[mapserver-commits] r8167 - trunk/docs
Tue Dec 2 11:35:39 EST 2008
Author: hobu
Date: 2008-12-02 11:35:39 -0500 (Tue, 02 Dec 2008)
New Revision: 8167
Added:
   trunk/docs/style_guide.txt
Removed:
   trunk/docs/msdocs_style.txt
rename
Deleted: trunk/docs/msdocs_style.txt
--- trunk/docs/msdocs_style.txt	2008-12-02 01:58:18 UTC (rev 8166)
+++ trunk/docs/msdocs_style.txt	2008-12-02 16:35:39 UTC (rev 8167)
@@ -1,37 +0,0 @@
- MapServer Documentation Style Guide
-:Author:  Howard Butler
-:Contact: hobu.inc at gmail.com
-:Revision: $Revision: 8058 $
-:Date: $Date: 2008-11-23 14:02:50 -0600 (Sun, 23 Nov 2008) $
-:Last Updated: 2008/11/23
-.. sectnum::
-.. contents:: Table of Contents
-    :depth: 2
-    :backlinks: top
-MapServer instead of mapserver, map server, Map Server or map Server.
-MapScript instead of mapscript, Mapscript, or map script.
-PostGIS instead of postgis.
-HowTo instead of howto or HOWTO.
-ReStructured Text Formatting
-All text should be hard breaks at or around the 80 column mark, just as
-the source code.
-no ``.. sectnum::`` in the contents directives
-Email addresses should be manually spam protected:
-hobu.inc at gmail.com instead of hobu.inc at gmail.com
\ No newline at end of file
Copied: trunk/docs/style_guide.txt (from rev 8166, trunk/docs/msdocs_style.txt)
--- trunk/docs/style_guide.txt	                        (rev 0)
+++ trunk/docs/style_guide.txt	2008-12-02 16:35:39 UTC (rev 8167)
@@ -0,0 +1,37 @@
+ MapServer Documentation Style Guide
+:Author:  Howard Butler
+:Contact: hobu.inc at gmail.com
+:Revision: $Revision: 8058 $
+:Date: $Date: 2008-11-23 14:02:50 -0600 (Sun, 23 Nov 2008) $
+:Last Updated: 2008/11/23
+.. sectnum::
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+MapServer instead of mapserver, map server, Map Server or map Server.
+MapScript instead of mapscript, Mapscript, or map script.
+PostGIS instead of postgis.
+HowTo instead of howto or HOWTO.
+ReStructured Text Formatting
+All text should be hard breaks at or around the 80 column mark, just as
+the source code.
+no ``.. sectnum::`` in the contents directives
+Email addresses should be manually spam protected:
+hobu.inc at gmail.com instead of hobu.inc at gmail.com
