[mapserver-commits] r7861 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Aug 15 13:34:35 EDT 2008
Author: tamas
Date: 2008-08-15 13:34:35 -0400 (Fri, 15 Aug 2008)
New Revision: 7861
trunk/mapserver/nmake.opt
- Added MS_DEBUG to switch between the debug and the optimized configuration
- Added BGDWIN32 required by gd-2.0.35
- Allow to specify EXTERNAL_LIBS and INCLUDES externally
Modified: trunk/mapserver/nmake.opt
--- trunk/mapserver/nmake.opt 2008-08-15 12:19:00 UTC (rev 7860)
+++ trunk/mapserver/nmake.opt 2008-08-15 17:34:35 UTC (rev 7861)
@@ -88,18 +88,24 @@
!IF $(MSVC_VER) == 1400
+!IFNDEF MS_DEBUG
# Optimized, with using MSVCRT.
OPTFLAGS = /nologo /Ox /MD $(WARNING_LEVEL) $(DEBUG) /EHsc /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE
+!ELSE
# Debug with MSVCRT
-#OPTFLAGS = /nologo /Zi /MD $(WARNING_LEVEL) $(DEBUG) /EHsc /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE
+OPTFLAGS = /nologo /Zi /MD $(WARNING_LEVEL) $(DEBUG) /EHsc /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE
#LDFLAGS = /NODEFAULTLIB:msvcrt /NODEFAULTLIB:libcd /DEBUG
+!ENDIF
!ELSE
+!IFNDEF MS_DEBUG
+!ELSE
# Debug with MSVCRT
-#OPTFLAGS = /nologo /Zi /MDd $(WARNING_LEVEL) $(DEBUG) /EHsc
+OPTFLAGS = /nologo /Zi /MDd $(WARNING_LEVEL) $(DEBUG) /EHsc
!ENDIF
+!ENDIF
# Uncomment the following to link mapserv.exe with a dll. In almost
# all cases you will want to do this.
@@ -111,6 +117,7 @@
# Debugging Options
+!IFDEF MS_DEBUG
#NEED_NONBLOCKING_STDERR=-DNEED_NONBLOCKING_STDERR
ENABLE_STDERR_DEBUG=-DENABLE_STDERR_DEBUG
@@ -120,6 +127,7 @@
# DEBUG Build flags
# Set the DEBUG flag if you wish to make a debug build
DEBUG=/DDEBUG
+!ENDIF
# String methods
@@ -794,22 +802,26 @@
# Should not need to be updated.
+!IFNDEF EXTERNAL_LIBS
EXTERNAL_LIBS=$(GD_LIBS) $(TIFF_LIB) $(JPEG_LIB) \
$(PROJ_LIB) $(OGR_LIB) $(GDAL_LIB)\
$(CURL_LIB) $(MING_LIB) $(PDF_LIB) \
$(WINSOCK_LIB) $(POSTGIS_LIB) $(IMGGEN_LIB) $(ERR_LIB) \
$(ORACLE_LIB) $(SDE_LIB) $(ICONV_LIB) $(FCGILIB) $(GEOS_LIB) \
$(LIBXML_LIB) $(AGG_LIB) $(FRIBIDI_LIB)
+!ENDIF
LIBS=$(MS_LIB) $(EXTERNAL_LIBS)
LIBS_DLL=$(MS_LIB_DLL) $(EXTERNAL_LIBS)
+!IFNDEF INCLUDES
INCLUDES=$(GD_INC) $(TIFF_INC) $(JPEG_INC) \
$(PROJ_INC) $(REGEX_INC) $(GDAL_INC) $(OGR_INC) \
$(CURL_INC) $(MING_INC) $(PDF_INC) $(POSTGIS_INC) \
$(IMGGEN_INC) $(ERR_INC) $(ORACLE_INC) $(SDE_INC)\
$(ICONV_INC) $(FCGIINC) $(GEOS_INC) $(ZLIB_INC) $(LIBXML_INC) \
$(AGG_INC) $(PNG_INC) $(FRIBIDI_INC)
+!ENDIF
MS_DEFS = $(REGEX_OPT) $(STRINGS) $(POSTGIS) \
@@ -822,9 +834,9 @@
$(SDE_OPT) $(ICONV) $(GEOS) $(ZLIB) $(SOS) $(XML2_ENABLED) $(AGG) $(RGBA_PNG_ENABLED) $(FRIBIDI)
!IFDEF WIN64
-MS_CFLAGS=$(INCLUDES) $(MS_DEFS) -DWIN32 -D_WIN32 -DUSE_GENERIC_MS_NINT
+MS_CFLAGS=$(INCLUDES) $(MS_DEFS) -DWIN32 -D_WIN32 -DUSE_GENERIC_MS_NINT -DBGDWIN32
!ELSE
+MS_CFLAGS=$(INCLUDES) $(MS_DEFS) -DWIN32 -D_WIN32 -DBGDWIN32
!ENDIF
More information about the mapserver-commits
