[mapserver-commits] r7210 - in trunk/mapserver/mapscript: csharp
swiginc
svn at osgeo.org
svn at osgeo.org
Sun Dec 23 15:41:38 EST 2007
Author: tamas
Date: 2007-12-23 15:41:38 -0500 (Sun, 23 Dec 2007)
New Revision: 7210
trunk/mapserver/mapscript/csharp/csmodule.i
trunk/mapserver/mapscript/csharp/swig_csharp_extensions.i
trunk/mapserver/mapscript/swiginc/class.i
trunk/mapserver/mapscript/swiginc/layer.i
trunk/mapserver/mapscript/swiginc/map.i
Added %typemap(csin) SWIGTYPE *SETREFERENCE and fixed the RFC-24 test failures. (#2442)
Modified: trunk/mapserver/mapscript/csharp/csmodule.i
--- trunk/mapserver/mapscript/csharp/csmodule.i 2007-12-23 20:29:33 UTC (rev 7209)
+++ trunk/mapserver/mapscript/csharp/csmodule.i 2007-12-23 20:41:38 UTC (rev 7210)
@@ -328,7 +328,7 @@
* with parent objects (causing nullreference exception, Bug 1743)
-%typemap(csconstruct, excode=SWIGEXCODE) layerObj(mapObj map) %{: this($imcall, true , map) {
+%typemap(csconstruct, excode=SWIGEXCODE) layerObj(mapObj map) %{: this($imcall, true, map) {
$excode
Modified: trunk/mapserver/mapscript/csharp/swig_csharp_extensions.i
--- trunk/mapserver/mapscript/csharp/swig_csharp_extensions.i 2007-12-23 20:29:33 UTC (rev 7209)
+++ trunk/mapserver/mapscript/csharp/swig_csharp_extensions.i 2007-12-23 20:41:38 UTC (rev 7210)
@@ -1,6 +1,6 @@
- * $Id: swig_csharp_extensions.i 10898 2007-03-08 21:17:42Z tamas $
+ * $Id: $
* Name: swig_csharp_extensions.i
* Purpose: Fix for the SWIG Interface problems (early GC)
@@ -58,10 +58,28 @@
return (obj == null) ? new HandleRef(null, IntPtr.Zero) : obj.swigCPtr;
internal static HandleRef getCPtrAndDisown($csclassname obj, object parent) {
- obj.swigCMemOwn = false;
- obj.swigParentRef = parent;
- return getCPtr(obj);
+ if (obj != null)
+ obj.swigCMemOwn = false;
+ obj.swigParentRef = parent;
+ return obj.swigCPtr;
+ else
+ return new HandleRef(null, IntPtr.Zero);
+ internal static HandleRef getCPtrAndSetReference($csclassname obj, object parent) {
+ if (obj != null)
+ else
// Derived proxy classes
@@ -75,11 +93,29 @@
internal static HandleRef getCPtr($csclassname obj) {
- internal static HandleRef getCPtrAndDisown($csclassname obj, bool cMemoryOwn, object parent) {
- obj.swigCMemOwn = cMemoryOwn;
+ internal static HandleRef getCPtrAndDisown($csclassname obj, object parent) {
+ if (obj != null)
+ else
+ if (obj != null)
+ else
// Typewrapper classes
@@ -135,6 +171,7 @@
%typemap(csin) SWIGTYPE *DISOWN "$csclassname.getCPtrAndDisown($csinput, ThisOwn_false())"
+%typemap(csin) SWIGTYPE *SETREFERENCE "$csclassname.getCPtrAndSetReference($csinput, ThisOwn_false())"
%pragma(csharp) modulecode=%{
internal class $moduleObject : IDisposable {
Modified: trunk/mapserver/mapscript/swiginc/class.i
--- trunk/mapserver/mapscript/swiginc/class.i 2007-12-23 20:29:33 UTC (rev 7209)
+++ trunk/mapserver/mapscript/swiginc/class.i 2007-12-23 20:41:38 UTC (rev 7210)
@@ -193,7 +193,7 @@
#ifdef SWIGCSHARP
-%apply SWIGTYPE *DISOWN {styleObj *style};
+%apply SWIGTYPE *SETREFERENCE {styleObj *style};
#endif
int insertStyle(styleObj *style, int index=-1) {
return msInsertStyle(self, style, index);
Modified: trunk/mapserver/mapscript/swiginc/layer.i
--- trunk/mapserver/mapscript/swiginc/layer.i 2007-12-23 20:29:33 UTC (rev 7209)
+++ trunk/mapserver/mapscript/swiginc/layer.i 2007-12-23 20:41:38 UTC (rev 7210)
@@ -123,7 +123,7 @@
#ifdef SWIGCSHARP
-%apply SWIGTYPE *DISOWN {classObj *classobj};
+%apply SWIGTYPE *SETREFERENCE {classObj *classobj};
#endif
int insertClass(classObj *classobj, int index=-1)
Modified: trunk/mapserver/mapscript/swiginc/map.i
--- trunk/mapserver/mapscript/swiginc/map.i 2007-12-23 20:29:33 UTC (rev 7209)
+++ trunk/mapserver/mapscript/swiginc/map.i 2007-12-23 20:41:38 UTC (rev 7210)
@@ -64,7 +64,7 @@
#ifdef SWIGCSHARP
-%apply SWIGTYPE *DISOWN {layerObj *layer};
+%apply SWIGTYPE *SETREFERENCE {layerObj *layer};
#endif
int insertLayer(layerObj *layer, int index=-1)
More information about the mapserver-commits
