[mapserver-commits] r8162 - in trunk/docs: compilation
development/rfc optimization
svn at osgeo.org
svn at osgeo.org
Mon Dec 1 11:19:27 EST 2008
Author: hobu
Date: 2008-12-01 11:19:27 -0500 (Mon, 01 Dec 2008)
New Revision: 8162
trunk/docs/compilation/unix.txt
trunk/docs/compilation/win32.txt
trunk/docs/development/rfc/ms-rfc-40.txt
trunk/docs/development/rfc/ms-rfc-45.txt
trunk/docs/development/rfc/ms-rfc-5.txt
trunk/docs/optimization/raster.txt
more cleanups for latex
Modified: trunk/docs/compilation/unix.txt
--- trunk/docs/compilation/unix.txt 2008-12-01 15:44:18 UTC (rev 8161)
+++ trunk/docs/compilation/unix.txt 2008-12-01 16:19:27 UTC (rev 8162)
@@ -91,7 +91,7 @@
spatial predicate and algebra operations (within, touches, etc & union,
difference, intersection). Requires version 4.10 or greater.
-* `libxml <http://xmlsoft.org>`__: libxml is required to use `OGC SOS </docs/howto/sos_server>`__
+* `libxml <http://xmlsoft.org>`__: libxml is required to use :ref:`OGC SOS <sos_server>`
support in MapServer (versions 4.10 and greater).
* `SDE Client Library <http://www.esri.com/software/arcgis/arcsde/index.html>`__:
@@ -224,9 +224,11 @@
More detail about this patch (if you need any) was described by Steve Lime
in a `post to mapserver-users`_.
-.. note: Windows builds that are built with the buildkit (this includes MS4W
-and OSGeo4W) have this patch already and do not need to be updated.
+.. note:
+ Windows builds that are built with the buildkit (this includes MS4W
+ and OSGeo4W) have this patch already and do not need to be updated.
Curved label support
@@ -565,8 +567,7 @@
Where to go once you've got it compiled
-The `new users`_ document provides excellent coverage of getting started
+The :ref:`new_users` document provides excellent coverage of getting started
with MapServer.
-.. _`new users`: /new_users
.. _`post to mapserver-users`: http://article.gmane.org/gmane.comp.gis.mapserver.user/17766
Modified: trunk/docs/compilation/win32.txt
--- trunk/docs/compilation/win32.txt 2008-12-01 15:44:18 UTC (rev 8161)
+++ trunk/docs/compilation/win32.txt 2008-12-01 16:19:27 UTC (rev 8162)
@@ -5,7 +5,7 @@
:Author: Pericles Nacionales
-iRevision: $Revision$
+:Revision: $Revision$
:Date: $Date$
:Last Updated: 2005/12/20
Modified: trunk/docs/development/rfc/ms-rfc-40.txt
--- trunk/docs/development/rfc/ms-rfc-40.txt 2008-12-01 15:44:18 UTC (rev 8161)
+++ trunk/docs/development/rfc/ms-rfc-40.txt 2008-12-01 16:19:27 UTC (rev 8162)
@@ -47,9 +47,9 @@
| | maxlen =0 | maxlen > 0 | maxlen < 0 |
| wrap = 'char' | current way | conditional wrap if current | hard wrap |
-| | | length > maxlen | i.e. always |
-+----------------+-----------------+-----------------------------+ break at exactly |
-| no wrap | no processing | skip label if text is | maxlen chars |
+| | | length > maxlen | |
+| no wrap | no processing | skip label if text is | hard wrap |
| | | longer than maxlen | |
Modified: trunk/docs/development/rfc/ms-rfc-45.txt
--- trunk/docs/development/rfc/ms-rfc-45.txt 2008-12-01 15:44:18 UTC (rev 8161)
+++ trunk/docs/development/rfc/ms-rfc-45.txt 2008-12-01 16:19:27 UTC (rev 8162)
@@ -14,8 +14,6 @@
(*partiallly derived in part from a document prepared by Håvard and
discussions with other developers working on cartographic output*)
-Proposed Changes
Scale Dependant Rendering
@@ -84,7 +82,8 @@
If possible, something like:
Modes of operation
- DEFAULT reference direction to the right (east), counter-clockwise direction
of rotation.
- CLOCKWISE reference direction to the right (east), clockwise direction of
@@ -93,7 +92,8 @@
(compass directions).
Behavior
- For symbols of Type HATCH, this is the angle of the hatched lines.
- For points, this specifies the rotation of a symbol around its defined
CENTER.
@@ -155,9 +155,6 @@
more to come?
-New Functionnality
add MINSCALEDENOM/MAXSCALEDENOM parameters to styleObj
this would allow doing things like removing outlines or the hollow portions of
@@ -210,8 +207,9 @@
Files Affected
* maplexer.l: C4, C5
* mapgd.c: B1, C2, C3, C4
* mapagg.cpp: B1, C2, C3, C4
@@ -220,8 +218,9 @@
* mapprimitive.c: C5, D2
Bug IDs
Individual modifications will be tracked with their own tickets which will
be listed here.
Modified: trunk/docs/development/rfc/ms-rfc-5.txt
--- trunk/docs/development/rfc/ms-rfc-5.txt 2008-12-01 15:44:18 UTC (rev 8161)
+++ trunk/docs/development/rfc/ms-rfc-5.txt 2008-12-01 16:19:27 UTC (rev 8162)
@@ -1,4 +1,4 @@
-.. rfc5:
+.. _rfc5:
MS RFC 5: MapServer Horizon Reprojection Improvements
Modified: trunk/docs/optimization/raster.txt
--- trunk/docs/optimization/raster.txt 2008-12-01 15:44:18 UTC (rev 8161)
+++ trunk/docs/optimization/raster.txt 2008-12-01 16:19:27 UTC (rev 8162)
@@ -32,7 +32,7 @@
small area of the image.
A tileindex is how one creates an on-the-fly mosaic from many rasters. This is
-described in the `tileindex howto`_. That document describes common cases where a tileindex makes
+described in the :ref:`tileindex`. That document describes common cases where a tileindex makes
sense. In particular, if you have a very large raster and most requests are for
a very small spatial area within it, you may want t consider slicing it and
tileindexing it.
@@ -76,9 +76,7 @@
See also
-`Raster Data Access`_
+:ref:`raster`
.. #### rST Link Section ####
-.. _`Raster Data Access`: /docs/howto/raster_data/
-.. _`tileindex howto`: /docs/howto/tileindex/
More information about the mapserver-commits
