[mapserver-commits] r8152 - in trunk/docs: . development/rfc
svn at osgeo.org
svn at osgeo.org
Mon Dec 1 00:57:24 EST 2008
Author: hobu
Date: 2008-12-01 00:57:24 -0500 (Mon, 01 Dec 2008)
New Revision: 8152
trunk/docs/development/rfc/index.txt
trunk/docs/development/rfc/ms-rfc-2.txt
trunk/docs/development/rfc/ms-rfc-24.txt
trunk/docs/development/rfc/ms-rfc-3.txt
trunk/docs/development/rfc/ms-rfc-37.txt
trunk/docs/development/rfc/ms-rfc-42.txt
trunk/docs/development/rfc/ms-rfc-46.txt
trunk/docs/development/rfc/ms-rfc-5.txt
trunk/docs/development/rfc/ms-rfc-6.txt
trunk/docs/development/rfc/ms-rfc-7.txt
trunk/docs/development/rfc/ms-rfc-8.txt
trunk/docs/index.txt
more style normalization
Modified: trunk/docs/development/rfc/index.txt
--- trunk/docs/development/rfc/index.txt 2008-12-01 05:33:33 UTC (rev 8151)
+++ trunk/docs/development/rfc/index.txt 2008-12-01 05:57:24 UTC (rev 8152)
@@ -0,0 +1,60 @@
+.. _rfcs:
+ Request for Comments
+.. toctree::
+ :maxdepth: 1
+ ms-rfc-1
+ ms-rfc-2
+ ms-rfc-3
+ ms-rfc-4
+ ms-rfc-5
+ ms-rfc-6
+ ms-rfc-7
+ ms-rfc-7.1
+ ms-rfc-8
+ ms-rfc-9
+ ms-rfc-10
+ ms-rfc-11
+ ms-rfc-12
+ ms-rfc-13
+ ms-rfc-14
+ ms-rfc-15
+ ms-rfc-16
+ ms-rfc-17
+ ms-rfc-18
+ ms-rfc-19
+ ms-rfc-20
+ ms-rfc-21
+ ms-rfc-22
+ ms-rfc-23
+ ms-rfc-24
+ ms-rfc-25
+ ms-rfc-26
+ ms-rfc-27
+ ms-rfc-28
+ ms-rfc-29
+ ms-rfc-30
+ ms-rfc-31
+ ms-rfc-32
+ ms-rfc-33
+ ms-rfc-34
+ ms-rfc-35
+ ms-rfc-36
+ ms-rfc-37
+ ms-rfc-38
+ ms-rfc-39
+ ms-rfc-40
+ ms-rfc-41
+ ms-rfc-42
+ ms-rfc-43
+ ms-rfc-44
+ ms-rfc-45
+ ms-rfc-46
+ ms-rfc-47
+ ms-rfc-48
Modified: trunk/docs/development/rfc/ms-rfc-2.txt
--- trunk/docs/development/rfc/ms-rfc-2.txt 2008-12-01 05:33:33 UTC (rev 8151)
+++ trunk/docs/development/rfc/ms-rfc-2.txt 2008-12-01 05:57:24 UTC (rev 8152)
@@ -132,7 +132,8 @@
Bug ID
-1466 (primary bug, addition entries for MapScript and OGR will follow)
+http://trac.osgeo.org/mapserver/ticket/1466
+(primary bug, addition entries for MapScript and OGR will follow)
Voting history
Modified: trunk/docs/development/rfc/ms-rfc-24.txt
--- trunk/docs/development/rfc/ms-rfc-24.txt 2008-12-01 05:33:33 UTC (rev 8151)
+++ trunk/docs/development/rfc/ms-rfc-24.txt 2008-12-01 05:57:24 UTC (rev 8152)
@@ -14,8 +14,6 @@
:Tracker 3.2: http://trac.osgeo.org/mapserver/ticket/2442
:Id: $Id$
-.. sectnum::
.. contents:: Table of Contents
:depth: 2
:backlinks: top
Modified: trunk/docs/development/rfc/ms-rfc-3.txt
--- trunk/docs/development/rfc/ms-rfc-3.txt 2008-12-01 05:33:33 UTC (rev 8151)
+++ trunk/docs/development/rfc/ms-rfc-3.txt 2008-12-01 05:57:24 UTC (rev 8152)
@@ -396,8 +396,7 @@
Vote proposed by Jani Averbach on 9/19/2005, result was +4
(3 non-voting members).
-Voting +1: Howard Butler, Frank Warmerdam, Yewondwossen Assefa,
- Daniel Morissette
+Voting +1: Howard Butler, Frank Warmerdam, Yewondwossen Assefa, Daniel Morissette
Proposal passes and will move forward.
@@ -424,12 +423,7 @@
which is handled via the layer API?
-Working Notes
.. Local Variables:
mode: text
End:
Modified: trunk/docs/development/rfc/ms-rfc-37.txt
--- trunk/docs/development/rfc/ms-rfc-37.txt 2008-12-01 05:33:33 UTC (rev 8151)
+++ trunk/docs/development/rfc/ms-rfc-37.txt 2008-12-01 05:57:24 UTC (rev 8152)
@@ -1,7 +1,7 @@
.. rfc37:
- MapServer Spatial Reference Improvements and Additions
+ MS RFC 37: MapServer Spatial Reference Improvements and Additions
:Author: Howard Butler
Modified: trunk/docs/development/rfc/ms-rfc-42.txt
--- trunk/docs/development/rfc/ms-rfc-42.txt 2008-12-01 05:33:33 UTC (rev 8151)
+++ trunk/docs/development/rfc/ms-rfc-42.txt 2008-12-01 05:57:24 UTC (rev 8152)
@@ -12,9 +12,8 @@
:version: MapServer 5.2
:Id: $Id$
Overview
This RFC propose to extend MapServer to forward HTTP Cookies when doing OWS
requests.
@@ -34,9 +33,8 @@
to) WMS requests for: getmaps, getfeatureinfo and WFS requests for GetFeature.
Implementation Methodology
A new metadata (http_cookie_data) will be added at the mapfile level to
temporarily store HTTP cookie data. Another metadata (ows_http_cookie) will
@@ -77,9 +75,8 @@
where MapServer request an outside webserver.
Implementation Issues
It was pointed out during the RFC review period that passing and storing the
cookie data using an "http_cookie_data" metadata is a poor use of MapServer's
@@ -104,9 +101,8 @@
will be allowed.
Modifications to the Source Code
The HTTP Cookie data will need to be stored in cgiRequestObj in a new member
variable to be able to pass it to the mapfile. If HTTP Cookies are present the
@@ -125,9 +121,8 @@
called CURLOPT_COOKIE to send cookies with a request.
MapScript
By storing the HTTP Cookie data in a mapfile metadata MapScript will be able
to use this new functionality. Here's an example of a PHP/MapScript use of
@@ -144,9 +139,8 @@
$oMap->draw();
File Affected
@@ -159,25 +153,20 @@
mapwfslayer.c (set cookies in httpRequestObj)
Backwards Compatibility
None.
Bug ID
http://trac.osgeo.org/mapserver/ticket/2566
Voting History
Adopted on 2008/04/01 with +1 from FrankW, DanielM, TomK and AssefaY, and +0
from JeffM and PericlesN.
Modified: trunk/docs/development/rfc/ms-rfc-46.txt
--- trunk/docs/development/rfc/ms-rfc-46.txt 2008-12-01 05:33:33 UTC (rev 8151)
+++ trunk/docs/development/rfc/ms-rfc-46.txt 2008-12-01 05:57:24 UTC (rev 8152)
@@ -11,9 +11,8 @@
:Status: Proposed
:Id: $Id$
Purpose
Developers and users have expressed dissatisfaction with the current MapServer
site, the site rather poorly serves the needs of the project in many
@@ -22,9 +21,8 @@
MapServer website with a hybrid setup that is similar to the infrastructure
that the OpenLayers_ currently maintains.
Failures of the Current Website
The current MapServer website could be considered the 2.0 version of the
MapServer project's web presence. The 1.0 version of the website was a
@@ -36,7 +34,7 @@
Administrative Failures
Our uptime has been ok, but one effect of the current setup is that no one
except Howard Butler takes responsibility for our web infrastructure. Part of
@@ -49,7 +47,7 @@
achieve any progress.
Survey
A `survey`_ that hoped to determine if the community had any feelings about
how the site is currently serving the community was rather inconclusive. While
@@ -57,9 +55,8 @@
dwarfs the nearly three thousand mailing list subscribers, and I am uncertain
what was expressed captures the general sentiment.
Goals
Here are some goals that the 3.0 version of the MapServer website should
achieve:
@@ -72,7 +69,7 @@
* Move off of UMN computing and integrate within OSGeo's infrastructure
Make it easy for folks to find the docs
Some people have complained that it is difficult to find documents on the
website unless you know the exact place in the hierarchy. Because our
@@ -82,7 +79,7 @@
hierarchy causes more problems than it solves in this regard.
Stay the out of developers' way
The current website is quite slow. Slow to edit, slow to view, and slow to
change. There's lots of pointing and clicking involved to do the simplest
@@ -92,7 +89,7 @@
in subversion and have the website be updated automatically.
Allow documenters to get their job done
The website fails documenters in a number of ways, but the most important
failure is the inability to tie documents to specific MapServer versions. A
@@ -101,7 +98,7 @@
should just leverage that to accomplish this goal.
Allow limited user-contributed information in the form of wiki pages
From time to time, users do contribute significant documentation describing
how to accomplish a particular task with MapServer. Our new infrastructure
@@ -110,7 +107,7 @@
can take advantage of it to accomplish this goal.
Have a gallery that works better
The `OpenLayers Gallery`_ works better than the current MapServer gallery,
and it works much easier from a management/administrative standpoint.
@@ -119,7 +116,7 @@
current MapServer gallery.
Just recently (Sept 15th -- Sept 16th, 2008), the server that houses the site
was having power supply unit issues (they have been resolved), but it is a
@@ -130,9 +127,8 @@
destiny. Reasons like this are exactly why OSGeo exists, there are resources
there for us to use, and we should move the website there at the same time.
Implementation
We are going to unabashedly rip off OpenLayers' web infrastructure. This
includes the gallery, static website, and Trac integration. OpenLayers' web
@@ -160,10 +156,6 @@
static HTML website from them. This website will be what exists at
http://mapserver.osgeo.org
.. _OpenLayers: http://openlayers.org
.. _OpenLayers Gallery: http://gallery.openlayers.org
.. _survey: http://mapserver.gis.umn.edu/community/polls/website-future/questionnaire_view_results
\ No newline at end of file
Modified: trunk/docs/development/rfc/ms-rfc-5.txt
--- trunk/docs/development/rfc/ms-rfc-5.txt 2008-12-01 05:33:33 UTC (rev 8151)
+++ trunk/docs/development/rfc/ms-rfc-5.txt 2008-12-01 05:57:24 UTC (rev 8152)
@@ -18,7 +18,7 @@
To provide a practical solution to MapServer Bug 411 - Clipping Issue
with Ortho Projection:
- http://trac.osgeo.org/mapserver/ticket411
+ http://trac.osgeo.org/mapserver/ticket/411
Approach
Modified: trunk/docs/development/rfc/ms-rfc-6.txt
--- trunk/docs/development/rfc/ms-rfc-6.txt 2008-12-01 05:33:33 UTC (rev 8151)
+++ trunk/docs/development/rfc/ms-rfc-6.txt 2008-12-01 05:57:24 UTC (rev 8152)
@@ -207,18 +207,20 @@
shapes color, and modify the color parameter accordingly.
2) Choose a unique method name ('linear', 'logarithmic', 'discrete')
-modify the method msMapColorRamp() to call its method when its method name
-is found on a ColorRange definition.
+ modify the method msMapColorRamp() to call its method when its method name
+ is found on a ColorRange definition.
- Note: whether the msMapColorRamp() method uses if/then logic or dispatches
- by function pointer can be determined later. For now, I believe the
- simplest approach would be to move all of the mapping logic + all current
- methods into a mapColorRange.c file.
+.. note::
+ Whether the msMapColorRamp() method uses if/then logic or dispatches
+ by function pointer can be determined later. For now, I believe the
+ simplest approach would be to move all of the mapping logic + all current
+ methods into a mapColorRange.c file.
Bug ID
-Currently this is being tracked by bug #1305
+Currently this is being tracked by http://trac.osgeo.org/mapserver/ticket/1305
Voting history
Modified: trunk/docs/development/rfc/ms-rfc-7.txt
--- trunk/docs/development/rfc/ms-rfc-7.txt 2008-12-01 05:33:33 UTC (rev 8151)
+++ trunk/docs/development/rfc/ms-rfc-7.txt 2008-12-01 05:57:24 UTC (rev 8152)
@@ -1,3 +1,5 @@
+.. _rfc7:
MS RFC 7: MapServer CVS Commit Management
Modified: trunk/docs/development/rfc/ms-rfc-8.txt
--- trunk/docs/development/rfc/ms-rfc-8.txt 2008-12-01 05:33:33 UTC (rev 8151)
+++ trunk/docs/development/rfc/ms-rfc-8.txt 2008-12-01 05:57:24 UTC (rev 8152)
@@ -137,8 +137,7 @@
Vote proposed by Jani Averbach on 10/26/2005, the initial result
was +3 and after amending RFC, got +4 (3 non-voting members).
-Voting +1: Frank Warmerdam, Steve Lime, Yewondwossen Assefa,
- Daniel Morissette
+Voting +1: Frank Warmerdam, Steve Lime, Yewondwossen Assefa, Daniel Morissette
Proposal passed and will move forward.
@@ -150,9 +149,8 @@
None
Working Notes
Plugin library has to implement function
``PluginInitializeVirtualTable``
Modified: trunk/docs/index.txt
--- trunk/docs/index.txt 2008-12-01 05:33:33 UTC (rev 8151)
+++ trunk/docs/index.txt 2008-12-01 05:57:24 UTC (rev 8152)
@@ -20,6 +20,7 @@
optimization/index
utilities/index
cgi/index
+ development/index
Indices and tables
More information about the mapserver-commits
