[mapserver-commits] r7872 - branches/branch-5-2/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Aug 20 08:31:56 EDT 2008
Author: dmorissette
Date: 2008-08-20 08:31:56 -0400 (Wed, 20 Aug 2008)
New Revision: 7872
branches/branch-5-2/mapserver/maplexer.c
New maplexer.c for maplexer.l r7868 (#2729)
Modified: branches/branch-5-2/mapserver/maplexer.c
--- branches/branch-5-2/mapserver/maplexer.c 2008-08-20 03:57:24 UTC (rev 7871)
+++ branches/branch-5-2/mapserver/maplexer.c 2008-08-20 12:31:56 UTC (rev 7872)
@@ -1648,6 +1648,7 @@
break;
case(MS_TOKENIZE_STRING):
BEGIN(INITIAL);
+ msyy_delete_buffer(YY_CURRENT_BUFFER);
msyysource=MS_STRING_TOKENS;
msyystate=MS_TOKENIZE_DEFAULT;
msyy_scan_string(msyystring);
@@ -1658,6 +1659,7 @@
break;
case(MS_TOKENIZE_URL_VARIABLE):
BEGIN(URL_VARIABLE);
msyysource=MS_URL_TOKENS;
@@ -1666,6 +1668,7 @@
break;
case(MS_TOKENIZE_URL_STRING):
BEGIN(URL_STRING);
@@ -1692,7 +1695,7 @@
break;
-#line 1696 "maplexer.c"
+#line 1699 "maplexer.c"
if ( !(yy_init) )
@@ -1777,62 +1780,62 @@
case 1:
YY_RULE_SETUP
-#line 112 "maplexer.l"
+#line 115 "maplexer.l"
YY_BREAK
case 2:
YY_RULE_SETUP
-#line 114 "maplexer.l"
+#line 117 "maplexer.l"
{ if (msyyreturncomments) return(MS_COMMENT); }
YY_BREAK
case 3:
YY_RULE_SETUP
-#line 116 "maplexer.l"
+#line 119 "maplexer.l"
YY_BREAK
case 4:
YY_RULE_SETUP
-#line 118 "maplexer.l"
+#line 121 "maplexer.l"
{ return(OR); }
YY_BREAK
case 5:
YY_RULE_SETUP
-#line 119 "maplexer.l"
+#line 122 "maplexer.l"
{ return(AND); }
YY_BREAK
case 6:
YY_RULE_SETUP
-#line 120 "maplexer.l"
+#line 123 "maplexer.l"
{ return(EQ); }
YY_BREAK
case 7:
YY_RULE_SETUP
-#line 121 "maplexer.l"
+#line 124 "maplexer.l"
{ return(NE); }
YY_BREAK
case 8:
YY_RULE_SETUP
-#line 122 "maplexer.l"
+#line 125 "maplexer.l"
{ return(GT); }
YY_BREAK
case 9:
YY_RULE_SETUP
-#line 123 "maplexer.l"
+#line 126 "maplexer.l"
{ return(LT); }
YY_BREAK
case 10:
YY_RULE_SETUP
-#line 124 "maplexer.l"
+#line 127 "maplexer.l"
{ return(GE); }
YY_BREAK
case 11:
YY_RULE_SETUP
-#line 125 "maplexer.l"
+#line 128 "maplexer.l"
{ return(LE); }
YY_BREAK
case 12:
YY_RULE_SETUP
-#line 126 "maplexer.l"
+#line 129 "maplexer.l"
BEGIN(EXPRESSION_STRING_REGEX);
return(RE);
@@ -1840,1247 +1843,1247 @@
YY_BREAK
case 13:
YY_RULE_SETUP
-#line 130 "maplexer.l"
+#line 133 "maplexer.l"
{ return(IN); }
YY_BREAK
case 14:
YY_RULE_SETUP
-#line 131 "maplexer.l"
+#line 134 "maplexer.l"
{ return(NOT); }
YY_BREAK
case 15:
YY_RULE_SETUP
-#line 133 "maplexer.l"
+#line 136 "maplexer.l"
{ return(LENGTH); }
YY_BREAK
case 16:
YY_RULE_SETUP
-#line 134 "maplexer.l"
+#line 137 "maplexer.l"
{ return(IEQ); }
YY_BREAK
case 17:
YY_RULE_SETUP
-#line 136 "maplexer.l"
+#line 139 "maplexer.l"
{ return(COLORRANGE); }
YY_BREAK
case 18:
YY_RULE_SETUP
-#line 137 "maplexer.l"
+#line 140 "maplexer.l"
{ return(ALPHACOLORRANGE); }
YY_BREAK
case 19:
YY_RULE_SETUP
-#line 138 "maplexer.l"
+#line 141 "maplexer.l"
{ return(DATARANGE); }
YY_BREAK
case 20:
YY_RULE_SETUP
-#line 139 "maplexer.l"
+#line 142 "maplexer.l"
{ return(RANGEITEM); }
YY_BREAK
case 21:
YY_RULE_SETUP
-#line 141 "maplexer.l"
+#line 144 "maplexer.l"
{ return(ALIGN); }
YY_BREAK
case 22:
YY_RULE_SETUP
-#line 142 "maplexer.l"
+#line 145 "maplexer.l"
{ return(ALPHACOLOR); }
YY_BREAK
case 23:
YY_RULE_SETUP
-#line 143 "maplexer.l"
+#line 146 "maplexer.l"
{ return(ANGLE); }
YY_BREAK
case 24:
YY_RULE_SETUP
-#line 144 "maplexer.l"
+#line 147 "maplexer.l"
{ return(ANTIALIAS); }
YY_BREAK
case 25:
YY_RULE_SETUP
-#line 145 "maplexer.l"
+#line 148 "maplexer.l"
{ return(BACKGROUNDCOLOR); }
YY_BREAK
case 26:
YY_RULE_SETUP
-#line 146 "maplexer.l"
+#line 149 "maplexer.l"
{ return(BACKGROUNDSHADOWCOLOR); }
YY_BREAK
case 27:
YY_RULE_SETUP
-#line 147 "maplexer.l"
+#line 150 "maplexer.l"
{ return(BACKGROUNDSHADOWSIZE); }
YY_BREAK
case 28:
YY_RULE_SETUP
-#line 148 "maplexer.l"
+#line 151 "maplexer.l"
{ return(BANDSITEM); }
YY_BREAK
case 29:
YY_RULE_SETUP
-#line 149 "maplexer.l"
+#line 152 "maplexer.l"
{ return(BROWSEFORMAT); }
YY_BREAK
case 30:
YY_RULE_SETUP
-#line 150 "maplexer.l"
+#line 153 "maplexer.l"
{ return(BUFFER); }
YY_BREAK
case 31:
YY_RULE_SETUP
-#line 151 "maplexer.l"
+#line 154 "maplexer.l"
{ return(CHARACTER); }
YY_BREAK
case 32:
YY_RULE_SETUP
-#line 152 "maplexer.l"
+#line 155 "maplexer.l"
{ return(CLASS); }
YY_BREAK
case 33:
YY_RULE_SETUP
-#line 153 "maplexer.l"
+#line 156 "maplexer.l"
{ return(CLASSITEM); }
YY_BREAK
case 34:
YY_RULE_SETUP
-#line 154 "maplexer.l"
+#line 157 "maplexer.l"
{ return(CLASSGROUP); }
YY_BREAK
case 35:
YY_RULE_SETUP
-#line 155 "maplexer.l"
+#line 158 "maplexer.l"
{ return(COLOR); }
YY_BREAK
case 36:
YY_RULE_SETUP
-#line 156 "maplexer.l"
+#line 159 "maplexer.l"
{ return(CONFIG); }
YY_BREAK
case 37:
YY_RULE_SETUP
-#line 157 "maplexer.l"
+#line 160 "maplexer.l"
{ return(CONNECTION); }
YY_BREAK
case 38:
YY_RULE_SETUP
-#line 158 "maplexer.l"
+#line 161 "maplexer.l"
{ return(CONNECTIONTYPE); }
YY_BREAK
case 39:
YY_RULE_SETUP
-#line 159 "maplexer.l"
+#line 162 "maplexer.l"
{ return(DATA); }
YY_BREAK
case 40:
YY_RULE_SETUP
-#line 160 "maplexer.l"
+#line 163 "maplexer.l"
{ return(DATAPATTERN); }
YY_BREAK
case 41:
YY_RULE_SETUP
-#line 161 "maplexer.l"
+#line 164 "maplexer.l"
{ return(DEBUG); }
YY_BREAK
case 42:
YY_RULE_SETUP
-#line 162 "maplexer.l"
+#line 165 "maplexer.l"
{ return(DRIVER); }
YY_BREAK
case 43:
YY_RULE_SETUP
-#line 163 "maplexer.l"
+#line 166 "maplexer.l"
{ return(DUMP); }
YY_BREAK
case 44:
YY_RULE_SETUP
-#line 164 "maplexer.l"
+#line 167 "maplexer.l"
{ return(EMPTY); }
YY_BREAK
case 45:
YY_RULE_SETUP
-#line 165 "maplexer.l"
+#line 168 "maplexer.l"
{ return(ENCODING); }
YY_BREAK
case 46:
YY_RULE_SETUP
-#line 166 "maplexer.l"
+#line 169 "maplexer.l"
{ return(END); }
YY_BREAK
case 47:
YY_RULE_SETUP
-#line 167 "maplexer.l"
+#line 170 "maplexer.l"
{ return(ERROR); }
YY_BREAK
case 48:
YY_RULE_SETUP
-#line 168 "maplexer.l"
+#line 171 "maplexer.l"
{ return(EXPRESSION); }
YY_BREAK
case 49:
YY_RULE_SETUP
-#line 169 "maplexer.l"
+#line 172 "maplexer.l"
{ return(EXTENT); }
YY_BREAK
case 50:
YY_RULE_SETUP
-#line 170 "maplexer.l"
+#line 173 "maplexer.l"
{ return(EXTENSION); }
YY_BREAK
case 51:
YY_RULE_SETUP
-#line 171 "maplexer.l"
+#line 174 "maplexer.l"
{ return(FEATURE); }
YY_BREAK
case 52:
YY_RULE_SETUP
-#line 172 "maplexer.l"
+#line 175 "maplexer.l"
{ return(FILLED); }
YY_BREAK
case 53:
YY_RULE_SETUP
-#line 173 "maplexer.l"
+#line 176 "maplexer.l"
{ return(FILTER); }
YY_BREAK
case 54:
YY_RULE_SETUP
-#line 174 "maplexer.l"
+#line 177 "maplexer.l"
{ return(FILTERITEM); }
YY_BREAK
case 55:
YY_RULE_SETUP
-#line 175 "maplexer.l"
+#line 178 "maplexer.l"
{ return(FOOTER); }
YY_BREAK
case 56:
YY_RULE_SETUP
-#line 176 "maplexer.l"
+#line 179 "maplexer.l"
{ return(FONT); }
YY_BREAK
case 57:
YY_RULE_SETUP
-#line 177 "maplexer.l"
+#line 180 "maplexer.l"
{ return(FONTSET); }
YY_BREAK
case 58:
YY_RULE_SETUP
-#line 178 "maplexer.l"
+#line 181 "maplexer.l"
{ return(FORCE); }
YY_BREAK
case 59:
YY_RULE_SETUP
-#line 179 "maplexer.l"
+#line 182 "maplexer.l"
{ return(FORMATOPTION); }
YY_BREAK
case 60:
YY_RULE_SETUP
-#line 180 "maplexer.l"
+#line 183 "maplexer.l"
{ return(FROM); }
YY_BREAK
case 61:
YY_RULE_SETUP
-#line 181 "maplexer.l"
+#line 184 "maplexer.l"
{ return(GAP); }
YY_BREAK
case 62:
YY_RULE_SETUP
-#line 182 "maplexer.l"
+#line 185 "maplexer.l"
{ return(GRID); }
YY_BREAK
case 63:
YY_RULE_SETUP
-#line 183 "maplexer.l"
+#line 186 "maplexer.l"
{ return(GRATICULE); }
YY_BREAK
case 64:
YY_RULE_SETUP
-#line 184 "maplexer.l"
+#line 187 "maplexer.l"
{ return(GROUP); }
YY_BREAK
case 65:
YY_RULE_SETUP
-#line 185 "maplexer.l"
+#line 188 "maplexer.l"
{ return(HEADER); }
YY_BREAK
case 66:
YY_RULE_SETUP
-#line 186 "maplexer.l"
+#line 189 "maplexer.l"
{ return(IMAGE); }
YY_BREAK
case 67:
YY_RULE_SETUP
-#line 187 "maplexer.l"
+#line 190 "maplexer.l"
{ return(IMAGECOLOR); }
YY_BREAK
case 68:
YY_RULE_SETUP
-#line 188 "maplexer.l"
+#line 191 "maplexer.l"
{ return(IMAGETYPE); }
YY_BREAK
case 69:
YY_RULE_SETUP
-#line 189 "maplexer.l"
+#line 192 "maplexer.l"
{ return(IMAGEQUALITY); }
YY_BREAK
case 70:
YY_RULE_SETUP
-#line 190 "maplexer.l"
+#line 193 "maplexer.l"
{ return(IMAGEMODE); }
YY_BREAK
case 71:
YY_RULE_SETUP
-#line 191 "maplexer.l"
+#line 194 "maplexer.l"
{ return(IMAGEPATH); }
YY_BREAK
case 72:
YY_RULE_SETUP
-#line 192 "maplexer.l"
+#line 195 "maplexer.l"
{ return(IMAGEURL); }
YY_BREAK
case 73:
YY_RULE_SETUP
-#line 193 "maplexer.l"
+#line 196 "maplexer.l"
{ BEGIN(INCLUDE); }
YY_BREAK
case 74:
YY_RULE_SETUP
-#line 194 "maplexer.l"
+#line 197 "maplexer.l"
{ return(INDEX); }
YY_BREAK
case 75:
YY_RULE_SETUP
-#line 195 "maplexer.l"
+#line 198 "maplexer.l"
{ return(INTERLACE); }
YY_BREAK
case 76:
YY_RULE_SETUP
-#line 196 "maplexer.l"
+#line 199 "maplexer.l"
{ return(INTERVALS); }
YY_BREAK
case 77:
YY_RULE_SETUP
-#line 197 "maplexer.l"
+#line 200 "maplexer.l"
{ return(JOIN); }
YY_BREAK
case 78:
YY_RULE_SETUP
-#line 198 "maplexer.l"
+#line 201 "maplexer.l"
{ return(KEYIMAGE); }
YY_BREAK
case 79:
YY_RULE_SETUP
-#line 199 "maplexer.l"
+#line 202 "maplexer.l"
{ return(KEYSIZE); }
YY_BREAK
case 80:
YY_RULE_SETUP
-#line 200 "maplexer.l"
+#line 203 "maplexer.l"
{ return(KEYSPACING); }
YY_BREAK
case 81:
YY_RULE_SETUP
-#line 201 "maplexer.l"
+#line 204 "maplexer.l"
{ return(LABEL); }
YY_BREAK
case 82:
YY_RULE_SETUP
-#line 202 "maplexer.l"
+#line 205 "maplexer.l"
{ return(LABELCACHE); }
YY_BREAK
case 83:
YY_RULE_SETUP
-#line 203 "maplexer.l"
+#line 206 "maplexer.l"
{ return(LABELFORMAT); }
YY_BREAK
case 84:
YY_RULE_SETUP
-#line 204 "maplexer.l"
+#line 207 "maplexer.l"
{ return(LABELITEM); }
YY_BREAK
case 85:
YY_RULE_SETUP
-#line 205 "maplexer.l"
+#line 208 "maplexer.l"
{ return(LABELMAXSCALE); }
YY_BREAK
case 86:
YY_RULE_SETUP
-#line 206 "maplexer.l"
+#line 209 "maplexer.l"
{ return(LABELMAXSCALEDENOM); }
YY_BREAK
case 87:
YY_RULE_SETUP
-#line 207 "maplexer.l"
+#line 210 "maplexer.l"
{ return(LABELMINSCALE); }
YY_BREAK
case 88:
YY_RULE_SETUP
-#line 208 "maplexer.l"
+#line 211 "maplexer.l"
{ return(LABELMINSCALEDENOM); }
YY_BREAK
case 89:
YY_RULE_SETUP
-#line 209 "maplexer.l"
+#line 212 "maplexer.l"
{ return(LABELREQUIRES); }
YY_BREAK
case 90:
YY_RULE_SETUP
-#line 210 "maplexer.l"
+#line 213 "maplexer.l"
{ return(LATLON); }
YY_BREAK
case 91:
YY_RULE_SETUP
-#line 211 "maplexer.l"
+#line 214 "maplexer.l"
{ return(LAYER); }
YY_BREAK
case 92:
YY_RULE_SETUP
-#line 212 "maplexer.l"
+#line 215 "maplexer.l"
{ return(LEGEND); }
YY_BREAK
case 93:
YY_RULE_SETUP
-#line 213 "maplexer.l"
+#line 216 "maplexer.l"
{ return(LEGENDFORMAT); }
YY_BREAK
case 94:
YY_RULE_SETUP
-#line 214 "maplexer.l"
+#line 217 "maplexer.l"
{ return(LINECAP); }
YY_BREAK
case 95:
YY_RULE_SETUP
-#line 215 "maplexer.l"
+#line 218 "maplexer.l"
{ return(LINEJOIN); }
YY_BREAK
case 96:
YY_RULE_SETUP
-#line 216 "maplexer.l"
+#line 219 "maplexer.l"
{ return(LINEJOINMAXSIZE); }
YY_BREAK
case 97:
YY_RULE_SETUP
-#line 217 "maplexer.l"
+#line 220 "maplexer.l"
{ return(LOG); }
YY_BREAK
case 98:
YY_RULE_SETUP
-#line 218 "maplexer.l"
+#line 221 "maplexer.l"
{ return(MAP); }
YY_BREAK
case 99:
YY_RULE_SETUP
-#line 219 "maplexer.l"
+#line 222 "maplexer.l"
{ return(MARKER); }
YY_BREAK
case 100:
YY_RULE_SETUP
-#line 220 "maplexer.l"
+#line 223 "maplexer.l"
{ return(MARKERSIZE); }
YY_BREAK
case 101:
YY_RULE_SETUP
-#line 221 "maplexer.l"
+#line 224 "maplexer.l"
{ return(MAXARCS); }
YY_BREAK
case 102:
YY_RULE_SETUP
-#line 222 "maplexer.l"
+#line 225 "maplexer.l"
{ return(MAXBOXSIZE); }
YY_BREAK
case 103:
YY_RULE_SETUP
-#line 223 "maplexer.l"
+#line 226 "maplexer.l"
{ return(MAXFEATURES); }
YY_BREAK
case 104:
YY_RULE_SETUP
-#line 224 "maplexer.l"
+#line 227 "maplexer.l"
{ return(MAXINTERVAL); }
YY_BREAK
case 105:
YY_RULE_SETUP
-#line 225 "maplexer.l"
+#line 228 "maplexer.l"
{ return(MAXSCALE); }
YY_BREAK
case 106:
YY_RULE_SETUP
-#line 226 "maplexer.l"
+#line 229 "maplexer.l"
{ return(MAXSCALEDENOM); }
YY_BREAK
case 107:
YY_RULE_SETUP
-#line 227 "maplexer.l"
+#line 230 "maplexer.l"
{ return(MAXSIZE); }
YY_BREAK
case 108:
YY_RULE_SETUP
-#line 228 "maplexer.l"
+#line 231 "maplexer.l"
{ return(MAXSUBDIVIDE); }
YY_BREAK
case 109:
YY_RULE_SETUP
-#line 229 "maplexer.l"
+#line 232 "maplexer.l"
{ return(MAXTEMPLATE); }
YY_BREAK
case 110:
YY_RULE_SETUP
-#line 230 "maplexer.l"
+#line 233 "maplexer.l"
{ return(MAXWIDTH); }
YY_BREAK
case 111:
YY_RULE_SETUP
-#line 231 "maplexer.l"
+#line 234 "maplexer.l"
{ return(METADATA); }
YY_BREAK
case 112:
YY_RULE_SETUP
-#line 232 "maplexer.l"
+#line 235 "maplexer.l"
{ return(MIMETYPE); }
YY_BREAK
case 113:
YY_RULE_SETUP
-#line 233 "maplexer.l"
+#line 236 "maplexer.l"
{ return(MINARCS); }
YY_BREAK
case 114:
YY_RULE_SETUP
-#line 234 "maplexer.l"
+#line 237 "maplexer.l"
{ return(MINBOXSIZE); }
YY_BREAK
case 115:
YY_RULE_SETUP
-#line 235 "maplexer.l"
+#line 238 "maplexer.l"
{ return(MINDISTANCE); }
YY_BREAK
case 116:
YY_RULE_SETUP
-#line 236 "maplexer.l"
+#line 239 "maplexer.l"
{ return(MINFEATURESIZE); }
YY_BREAK
case 117:
YY_RULE_SETUP
-#line 237 "maplexer.l"
+#line 240 "maplexer.l"
{ return(MININTERVAL); }
YY_BREAK
case 118:
YY_RULE_SETUP
-#line 238 "maplexer.l"
+#line 241 "maplexer.l"
{ return(MINSCALE); }
YY_BREAK
case 119:
YY_RULE_SETUP
-#line 239 "maplexer.l"
+#line 242 "maplexer.l"
{ return(MINSCALEDENOM); }
YY_BREAK
case 120:
YY_RULE_SETUP
-#line 240 "maplexer.l"
+#line 243 "maplexer.l"
{ return(MINSIZE); }
YY_BREAK
case 121:
YY_RULE_SETUP
-#line 241 "maplexer.l"
+#line 244 "maplexer.l"
{ return(MINSUBDIVIDE); }
YY_BREAK
case 122:
YY_RULE_SETUP
-#line 242 "maplexer.l"
+#line 245 "maplexer.l"
{ return(MINTEMPLATE); }
YY_BREAK
case 123:
YY_RULE_SETUP
-#line 243 "maplexer.l"
+#line 246 "maplexer.l"
{ return(MINWIDTH); }
YY_BREAK
case 124:
YY_RULE_SETUP
-#line 244 "maplexer.l"
+#line 247 "maplexer.l"
{ return(NAME); }
YY_BREAK
case 125:
YY_RULE_SETUP
-#line 245 "maplexer.l"
+#line 248 "maplexer.l"
{ return(OFFSET); }
YY_BREAK
case 126:
YY_RULE_SETUP
-#line 246 "maplexer.l"
+#line 249 "maplexer.l"
{ return(OFFSITE); }
YY_BREAK
case 127:
YY_RULE_SETUP
-#line 247 "maplexer.l"
+#line 250 "maplexer.l"
{ return(OPACITY); }
YY_BREAK
case 128:
YY_RULE_SETUP
-#line 248 "maplexer.l"
+#line 251 "maplexer.l"
{ return(OUTLINECOLOR); }
YY_BREAK
case 129:
YY_RULE_SETUP
-#line 249 "maplexer.l"
+#line 252 "maplexer.l"
{ return(OUTLINEWIDTH); }
YY_BREAK
case 130:
YY_RULE_SETUP
-#line 250 "maplexer.l"
+#line 253 "maplexer.l"
{ return(OUTPUTFORMAT); }
YY_BREAK
case 131:
YY_RULE_SETUP
-#line 251 "maplexer.l"
+#line 254 "maplexer.l"
{ return(OVERLAYBACKGROUNDCOLOR); }
YY_BREAK
case 132:
YY_RULE_SETUP
-#line 252 "maplexer.l"
+#line 255 "maplexer.l"
{ return(OVERLAYCOLOR); }
YY_BREAK
case 133:
YY_RULE_SETUP
-#line 253 "maplexer.l"
+#line 256 "maplexer.l"
{ return(OVERLAYMAXSIZE); }
YY_BREAK
case 134:
YY_RULE_SETUP
-#line 254 "maplexer.l"
+#line 257 "maplexer.l"
{ return(OVERLAYMINSIZE); }
YY_BREAK
case 135:
YY_RULE_SETUP
-#line 255 "maplexer.l"
+#line 258 "maplexer.l"
{ return(OVERLAYOUTLINECOLOR); }
YY_BREAK
case 136:
YY_RULE_SETUP
-#line 256 "maplexer.l"
+#line 259 "maplexer.l"
{ return(OVERLAYSIZE); }
YY_BREAK
case 137:
YY_RULE_SETUP
-#line 257 "maplexer.l"
+#line 260 "maplexer.l"
{ return(OVERLAYSYMBOL); }
YY_BREAK
case 138:
YY_RULE_SETUP
-#line 258 "maplexer.l"
+#line 261 "maplexer.l"
{ return(PARTIALS); }
YY_BREAK
case 139:
YY_RULE_SETUP
-#line 259 "maplexer.l"
+#line 262 "maplexer.l"
{ return(PATTERN); }
YY_BREAK
case 140:
YY_RULE_SETUP
-#line 260 "maplexer.l"
+#line 263 "maplexer.l"
{ return(POINTS); }
YY_BREAK
case 141:
YY_RULE_SETUP
-#line 261 "maplexer.l"
+#line 264 "maplexer.l"
{ return(POSITION); }
YY_BREAK
case 142:
YY_RULE_SETUP
-#line 262 "maplexer.l"
+#line 265 "maplexer.l"
{ return(POSTLABELCACHE); }
YY_BREAK
case 143:
YY_RULE_SETUP
-#line 263 "maplexer.l"
+#line 266 "maplexer.l"
{ return(PRIORITY); }
YY_BREAK
case 144:
YY_RULE_SETUP
-#line 264 "maplexer.l"
+#line 267 "maplexer.l"
{ return(PROCESSING); }
YY_BREAK
case 145:
YY_RULE_SETUP
-#line 265 "maplexer.l"
+#line 268 "maplexer.l"
{ return(PROJECTION); }
YY_BREAK
case 146:
YY_RULE_SETUP
-#line 266 "maplexer.l"
+#line 269 "maplexer.l"
{ return(QUERYFORMAT); }
YY_BREAK
case 147:
YY_RULE_SETUP
-#line 267 "maplexer.l"
+#line 270 "maplexer.l"
{ return(QUERYMAP); }
YY_BREAK
case 148:
YY_RULE_SETUP
-#line 268 "maplexer.l"
+#line 271 "maplexer.l"
{ return(REFERENCE); }
YY_BREAK
case 149:
YY_RULE_SETUP
-#line 269 "maplexer.l"
+#line 272 "maplexer.l"
{ return(RELATIVETO); }
YY_BREAK
case 150:
YY_RULE_SETUP
-#line 270 "maplexer.l"
+#line 273 "maplexer.l"
{ return(REQUIRES); }
YY_BREAK
case 151:
YY_RULE_SETUP
-#line 271 "maplexer.l"
+#line 274 "maplexer.l"
{ return(RESOLUTION); }
YY_BREAK
case 152:
YY_RULE_SETUP
-#line 272 "maplexer.l"
+#line 275 "maplexer.l"
{ return(SCALE); }
YY_BREAK
case 153:
YY_RULE_SETUP
-#line 273 "maplexer.l"
+#line 276 "maplexer.l"
{ return(SCALEDENOM); }
YY_BREAK
case 154:
YY_RULE_SETUP
-#line 274 "maplexer.l"
+#line 277 "maplexer.l"
{ return(SCALEBAR); }
YY_BREAK
case 155:
YY_RULE_SETUP
-#line 275 "maplexer.l"
+#line 278 "maplexer.l"
{ return(SHADOWCOLOR); }
YY_BREAK
case 156:
YY_RULE_SETUP
-#line 276 "maplexer.l"
+#line 279 "maplexer.l"
{ return(SHADOWSIZE); }
YY_BREAK
case 157:
YY_RULE_SETUP
-#line 277 "maplexer.l"
+#line 280 "maplexer.l"
{ return(SHAPEPATH); }
YY_BREAK
case 158:
YY_RULE_SETUP
-#line 278 "maplexer.l"
+#line 281 "maplexer.l"
{ return(SIZE); }
YY_BREAK
case 159:
YY_RULE_SETUP
-#line 279 "maplexer.l"
+#line 282 "maplexer.l"
{ return(SIZEUNITS); }
YY_BREAK
case 160:
YY_RULE_SETUP
-#line 280 "maplexer.l"
+#line 283 "maplexer.l"
{ return(STATUS); }
YY_BREAK
case 161:
YY_RULE_SETUP
-#line 281 "maplexer.l"
+#line 284 "maplexer.l"
{ return(STYLE); }
YY_BREAK
case 162:
YY_RULE_SETUP
-#line 282 "maplexer.l"
+#line 285 "maplexer.l"
{ return(STYLEITEM); }
YY_BREAK
case 163:
YY_RULE_SETUP
-#line 283 "maplexer.l"
+#line 286 "maplexer.l"
{ return(SYMBOL); }
YY_BREAK
case 164:
YY_RULE_SETUP
-#line 284 "maplexer.l"
+#line 287 "maplexer.l"
{ return(SYMBOLSCALE); }
YY_BREAK
case 165:
YY_RULE_SETUP
-#line 285 "maplexer.l"
+#line 288 "maplexer.l"
{ return(SYMBOLSCALEDENOM); }
YY_BREAK
case 166:
YY_RULE_SETUP
-#line 286 "maplexer.l"
+#line 289 "maplexer.l"
{ return(SYMBOLSET); }
YY_BREAK
case 167:
YY_RULE_SETUP
-#line 287 "maplexer.l"
+#line 290 "maplexer.l"
{ return(TABLE); }
YY_BREAK
case 168:
YY_RULE_SETUP
-#line 288 "maplexer.l"
+#line 291 "maplexer.l"
{ return(TEMPLATE); }
YY_BREAK
case 169:
YY_RULE_SETUP
-#line 289 "maplexer.l"
+#line 292 "maplexer.l"
{ return(TEMPLATEPATTERN); }
YY_BREAK
case 170:
YY_RULE_SETUP
-#line 290 "maplexer.l"
+#line 293 "maplexer.l"
{ return(TEXT); }
YY_BREAK
case 171:
YY_RULE_SETUP
-#line 291 "maplexer.l"
+#line 294 "maplexer.l"
{ return(TILEINDEX); }
YY_BREAK
case 172:
YY_RULE_SETUP
-#line 292 "maplexer.l"
+#line 295 "maplexer.l"
{ return(TILEITEM); }
YY_BREAK
case 173:
YY_RULE_SETUP
-#line 293 "maplexer.l"
+#line 296 "maplexer.l"
{ return(TITLE); }
YY_BREAK
case 174:
YY_RULE_SETUP
-#line 294 "maplexer.l"
+#line 297 "maplexer.l"
{ return(TO); }
YY_BREAK
case 175:
YY_RULE_SETUP
-#line 295 "maplexer.l"
+#line 298 "maplexer.l"
{ return(TOLERANCE); }
YY_BREAK
case 176:
YY_RULE_SETUP
-#line 296 "maplexer.l"
+#line 299 "maplexer.l"
{ return(TOLERANCEUNITS); }
YY_BREAK
case 177:
YY_RULE_SETUP
-#line 297 "maplexer.l"
+#line 300 "maplexer.l"
{ return(TRANSPARENCY); }
YY_BREAK
case 178:
YY_RULE_SETUP
-#line 298 "maplexer.l"
+#line 301 "maplexer.l"
{ return(TRANSPARENT); }
YY_BREAK
case 179:
YY_RULE_SETUP
-#line 299 "maplexer.l"
+#line 302 "maplexer.l"
{ return(TRANSFORM); }
YY_BREAK
case 180:
YY_RULE_SETUP
-#line 300 "maplexer.l"
+#line 303 "maplexer.l"
{ return(TYPE); }
YY_BREAK
case 181:
YY_RULE_SETUP
-#line 301 "maplexer.l"
+#line 304 "maplexer.l"
{ return(UNITS); }
YY_BREAK
case 182:
YY_RULE_SETUP
-#line 302 "maplexer.l"
+#line 305 "maplexer.l"
{ return(WEB); }
YY_BREAK
case 183:
YY_RULE_SETUP
-#line 303 "maplexer.l"
+#line 306 "maplexer.l"
{ return(WIDTH); }
YY_BREAK
case 184:
YY_RULE_SETUP
-#line 304 "maplexer.l"
+#line 307 "maplexer.l"
{ return(WKT); }
YY_BREAK
case 185:
YY_RULE_SETUP
-#line 305 "maplexer.l"
+#line 308 "maplexer.l"
{ return(WRAP); }
YY_BREAK
case 186:
YY_RULE_SETUP
-#line 307 "maplexer.l"
+#line 310 "maplexer.l"
{ return(MS_LAYER_ANNOTATION); }
YY_BREAK
case 187:
YY_RULE_SETUP
-#line 308 "maplexer.l"
+#line 311 "maplexer.l"
{ return(MS_AUTO); }
YY_BREAK
case 188:
YY_RULE_SETUP
-#line 309 "maplexer.l"
+#line 312 "maplexer.l"
{ return(MS_CJC_BEVEL); }
YY_BREAK
case 189:
YY_RULE_SETUP
-#line 310 "maplexer.l"
+#line 313 "maplexer.l"
{ return(MS_BITMAP); }
YY_BREAK
case 190:
YY_RULE_SETUP
-#line 311 "maplexer.l"
+#line 314 "maplexer.l"
{ return(MS_CJC_BUTT); }
YY_BREAK
case 191:
YY_RULE_SETUP
-#line 312 "maplexer.l"
+#line 315 "maplexer.l"
{ return(MS_SYMBOL_CARTOLINE); }
YY_BREAK
case 192:
YY_RULE_SETUP
-#line 313 "maplexer.l"
+#line 316 "maplexer.l"
{ return(MS_CC); }
YY_BREAK
case 193:
YY_RULE_SETUP
-#line 314 "maplexer.l"
+#line 317 "maplexer.l"
{ return(MS_ALIGN_CENTER); }
YY_BREAK
case 194:
YY_RULE_SETUP
-#line 315 "maplexer.l"
+#line 318 "maplexer.l"
{ return(MS_LAYER_CHART); }
YY_BREAK
case 195:
YY_RULE_SETUP
-#line 316 "maplexer.l"
+#line 319 "maplexer.l"
{ return(MS_LAYER_CIRCLE); }
YY_BREAK
case 196:
YY_RULE_SETUP
-#line 317 "maplexer.l"
+#line 320 "maplexer.l"
{ return(MS_CL); }
YY_BREAK
case 197:
YY_RULE_SETUP
-#line 318 "maplexer.l"
+#line 321 "maplexer.l"
{ return(MS_CR); }
YY_BREAK
case 198:
YY_RULE_SETUP
-#line 319 "maplexer.l"
+#line 322 "maplexer.l"
{ return(MS_DB_CSV); }
YY_BREAK
case 199:
YY_RULE_SETUP
-#line 320 "maplexer.l"
+#line 323 "maplexer.l"
{ return(MS_DB_MYSQL); }
YY_BREAK
case 200:
YY_RULE_SETUP
-#line 321 "maplexer.l"
+#line 324 "maplexer.l"
{ return(MS_DB_POSTGRES); }
YY_BREAK
case 201:
YY_RULE_SETUP
-#line 322 "maplexer.l"
+#line 325 "maplexer.l"
{ return(MS_DEFAULT); }
YY_BREAK
case 202:
YY_RULE_SETUP
-#line 323 "maplexer.l"
+#line 326 "maplexer.l"
{ return(MS_DD); }
YY_BREAK
case 203:
YY_RULE_SETUP
-#line 324 "maplexer.l"
+#line 327 "maplexer.l"
{ return(MS_SYMBOL_ELLIPSE); }
YY_BREAK
case 204:
YY_RULE_SETUP
-#line 325 "maplexer.l"
+#line 328 "maplexer.l"
{ return(MS_EMBED); }
YY_BREAK
case 205:
YY_RULE_SETUP
-#line 326 "maplexer.l"
+#line 329 "maplexer.l"
{ return(MS_FALSE); }
YY_BREAK
case 206:
YY_RULE_SETUP
-#line 327 "maplexer.l"
+#line 330 "maplexer.l"
{ return(MS_FEET); }
YY_BREAK
case 207:
YY_RULE_SETUP
-#line 328 "maplexer.l"
+#line 331 "maplexer.l"
{ return(MS_FOLLOW); }
YY_BREAK
case 208:
YY_RULE_SETUP
-#line 329 "maplexer.l"
+#line 332 "maplexer.l"
{ return(MS_GIANT); }
YY_BREAK
case 209:
YY_RULE_SETUP
-#line 330 "maplexer.l"
+#line 333 "maplexer.l"
{ return(MS_SYMBOL_HATCH); }
YY_BREAK
case 210:
YY_RULE_SETUP
-#line 331 "maplexer.l"
+#line 334 "maplexer.l"
{ return(MS_HILITE); }
YY_BREAK
case 211:
YY_RULE_SETUP
-#line 332 "maplexer.l"
+#line 335 "maplexer.l"
{ return(MS_INCHES); }
YY_BREAK
case 212:
YY_RULE_SETUP
-#line 333 "maplexer.l"
+#line 336 "maplexer.l"
{ return(MS_KILOMETERS); }
YY_BREAK
case 213:
YY_RULE_SETUP
-#line 334 "maplexer.l"
+#line 337 "maplexer.l"
{ return(MS_LARGE); }
YY_BREAK
case 214:
YY_RULE_SETUP
-#line 335 "maplexer.l"
+#line 338 "maplexer.l"
{ return(MS_LC); }
YY_BREAK
case 215:
YY_RULE_SETUP
-#line 336 "maplexer.l"
+#line 339 "maplexer.l"
{ return(MS_ALIGN_LEFT); }
YY_BREAK
case 216:
YY_RULE_SETUP
-#line 337 "maplexer.l"
+#line 340 "maplexer.l"
{ return(MS_LAYER_LINE); }
YY_BREAK
case 217:
YY_RULE_SETUP
-#line 338 "maplexer.l"
+#line 341 "maplexer.l"
{ return(MS_LL); }
YY_BREAK
case 218:
YY_RULE_SETUP
-#line 339 "maplexer.l"
+#line 342 "maplexer.l"
{ return(MS_LR); }
YY_BREAK
case 219:
YY_RULE_SETUP
-#line 340 "maplexer.l"
+#line 343 "maplexer.l"
{ return(MS_MEDIUM); }
YY_BREAK
case 220:
YY_RULE_SETUP
-#line 341 "maplexer.l"
+#line 344 "maplexer.l"
{ return(MS_METERS); }
YY_BREAK
case 221:
YY_RULE_SETUP
-#line 342 "maplexer.l"
+#line 345 "maplexer.l"
{ return(MS_MILES); }
YY_BREAK
case 222:
YY_RULE_SETUP
-#line 343 "maplexer.l"
+#line 346 "maplexer.l"
{ return(MS_CJC_MITER); }
YY_BREAK
case 223:
YY_RULE_SETUP
-#line 344 "maplexer.l"
+#line 347 "maplexer.l"
{ return(MS_MULTIPLE); }
YY_BREAK
case 224:
YY_RULE_SETUP
-#line 345 "maplexer.l"
+#line 348 "maplexer.l"
{ return(MS_CJC_NONE); }
YY_BREAK
case 225:
YY_RULE_SETUP
-#line 346 "maplexer.l"
+#line 349 "maplexer.l"
{ return(MS_NORMAL); }
YY_BREAK
case 226:
YY_RULE_SETUP
-#line 347 "maplexer.l"
+#line 350 "maplexer.l"
{ return(MS_OFF); }
YY_BREAK
case 227:
YY_RULE_SETUP
-#line 348 "maplexer.l"
+#line 351 "maplexer.l"
{ return(MS_OGR); }
YY_BREAK
case 228:
YY_RULE_SETUP
-#line 349 "maplexer.l"
+#line 352 "maplexer.l"
{ return(MS_ON); }
YY_BREAK
case 229:
YY_RULE_SETUP
-#line 350 "maplexer.l"
+#line 353 "maplexer.l"
{ return(MS_JOIN_ONE_TO_ONE); }
YY_BREAK
case 230:
YY_RULE_SETUP
-#line 351 "maplexer.l"
+#line 354 "maplexer.l"
{ return(MS_JOIN_ONE_TO_MANY); }
YY_BREAK
case 231:
YY_RULE_SETUP
-#line 352 "maplexer.l"
+#line 355 "maplexer.l"
{ return(MS_ORACLESPATIAL); }
YY_BREAK
case 232:
YY_RULE_SETUP
-#line 353 "maplexer.l"
+#line 356 "maplexer.l"
{ return(MS_PERCENTAGES); }
YY_BREAK
case 233:
YY_RULE_SETUP
-#line 354 "maplexer.l"
+#line 357 "maplexer.l"
{ return(MS_SYMBOL_PIXMAP); }
YY_BREAK
case 234:
YY_RULE_SETUP
-#line 355 "maplexer.l"
+#line 358 "maplexer.l"
{ return(MS_PIXELS); }
YY_BREAK
case 235:
YY_RULE_SETUP
-#line 356 "maplexer.l"
+#line 359 "maplexer.l"
{ return(MS_LAYER_POINT); }
YY_BREAK
case 236:
YY_RULE_SETUP
-#line 357 "maplexer.l"
+#line 360 "maplexer.l"
{ return(MS_LAYER_POLYGON); }
YY_BREAK
case 237:
YY_RULE_SETUP
-#line 358 "maplexer.l"
+#line 361 "maplexer.l"
{ return(MS_POSTGIS); }
YY_BREAK
case 238:
YY_RULE_SETUP
-#line 359 "maplexer.l"
+#line 362 "maplexer.l"
{ return(MS_MYGIS); }
YY_BREAK
case 239:
YY_RULE_SETUP
-#line 360 "maplexer.l"
+#line 363 "maplexer.l"
{ return(MS_PLUGIN); }
YY_BREAK
case 240:
YY_RULE_SETUP
-#line 361 "maplexer.l"
+#line 364 "maplexer.l"
{ return(MS_LAYER_QUERY); }
YY_BREAK
case 241:
YY_RULE_SETUP
-#line 362 "maplexer.l"
+#line 365 "maplexer.l"
{ return(MS_LAYER_RASTER); }
YY_BREAK
case 242:
YY_RULE_SETUP
-#line 363 "maplexer.l"
+#line 366 "maplexer.l"
{ return(MS_ALIGN_RIGHT); }
YY_BREAK
case 243:
YY_RULE_SETUP
-#line 364 "maplexer.l"
+#line 367 "maplexer.l"
{ return(MS_CJC_ROUND); }
YY_BREAK
case 244:
YY_RULE_SETUP
-#line 365 "maplexer.l"
+#line 368 "maplexer.l"
{ return(MS_SDE); }
YY_BREAK
case 245:
YY_RULE_SETUP
-#line 366 "maplexer.l"
+#line 369 "maplexer.l"
{ return(MS_SELECTED); }
YY_BREAK
case 246:
YY_RULE_SETUP
-#line 367 "maplexer.l"
+#line 370 "maplexer.l"
{ return(MS_SYMBOL_SIMPLE); }
YY_BREAK
case 247:
YY_RULE_SETUP
-#line 368 "maplexer.l"
+#line 371 "maplexer.l"
{ return(MS_SINGLE); }
YY_BREAK
case 248:
YY_RULE_SETUP
-#line 369 "maplexer.l"
+#line 372 "maplexer.l"
{ return(MS_SMALL); }
YY_BREAK
case 249:
YY_RULE_SETUP
-#line 370 "maplexer.l"
+#line 373 "maplexer.l"
{ return(MS_CJC_SQUARE); }
YY_BREAK
case 250:
YY_RULE_SETUP
-#line 371 "maplexer.l"
+#line 374 "maplexer.l"
{ return(MS_TINY); }
YY_BREAK
case 251:
YY_RULE_SETUP
-#line 372 "maplexer.l"
+#line 375 "maplexer.l"
{ return(MS_CJC_TRIANGLE); }
YY_BREAK
case 252:
YY_RULE_SETUP
-#line 373 "maplexer.l"
+#line 376 "maplexer.l"
{ return(MS_TRUE); }
YY_BREAK
case 253:
YY_RULE_SETUP
-#line 374 "maplexer.l"
+#line 377 "maplexer.l"
{ return(MS_TRUETYPE); }
YY_BREAK
case 254:
YY_RULE_SETUP
-#line 375 "maplexer.l"
+#line 378 "maplexer.l"
{ return(MS_UC); }
YY_BREAK
case 255:
YY_RULE_SETUP
-#line 376 "maplexer.l"
+#line 379 "maplexer.l"
{ return(MS_UL); }
YY_BREAK
case 256:
YY_RULE_SETUP
-#line 377 "maplexer.l"
+#line 380 "maplexer.l"
{ return(MS_UR); }
YY_BREAK
case 257:
YY_RULE_SETUP
-#line 378 "maplexer.l"
+#line 381 "maplexer.l"
{ return(MS_SYMBOL_VECTOR); }
YY_BREAK
case 258:
YY_RULE_SETUP
-#line 379 "maplexer.l"
+#line 382 "maplexer.l"
{ return(MS_WFS); }
YY_BREAK
case 259:
YY_RULE_SETUP
-#line 380 "maplexer.l"
+#line 383 "maplexer.l"
{ return(MS_WMS); }
YY_BREAK
case 260:
YY_RULE_SETUP
-#line 381 "maplexer.l"
+#line 384 "maplexer.l"
{ return(MS_GD_ALPHA); }
YY_BREAK
case 261:
YY_RULE_SETUP
-#line 383 "maplexer.l"
+#line 386 "maplexer.l"
msyytext++;
msyytext[strlen(msyytext)-1] = '\0';
@@ -3089,7 +3092,7 @@
YY_BREAK
case 262:
YY_RULE_SETUP
-#line 388 "maplexer.l"
+#line 391 "maplexer.l"
msyytext++;
@@ -3099,7 +3102,7 @@
YY_BREAK
case 263:
YY_RULE_SETUP
-#line 395 "maplexer.l"
+#line 398 "maplexer.l"
msyytext++;
@@ -3108,7 +3111,7 @@
YY_BREAK
case 264:
YY_RULE_SETUP
-#line 401 "maplexer.l"
+#line 404 "maplexer.l"
msyynumber = atof(msyytext);
return(MS_NUMBER);
@@ -3116,7 +3119,7 @@
YY_BREAK
case 265:
YY_RULE_SETUP
-#line 406 "maplexer.l"
+#line 409 "maplexer.l"
msyylval.dblval = atof(msyytext);
return(NUMBER);
@@ -3125,7 +3128,7 @@
case 266:
/* rule 266 can match eol */
YY_RULE_SETUP
-#line 411 "maplexer.l"
+#line 414 "maplexer.l"
msyytext++;
@@ -3138,7 +3141,7 @@
case 267:
/* rule 267 can match eol */
YY_RULE_SETUP
-#line 420 "maplexer.l"
+#line 423 "maplexer.l"
msyytext++;
msyytext[strlen(msyytext)-2] = '\0';
@@ -3148,7 +3151,7 @@
case 268:
/* rule 268 can match eol */
YY_RULE_SETUP
-#line 426 "maplexer.l"
+#line 429 "maplexer.l"
msyytext++;
@@ -3160,7 +3163,7 @@
case 269:
/* rule 269 can match eol */
YY_RULE_SETUP
-#line 434 "maplexer.l"
+#line 437 "maplexer.l"
msyytext++;
@@ -3170,7 +3173,7 @@
case 270:
/* rule 270 can match eol */
YY_RULE_SETUP
-#line 440 "maplexer.l"
+#line 443 "maplexer.l"
msyytext++;
@@ -3181,7 +3184,7 @@
YY_BREAK
case 271:
YY_RULE_SETUP
-#line 448 "maplexer.l"
+#line 451 "maplexer.l"
msyytext++;
@@ -3191,7 +3194,7 @@
case 272:
/* rule 272 can match eol */
YY_RULE_SETUP
-#line 454 "maplexer.l"
+#line 457 "maplexer.l"
msyytext++;
@@ -3201,7 +3204,7 @@
case 273:
/* rule 273 can match eol */
YY_RULE_SETUP
-#line 460 "maplexer.l"
+#line 463 "maplexer.l"
msyytext++;
@@ -3227,7 +3230,7 @@
case 274:
/* rule 274 can match eol */
YY_RULE_SETUP
-#line 482 "maplexer.l"
+#line 485 "maplexer.l"
msyytext++;
@@ -3237,7 +3240,7 @@
case 275:
/* rule 275 can match eol */
YY_RULE_SETUP
-#line 488 "maplexer.l"
+#line 491 "maplexer.l"
msyytext++;
@@ -3248,7 +3251,7 @@
YY_BREAK
case 276:
YY_RULE_SETUP
-#line 496 "maplexer.l"
+#line 499 "maplexer.l"
/* Beginning of a new String, skip the quote and enter the MSSTR context */
int idx=0;
@@ -3261,7 +3264,7 @@
case 277:
/* rule 277 can match eol */
YY_RULE_SETUP
-#line 505 "maplexer.l"
+#line 508 "maplexer.l"
/* Escape code: skip the slash and use the escaped char */
if(strlen(string_buf) < (1024-2))
@@ -3270,7 +3273,7 @@
YY_BREAK
case 278:
YY_RULE_SETUP
-#line 511 "maplexer.l"
+#line 514 "maplexer.l"
this is the closing quote - we're done
@@ -3287,7 +3290,7 @@
case 279:
/* rule 279 can match eol */
YY_RULE_SETUP
-#line 524 "maplexer.l"
+#line 527 "maplexer.l"
char *yptr = msyytext;
@@ -3304,17 +3307,17 @@
YY_BREAK
case 280:
YY_RULE_SETUP
-#line 538 "maplexer.l"
+#line 541 "maplexer.l"
{ return(MS_STRING); }
YY_BREAK
case 281:
/* rule 281 can match eol */
YY_RULE_SETUP
-#line 540 "maplexer.l"
+#line 543 "maplexer.l"
{ msyylineno++; }
YY_BREAK
case YY_STATE_EOF(INITIAL):
-#line 542 "maplexer.l"
+#line 545 "maplexer.l"
if( --include_stack_ptr < 0 )
return(EOF); /* end of main file */
@@ -3328,27 +3331,27 @@
case 282:
/* rule 282 can match eol */
YY_RULE_SETUP
-#line 552 "maplexer.l"
+#line 555 "maplexer.l"
return(0);
YY_BREAK
case 283:
YY_RULE_SETUP
-#line 556 "maplexer.l"
+#line 559 "maplexer.l"
{ return(0); }
YY_BREAK
case 284:
YY_RULE_SETUP
-#line 557 "maplexer.l"
+#line 560 "maplexer.l"
{ return(msyytext[0]); }
YY_BREAK
case 285:
YY_RULE_SETUP
-#line 558 "maplexer.l"
+#line 561 "maplexer.l"
ECHO;
YY_BREAK
-#line 3352 "maplexer.c"
+#line 3355 "maplexer.c"
case YY_STATE_EOF(URL_VARIABLE):
case YY_STATE_EOF(URL_STRING):
case YY_STATE_EOF(EXPRESSION_STRING):
@@ -4339,7 +4342,7 @@
#define YYTABLES_NAME "yytables"
More information about the mapserver-commits
