[mapserver-commits] r7527 - trunk/mapserver/mapscript/java/examples
svn at osgeo.org
svn at osgeo.org
Fri Apr 25 17:05:12 EDT 2008
Author: warmerdam
Date: 2008-04-25 17:05:12 -0400 (Fri, 25 Apr 2008)
New Revision: 7527
trunk/mapserver/mapscript/java/examples/DrawMap.java
trunk/mapserver/mapscript/java/examples/DumpShp.java
trunk/mapserver/mapscript/java/examples/Metadata.java
trunk/mapserver/mapscript/java/examples/RunTimeBuiltWMSClient.java
trunk/mapserver/mapscript/java/examples/ShapeInfo.java
Avoid explicitly doing loadLibrary("mapscript") as it is already done
by the bindings, and it interferes with renaming of the library (#2595).
Modified: trunk/mapserver/mapscript/java/examples/DrawMap.java
--- trunk/mapserver/mapscript/java/examples/DrawMap.java 2008-04-21 08:31:48 UTC (rev 7526)
+++ trunk/mapserver/mapscript/java/examples/DrawMap.java 2008-04-25 21:05:12 UTC (rev 7527)
@@ -16,15 +16,6 @@
public static void main(String[] args) {
if (args.length != 2) usage();
- try
- System.loadLibrary("mapscript");
- catch(UnsatisfiedLinkError ule)
- System.err.println(ule);
- System.exit(-1);
mapObj map = new mapObj(args[0]);
//map.getImagecolor().setRGB(153, 153, 204);
Modified: trunk/mapserver/mapscript/java/examples/DumpShp.java
--- trunk/mapserver/mapscript/java/examples/DumpShp.java 2008-04-21 08:31:48 UTC (rev 7526)
+++ trunk/mapserver/mapscript/java/examples/DumpShp.java 2008-04-25 21:05:12 UTC (rev 7527)
@@ -27,15 +27,6 @@
if (args.length != 1) usage();
- try
- System.exit(-1);
shapefileObj shapefile = new shapefileObj (args[0],-1);
System.out.println ("Shapefile opened (type = " + getShapeType(shapefile.getType()) +
Modified: trunk/mapserver/mapscript/java/examples/Metadata.java
--- trunk/mapserver/mapscript/java/examples/Metadata.java 2008-04-21 08:31:48 UTC (rev 7526)
+++ trunk/mapserver/mapscript/java/examples/Metadata.java 2008-04-25 21:05:12 UTC (rev 7527)
@@ -16,15 +16,6 @@
- try
- System.exit(-1);
Modified: trunk/mapserver/mapscript/java/examples/RunTimeBuiltWMSClient.java
--- trunk/mapserver/mapscript/java/examples/RunTimeBuiltWMSClient.java 2008-04-21 08:31:48 UTC (rev 7526)
+++ trunk/mapserver/mapscript/java/examples/RunTimeBuiltWMSClient.java 2008-04-25 21:05:12 UTC (rev 7527)
@@ -9,8 +9,6 @@
public class RunTimeBuiltWMSClient {
- // Not needed anymore since mapserver 4.4.x
- //System.loadLibrary("mapscript");
System.out.println(mapscript.msGetVersion());
mapObj map;
webObj web;
Modified: trunk/mapserver/mapscript/java/examples/ShapeInfo.java
--- trunk/mapserver/mapscript/java/examples/ShapeInfo.java 2008-04-21 08:31:48 UTC (rev 7526)
+++ trunk/mapserver/mapscript/java/examples/ShapeInfo.java 2008-04-25 21:05:12 UTC (rev 7527)
@@ -31,15 +31,6 @@
- try
- System.exit(-1);
System.out.println ("Shapefile name = " + args[0]);
More information about the mapserver-commits
