[mapserver-commits] r7188 - in trunk/mapserver: . mapscript/doc
mapscript/java/examples mapscript/swiginc
svn at osgeo.org
svn at osgeo.org
Wed Dec 19 05:44:21 EST 2007
Author: unicoletti
Date: 2007-12-19 05:44:20 -0500 (Wed, 19 Dec 2007)
New Revision: 7188
trunk/mapserver/mapscript/doc/mapscript.txt
trunk/mapserver/mapscript/java/examples/DrawMap.java
trunk/mapserver/mapscript/swiginc/image.i
trunk/mapserver/mapserver.h
#2448: implement getSize on imageObj
Modified: trunk/mapserver/mapscript/doc/mapscript.txt
--- trunk/mapserver/mapscript/doc/mapscript.txt 2007-12-18 23:26:29 UTC (rev 7187)
+++ trunk/mapserver/mapscript/doc/mapscript.txt 2007-12-19 10:44:20 UTC (rev 7188)
@@ -859,8 +859,12 @@
MS_RENDER_WITH_GD, MS_RENDER_WITH_SWF, MS_RENDER_WITH_RAWDATA,
MS_RENDER_WITH_PDF, or MS_RENDER_WITH_IMAGEMAP. Don't mess with this!
-size : int
- I don't see where this is used. Anyone? --SG
+size : int immutable
+ To access this attribute use the getSize method.
+.. note:: the getSize method is inefficient as it does a call to getBytes and then computes
+ the size of the byte array. The bytearray is then immediately discarded. In most
+ cases it is more efficient to call getBytes directly.
width : int immutable
Image width in pixels.
@@ -882,6 +886,13 @@
form of this buffer will vary by mapscript language (eg. string in Python,
byte[] array in Java and C#, unhandled in perl)
+getSize() : int
+ Resturns the size of the binary buffer representing the image buffer.
+ the size of the byte array. The byte array is then immediately discarded. In most
save( string filename [, mapObj_ parent_map=NULL ] ) : int
Save image to *filename*. The optional *parent_map* parameter must be
specified if saving GeoTIFF images.
Modified: trunk/mapserver/mapscript/java/examples/DrawMap.java
--- trunk/mapserver/mapscript/java/examples/DrawMap.java 2007-12-18 23:26:29 UTC (rev 7187)
+++ trunk/mapserver/mapscript/java/examples/DrawMap.java 2007-12-19 10:44:20 UTC (rev 7188)
@@ -36,6 +36,8 @@
int i=0;
//for (i=0; i<100; i++) {
imageObj img = map.draw();
+ System.out.println("Image size is: "+img.getSize());
+ System.out.println("Image size from getBytes is: "+img.getBytes().length);
System.out.println(i+") the map will be drawn to:"+args[1]);
img.save(args[1], map);
Modified: trunk/mapserver/mapscript/swiginc/image.i
--- trunk/mapserver/mapscript/swiginc/image.i 2007-12-18 23:26:29 UTC (rev 7187)
+++ trunk/mapserver/mapscript/swiginc/image.i 2007-12-19 10:44:20 UTC (rev 7188)
@@ -224,6 +224,20 @@
return buffer;
+ int getSize() {
+ gdBuffer buffer;
+ int size=0;
+ buffer.data = msSaveImageBuffer(self, &buffer.size, self->format);
+ size = buffer.size;
+ if( buffer.data == NULL || buffer.size == 0 ) {
+ buffer.data = NULL;
+ msSetError(MS_MISCERR, "Failed to get image buffer size", "getSize");
+ free(buffer.data);
+ return size;
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2007-12-18 23:26:29 UTC (rev 7187)
+++ trunk/mapserver/mapserver.h 2007-12-19 10:44:20 UTC (rev 7188)
@@ -1333,7 +1333,9 @@
%mutable;
#endif
int renderer;
+#ifndef SWIG
int size;
+#endif
#ifndef SWIG
union {
More information about the mapserver-commits
