[mapserver-commits] r7190 - trunk/mapserver
Wed Dec 19 10:54:25 EST 2007
Author: Assefa
Date: 2007-12-19 10:54:25 -0500 (Wed, 19 Dec 2007)
New Revision: 7190
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapogcsld.c
SLD using a single BBOX filter should generate an SQL ststement for oracle/postgis/ogr (#2450)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2007-12-19 15:25:07 UTC (rev 7189)
+++ trunk/mapserver/HISTORY.TXT	2007-12-19 15:54:25 UTC (rev 7190)
@@ -13,6 +13,9 @@
 Current Version (5.1-dev, SVN trunk):
+- SLD using a single BBOX filter should generate an SQL ststement for
+  oracle/postgis/ogr (#2450)
 - Accurate Calculation of legend size for WMS LegendURL (#2435)
 - Converted mapogr.cpp to use OGR C API instead of C++ classes to allow
Modified: trunk/mapserver/mapogcsld.c
--- trunk/mapserver/mapogcsld.c	2007-12-19 15:25:07 UTC (rev 7189)
+++ trunk/mapserver/mapogcsld.c	2007-12-19 15:54:25 UTC (rev 7190)
@@ -141,7 +141,7 @@
     const char *pszTmp = NULL;
     int bFreeTemplate = 0;
     int nLayerStatus = 0;
-    //const char *pszSLDNotSupported = NULL;
+    /*const char *pszSLDNotSupported = NULL;*/
     pasLayers = msSLDParseSLD(map, psSLDXML, &nLayers);
@@ -300,8 +300,6 @@
                         nLayerStatus =  GET_LAYER(map, i)->status;
                         GET_LAYER(map, i)->status = MS_ON;
-                        //FLTApplySpatialFilterToLayer(psNode, map,
-                        //                           GET_LAYER(map, i)->index);
                         FLTApplyFilterToLayer(psNode, map,
                                               GET_LAYER(map, i)->index,
                                               !FLTIsSimpleFilter(psNode));
