[mapserver-commits] r8176 - in trunk/docs: cgi howto
svn at osgeo.org
svn at osgeo.org
Tue Dec 2 23:40:06 EST 2008
Author: hobu
Date: 2008-12-02 23:40:06 -0500 (Tue, 02 Dec 2008)
New Revision: 8176
Added:
trunk/docs/cgi/runsub.txt
Removed:
trunk/docs/howto/runsub.txt
trunk/docs/cgi/index.txt
move to cgi section
Modified: trunk/docs/cgi/index.txt
--- trunk/docs/cgi/index.txt 2008-12-03 04:39:24 UTC (rev 8175)
+++ trunk/docs/cgi/index.txt 2008-12-03 04:40:06 UTC (rev 8176)
@@ -18,6 +18,7 @@
mapserv
mapcontext
controls
+ runsub
Copied: trunk/docs/cgi/runsub.txt (from rev 8175, trunk/docs/howto/runsub.txt)
--- trunk/docs/cgi/runsub.txt (rev 0)
+++ trunk/docs/cgi/runsub.txt 2008-12-03 04:40:06 UTC (rev 8176)
@@ -0,0 +1,70 @@
+.. _runsub:
+ Run-time Substitution
+:Author: Steve Lime
+:Contact: steve.lime at DNR.STATE.MN.US
+:Revision: $Revision$
+:Date: $Date$
+:Last Updated: 2005/12/12
+.. contents:: Table of Contents
+ :depth: 2
+ :backlinks: top
+Introduction
+Run-time substitution for the MapServer CGI has been around since version 4.0
+and it's use has continued to expand. In short, it allows you to alter
+portions of a mapfile based on data passed via a CGI request. This
+functionality is only available via the standard CGI application. Within
+MapScript this is easy to do since the developer has complete control over how
+input is handled.
+Basic Example
+Let's say you'd like the user to dynamically set a
+portion of an expression so they could highlight a certain land cover class,
+and you have a form element (called ctype) that allows them to choose between:
+forest, water, wetland and developed. You could then set up a layer like so:
+ LAYER
+ NAME 'covertypes'
+ CLASSITEM 'type'
+ CLASS # highlighted presentation
+ EXPRESSION '%ctype%'
+ END
+ CLASS # default presentation
+ END
+ END
+When a request is processed the value for ctype is substituted for the
+string %ctype% and the mapfile is processed as normal. If no ctype is passed
+in the EXPRESSION will never be true so it doesn't really hurt anything except
+for a slight performance hit. Often you would set a default class to draw
+features that don't match, but that is not required.
+Parameters Supported
+Not every mapfile parameter supports run-time substitution and care has
+been taken to try and support those that make the most sense. Remember, you
+also can do run-time configuration using the map_object_property type syntax
+detailed elsewhere (todo- add link). Below is a list of properties that do
+allow run-time substitution (todo- add MapServer version):
+* LAYER: DATA (must validate against DATAPATTERN)
+* LAYER: TILEINDEX
+* LAYER: CONNECTION
+* LAYER: FILTER
+* CLASS EXPRESSION
Deleted: trunk/docs/howto/runsub.txt
--- trunk/docs/howto/runsub.txt 2008-12-03 04:39:24 UTC (rev 8175)
+++ trunk/docs/howto/runsub.txt 2008-12-03 04:40:06 UTC (rev 8176)
@@ -1,70 +0,0 @@
-.. _runsub:
- Run-time Substitution
-:Author: Steve Lime
-:Contact: steve.lime at DNR.STATE.MN.US
-:Revision: $Revision$
-:Date: $Date$
-:Last Updated: 2005/12/12
-.. contents:: Table of Contents
- :depth: 2
- :backlinks: top
-Introduction
-Run-time substitution for the MapServer CGI has been around since version 4.0
-and it's use has continued to expand. In short, it allows you to alter
-portions of a mapfile based on data passed via a CGI request. This
-functionality is only available via the standard CGI application. Within
-MapScript this is easy to do since the developer has complete control over how
-input is handled.
-Basic Example
-Let's say you'd like the user to dynamically set a
-portion of an expression so they could highlight a certain land cover class,
-and you have a form element (called ctype) that allows them to choose between:
-forest, water, wetland and developed. You could then set up a layer like so:
- LAYER
- NAME 'covertypes'
- CLASSITEM 'type'
- CLASS # highlighted presentation
- EXPRESSION '%ctype%'
- END
- CLASS # default presentation
- END
- END
-When a request is processed the value for ctype is substituted for the
-string %ctype% and the mapfile is processed as normal. If no ctype is passed
-in the EXPRESSION will never be true so it doesn't really hurt anything except
-for a slight performance hit. Often you would set a default class to draw
-features that don't match, but that is not required.
-Parameters Supported
-Not every mapfile parameter supports run-time substitution and care has
-been taken to try and support those that make the most sense. Remember, you
-also can do run-time configuration using the map_object_property type syntax
-detailed elsewhere (todo- add link). Below is a list of properties that do
-allow run-time substitution (todo- add MapServer version):
-* LAYER: DATA (must validate against DATAPATTERN)
-* LAYER: TILEINDEX
-* LAYER: CONNECTION
-* LAYER: FILTER
-* CLASS EXPRESSION
More information about the mapserver-commits
