[mapserver-commits] r7177 - trunk/mapserver/mapscript/csharp
svn at osgeo.org
svn at osgeo.org
Mon Dec 17 04:38:25 EST 2007
Author: tamas
Date: 2007-12-17 04:38:24 -0500 (Mon, 17 Dec 2007)
New Revision: 7177
trunk/mapserver/mapscript/csharp/csmodule.i
Removed the temporary stuff.
Modified: trunk/mapserver/mapscript/csharp/csmodule.i
--- trunk/mapserver/mapscript/csharp/csmodule.i 2007-12-16 13:13:33 UTC (rev 7176)
+++ trunk/mapserver/mapscript/csharp/csmodule.i 2007-12-17 09:38:24 UTC (rev 7177)
@@ -20,40 +20,6 @@
//#define ALLOW_INNER_EXCEPTIONS
//#endif
-/*Uncomment the following line if you want to use global lock around the method
-calls to test against potential thread safety problems */
-//#define USE_GLOBAL_LOCK
-#ifdef USE_GLOBAL_LOCK
-#ifndef WIN32
-%insert(runtime) %{
-#include "pthread.h"
-static pthread_mutex_t global_lock = -1;
-void GetLock() {
-if (!global_lock)
- global_lock = PTHREAD_MUTEX_INITIALIZER
- pthread_mutex_lock( &global_lock );
-void ReleaseLock() {
- pthread_mutex_unlock( &global_lock );
-#else
-#include <windows.h>
-static HANDLE global_lock = NULL;
-void GetLock() {
-if (!global_lock)
- global_lock = CreateMutex( NULL, TRUE, NULL );
- WaitForSingleObject( global_lock, INFINITE );
- ReleaseMutex( global_lock );
-#endif
-#endif
%ignore fp;
@@ -82,13 +48,6 @@
%exception
errorObj *ms_error;
- #ifdef USE_GLOBAL_LOCK
- GetLock();
- #endif
- $action
- ReleaseLock();
- #endif
ms_error = msGetErrorObj();
if (ms_error != NULL && ms_error->code != MS_NOERR) {
if (ms_error->code != MS_NOTFOUND && ms_error->code != -1) {
@@ -112,13 +71,6 @@
%exception
errorObj *ms_error;
- GetLock();
- #endif
- $action
- ReleaseLock();
- #endif
More information about the mapserver-commits
