[mapserver-commits] r7845 - in trunk/mapserver: . mapscript/doc mapscript/swiginc
Wed Aug 13 09:57:25 EDT 2008
Author: tamas
Date: 2008-08-13 09:57:24 -0400 (Wed, 13 Aug 2008)
New Revision: 7845
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapscript/doc/mapscript.txt
   trunk/mapserver/mapscript/swiginc/layer.i
Expose msConnectLayer to the SWIG mapscript interface (#2735)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-08-08 18:37:19 UTC (rev 7844)
+++ trunk/mapserver/HISTORY.TXT	2008-08-13 13:57:24 UTC (rev 7845)
@@ -12,6 +12,8 @@
 Current Version (5.3-dev, SVN trunk):
+- Expose msConnectLayer to the SWIG mapscript interface (#2735)
 - SLD: when creating well known symbols on the fly the pen-up value
   used should be -99.
Modified: trunk/mapserver/mapscript/doc/mapscript.txt
--- trunk/mapserver/mapscript/doc/mapscript.txt	2008-08-08 18:37:19 UTC (rev 7844)
+++ trunk/mapserver/mapscript/doc/mapscript.txt	2008-08-13 13:57:24 UTC (rev 7845)
@@ -1391,6 +1391,11 @@
 .. note:: demote() is removed in MapServer 4.4
+connectLayer(int connectiontype, string library_str) : int
+    Changes the connectiontype of the layer and recreates the vtable
+    according to the new connection type. This method should be used
+    instead of setting the connectiontype parameter directly.
 draw( mapObj_ map, imageObj_ image ) : int
     Renders this layer into the target image, adding labels to the cache if
     required.  Returns MS_SUCCESS or MS_FAILURE.
Modified: trunk/mapserver/mapscript/swiginc/layer.i
--- trunk/mapserver/mapscript/swiginc/layer.i	2008-08-08 18:37:19 UTC (rev 7844)
+++ trunk/mapserver/mapscript/swiginc/layer.i	2008-08-13 13:57:24 UTC (rev 7845)
@@ -544,5 +544,10 @@
         return msLayerClearProcessing(self);
+    int connectLayer(int connectiontype,
+                            char *library_str)
+        return msConnectLayer(self, connectiontype, library_str);
