[mapserver-commits] r7889 - trunk/mapserver/mapscript/php3
svn at osgeo.org
svn at osgeo.org
Wed Aug 27 09:26:51 EDT 2008
Author: Assefa
Date: 2008-08-27 09:26:50 -0400 (Wed, 27 Aug 2008)
New Revision: 7889
trunk/mapserver/mapscript/php3/README
trunk/mapserver/mapscript/php3/php_mapscript.c
Add opacity parameter in the style object (#2755)
Modified: trunk/mapserver/mapscript/php3/README
--- trunk/mapserver/mapscript/php3/README 2008-08-27 03:36:18 UTC (rev 7888)
+++ trunk/mapserver/mapscript/php3/README 2008-08-27 13:26:50 UTC (rev 7889)
@@ -1692,6 +1692,7 @@
double minvalue
double maxvalue
string rangeitem
+ int opacity (this parameter is only supported for the AGG driver)
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c 2008-08-27 03:36:18 UTC (rev 7888)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c 2008-08-27 13:26:50 UTC (rev 7889)
@@ -13751,6 +13751,7 @@
add_property_double(return_value, "minvalue", pstyle->minvalue);
add_property_double(return_value, "maxvalue", pstyle->maxvalue);
PHPMS_ADD_PROP_STR(return_value, "rangeitem", pstyle->rangeitem);
+ add_property_long(return_value, "opacity", pstyle->opacity);
MAKE_STD_ZVAL(new_obj_ptr); /* Alloc and Init a ZVAL for new object */
_phpms_build_color_object(&(pstyle->color),list, new_obj_ptr TSRMLS_CC);
@@ -13894,6 +13895,7 @@
else IF_SET_DOUBLE("minvalue", self->minvalue)
else IF_SET_DOUBLE("maxvalue", self->maxvalue)
else IF_SET_STRING( "rangeitem", self->rangeitem)
+ else IF_SET_LONG( "opacity", self->opacity)
else
php3_error(E_ERROR,"Property '%s' does not exist in this object.",
More information about the mapserver-commits
