[mapserver-commits] r7231 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Dec 31 00:19:01 EST 2007
Author: sdlime
Date: 2007-12-31 00:19:00 -0500 (Mon, 31 Dec 2007)
New Revision: 7231
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapdraw.c
Fixed a bug with path following labels where in labels turned over to auto angle computations would use the position set in the mapfile rather than MS_CC. We needed to force ALL labels to MS_CC when ANGLE FOLLOW is set. (bug #2455)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2007-12-30 21:42:11 UTC (rev 7230)
+++ trunk/mapserver/HISTORY.TXT 2007-12-31 05:19:00 UTC (rev 7231)
@@ -13,6 +13,10 @@
Current Version (5.1-dev, SVN trunk):
+- fixed issue where path following labels sometimes used the supplied
+setting for position. In all cases with ANGLE FOLLOW we want to force
+position MS_CC regardless of what is set in the mapfile.
- enforce (-99 -99) to be the penup value for vector symbols (#1036)
- Support for labeling features (polygon & line) prior to clipping. This
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c 2007-12-30 21:42:11 UTC (rev 7230)
+++ trunk/mapserver/mapdraw.c 2007-12-31 05:19:00 UTC (rev 7231)
@@ -1400,19 +1400,15 @@
/* Bug #1620 implementation */
if ( layer->class[c]->label.autofollow == MS_TRUE ) {
+ layer->class[c]->label.position = MS_CC; /* Force all label positions to MS_CC regardless if a path is computed */
- /* Determine the label path iff it has not been computed above */
+ /* Determine the label path if it has not been computed above */
if(bLabelNoClip == MS_FALSE)
annopath = msPolylineLabelPath(shape, layer->class[c]->label.minfeaturesize, &(map->fontset), shape->text, &(layer->class[c]->label), layer->scalefactor, &status);
if( annopath ) {
labelObj label = layer->class[c]->label;
- /* Label path derived from line overrides the rotation and position
- values, so ignore the specified angle and set the position to
- auto. */
- label.position = MS_AUTO;
if(layer->labelcache) {
if(msAddLabel(map, layer->index, c, shape->index, shape->tileindex, NULL, annopath, shape->text, length, &label) != MS_SUCCESS) return(MS_FAILURE);
} else {
@@ -1617,6 +1613,7 @@
if(layer->class[c]->label.autofollow == MS_TRUE) {
if (bLabelNoClip == MS_FALSE)
@@ -1624,12 +1621,6 @@
if(annopath) {
- ** Label path derived from line overrides the rotation and position
- ** values, so ignore the specified angle and set the position to auto.
} else {
@@ -2113,100 +2104,82 @@
marker_rect.maxx = marker_rect.minx + (marker_width-1);
marker_rect.maxy = marker_rect.miny + (marker_height-1);
if(labelPtr->position == MS_AUTO) {
+ int first_pos, pos, last_pos;
- /* If we have a label path there are no alternate positions.
- Just check against the image boundaries, existing markers
- and existing labels. (Bug #1620) */
- if ( cachePtr->labelpath ) {
+ if(labelPtr->type == MS_LAYER_LINE) {
+ first_pos = MS_UC; /* There are three possible positions: UC, CC, LC */
+ last_pos = MS_CC;
+ } else {
+ first_pos = MS_UL; /* There are 8 possible outer positions: UL, LR, UR, LL, CR, CL, UC, LC */
+ last_pos = MS_LC;
- /* Assume label can be drawn */
- cachePtr->status = MS_TRUE;
+ for(pos = first_pos; pos <= last_pos; pos++) {
+ msFreeShape(cachePtr->poly);
+ cachePtr->status = MS_TRUE; /* assume label *can* be drawn */
- /* Copy the bounds into the cache's polygon */
- msCopyShape(&(cachePtr->labelpath->bounds), cachePtr->poly);
+ p = get_metrics(&(cachePtr->point), pos, r, (marker_offset_x + labelPtr->offsetx), (marker_offset_y + labelPtr->offsety), labelPtr->angle, labelPtr->buffer, cachePtr->poly);
+ if(layerPtr->type == MS_LAYER_ANNOTATION && cachePtr->numstyles > 0)
+ msRectToPolygon(marker_rect, cachePtr->poly); /* save marker bounding polygon */
- msFreeShape(&(cachePtr->labelpath->bounds));
+ /* Compare against image bounds, rendered labels and markers (sets cachePtr->status) */
+ msTestLabelCacheCollisions(&(map->labelcache), labelPtr, image->width, image->height,
+ labelPtr->buffer + map_edge_buffer, cachePtr, priority, l);
+ if(cachePtr->status) /* found a suitable place for this label */ {
+ if(MS_VALID_COLOR(labelPtr->backgroundcolor))
+ get_metrics_line(&(cachePtr->point), pos, r, (marker_offset_x + labelPtr->offsetx), (marker_offset_y + labelPtr->offsety), labelPtr->angle, 1, billboard.line);
+ break;
- /* Compare against image bounds, rendered labels and markers (sets cachePtr->status) */
- msTestLabelCacheCollisions(&(map->labelcache), labelPtr, image->width, image->height,
- labelPtr->buffer + map_edge_buffer, cachePtr, priority, l);
+ } /* next position */
- } else {
+ if(labelPtr->force) cachePtr->status = MS_TRUE; /* draw in spite of collisions based on last position, need a *best* position */
- /* We have a label point */
- int first_pos, pos, last_pos;
+ } else {
- if ( labelPtr->type == MS_LAYER_LINE ) {
- /* There are three possible positions: UC, CC, LC */
- first_pos = MS_UC;
- last_pos = MS_CC;
- } else {
- /* There are 8 possible outer positions: UL, LR, UR, LL, CR, CL, UC, LC */
- first_pos = MS_UL;
- last_pos = MS_LC;
- for(pos = first_pos; pos <= last_pos; pos++) {
- msFreeShape(cachePtr->poly);
- cachePtr->status = MS_TRUE; /* assume label *can* be drawn */
+ if(cachePtr->labelpath ) {
- p = get_metrics(&(cachePtr->point), pos, r, (marker_offset_x + labelPtr->offsetx), (marker_offset_y + labelPtr->offsety), labelPtr->angle, labelPtr->buffer, cachePtr->poly);
- if(layerPtr->type == MS_LAYER_ANNOTATION && cachePtr->numstyles > 0)
- msRectToPolygon(marker_rect, cachePtr->poly); /* save marker bounding polygon */
+ /* Copy the bounds into the cache's polygon */
+ msCopyShape(&(cachePtr->labelpath->bounds), cachePtr->poly);
+ msFreeShape(&(cachePtr->labelpath->bounds));
+ msTestLabelCacheCollisions(&(map->labelcache), labelPtr, image->width, image->height, labelPtr->buffer + map_edge_buffer, cachePtr, priority, l);
- if(cachePtr->status) /* found a suitable place for this label */ {
- if(MS_VALID_COLOR(labelPtr->backgroundcolor))
- get_metrics_line(&(cachePtr->point), pos, r, (marker_offset_x + labelPtr->offsetx), (marker_offset_y + labelPtr->offsety), labelPtr->angle, 1, billboard.line);
- break;
+ } else {
- } /* next position */
+ if(labelPtr->position == MS_CC) { /* don't need the marker_offset */
+ p = get_metrics(&(cachePtr->point), labelPtr->position, r, labelPtr->offsetx, labelPtr->offsety, labelPtr->angle, labelPtr->buffer, cachePtr->poly);
+ get_metrics_line(&(cachePtr->point), labelPtr->position, r, labelPtr->offsetx, labelPtr->offsety, labelPtr->angle, 1, billboard.line);
+ } else {
+ p = get_metrics(&(cachePtr->point), labelPtr->position, r, (marker_offset_x + labelPtr->offsetx), (marker_offset_y + labelPtr->offsety), labelPtr->angle, labelPtr->buffer, cachePtr->poly);
+ get_metrics_line(&(cachePtr->point), labelPtr->position, r, (marker_offset_x + labelPtr->offsetx), (marker_offset_y + labelPtr->offsety), labelPtr->angle, 1, billboard.line);
- if(labelPtr->force) cachePtr->status = MS_TRUE; /* draw in spite of collisions based on last position, need a *best* position */
- } else {
- if(labelPtr->position == MS_CC) {/* don't need the marker_offset */
- p = get_metrics(&(cachePtr->point), labelPtr->position, r, labelPtr->offsetx, labelPtr->offsety, labelPtr->angle, labelPtr->buffer, cachePtr->poly);
- get_metrics_line(&(cachePtr->point), labelPtr->position, r, labelPtr->offsetx, labelPtr->offsety, labelPtr->angle, 1, billboard.line);
- else{
- p = get_metrics(&(cachePtr->point), labelPtr->position, r, (marker_offset_x + labelPtr->offsetx), (marker_offset_y + labelPtr->offsety), labelPtr->angle, labelPtr->buffer, cachePtr->poly);
- get_metrics_line(&(cachePtr->point), labelPtr->position, r, (marker_offset_x + labelPtr->offsetx), (marker_offset_y + labelPtr->offsety), labelPtr->angle, 1, billboard.line);
- msRectToPolygon(marker_rect, cachePtr->poly); /* save marker bounding polygon, part of overlap tests */
+ msRectToPolygon(marker_rect, cachePtr->poly); /* save marker bounding polygon, part of overlap tests */
if(!labelPtr->force) { /* no need to check anything else */
} /* end position if-then-else */
/* imagePolyline(img, cachePtr->poly, 1, 0, 0); */
if(!cachePtr->status)
- continue; /* next label */
+ continue; /* next label */
if(layerPtr->type == MS_LAYER_ANNOTATION && cachePtr->numstyles > 0) { /* need to draw a marker */
- for(i=0; i<cachePtr->numstyles; i++)
- msDrawMarkerSymbol(&map->symbolset, image, &(cachePtr->point), &(cachePtr->styles[i]), layerPtr->scalefactor);
+ for(i=0; i<cachePtr->numstyles; i++)
+ msDrawMarkerSymbol(&map->symbolset, image, &(cachePtr->point), &(cachePtr->styles[i]), layerPtr->scalefactor);
if(MS_VALID_COLOR(labelPtr->backgroundcolor)) {
More information about the mapserver-commits
