtextptr++)=*(textptr);
- if(*(textptr)=='\n' || *(textptr)=='\0')
- {textptr++;break;}
- else
- textptr++;
- free(lens);
- return newtext;
* this function applies the label encoding and wrap parameters
* to the supplied text
@@ -103,32 +47,16 @@
char *msTransformLabelText(labelObj *label, char *text)
- int minwraplength=8;
- int curlgth=0;
- char glyph[12];
- char *newtext,*newnewtext,*txtptr,*glyphptr;
+ char *newtext;
if(label->encoding)
newtext = msGetEncodedString(text, label->encoding);
else
newtext=strdup(text);
if(newtext && label->wrap!='\0') {
- txtptr=glyphptr=newtext;
- while(msGetNextGlyph((const char**)&txtptr,glyph)!=-1) {
- if(*glyph==label->wrap && curlgth>minwraplength) {
- *glyphptr='\n';
- curlgth=0;
- } else
- curlgth++;
- glyphptr=txtptr;
+ msReplaceChar(newtext, label->wrap, '\n');
- if((newnewtext=centerText(newtext))==NULL)
- return newtext;
- else {
- free(newtext);
- return newnewtext;
+ return newtext;
int msAddLabel(mapObj *map, int layerindex, int classindex, int shapeindex, int tileindex, pointObj *point, labelPathObj *labelpath, char *string, double featuresize, labelObj *label )
More information about the mapserver-commits
