[mapserver-commits] r7219 - trunk/mapserver
Thu Dec 27 14:07:17 EST 2007
Author: sdlime
Date: 2007-12-27 14:07:17 -0500 (Thu, 27 Dec 2007)
New Revision: 7219
   trunk/mapserver/maptemplate.c
Updated template include tag to allow for tag processing in the included content.
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c	2007-12-27 16:48:12 UTC (rev 7218)
+++ trunk/mapserver/maptemplate.c	2007-12-27 19:07:17 UTC (rev 7219)
@@ -967,13 +967,13 @@
 ** TODO's:
 **   - Allow URLs.
-static int processInclude(mapObj *map, char **line)
+static int processInclude(mapservObj *ms, char **line, int mode)
   char *tag, *tagStart, *tagEnd;
   hashTableObj *tagArgs=NULL;
   int tagOffset, tagLength;
-  char *content=NULL, *src=NULL;
+  char *content=NULL, *processedContent=NULL, *src=NULL;
   FILE *stream;
   char buffer[MS_BUFFER_LENGTH], path[MS_MAXPATHLEN];
@@ -999,7 +999,7 @@
     if(!src) return(MS_SUCCESS); /* don't process the tag, could be something else so return MS_SUCCESS */
-    if((stream = fopen(msBuildPath(path, map->mappath, src), "r")) == NULL) {
+    if((stream = fopen(msBuildPath(path, ms->Map->mappath, src), "r")) == NULL) {
       msSetError(MS_IOERR, src, "processInclude()");
       return MS_FAILURE;
@@ -1017,13 +1017,18 @@
     strncpy(tag, tagStart, tagLength);
     tag[tagLength] = '\0';
+    /* process any tags in the content */
+    processedContent = processLine(ms, content, mode);
     /* do the replacement */
-    *line = msReplaceSubstring(*line, tag, content);
+    *line = msReplaceSubstring(*line, tag, processedContent);
     /* clean up */
     free(tag); tag = NULL;
     msFreeHashTable(tagArgs); tagArgs=NULL;
     free(content);
+    free(processedContent);
     if((*line)[tagOffset] != '\0')
       tagStart = findTag(*line+tagOffset+1, "include");
@@ -2984,7 +2989,7 @@
   } /* end query mode specific substitutions */
-  if(processInclude(msObj->Map, &outstr) != MS_SUCCESS)
+  if(processInclude(msObj, &outstr, mode) != MS_SUCCESS)
     return(NULL);
   for(i=0;i<msObj->request->NumParams;i++) {
