[mapserver-commits] r8180 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Dec 3 05:19:39 EST 2008
Author: tbonfort
Date: 2008-12-03 05:19:39 -0500 (Wed, 03 Dec 2008)
New Revision: 8180
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapagg.cpp
agg: fix center of rotation for truetype marker symbols
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-12-03 09:55:48 UTC (rev 8179)
+++ trunk/mapserver/HISTORY.TXT 2008-12-03 10:19:39 UTC (rev 8180)
@@ -11,6 +11,7 @@
Current Version (5.3-dev, SVN trunk):
+- mapagg.cpp: Fix center of rotation for truetype marker symbols
- mapowscommon.c: use msLibXml2GenerateList to generate listed XML elements
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp 2008-12-03 09:55:48 UTC (rev 8179)
+++ trunk/mapserver/mapagg.cpp 2008-12-03 10:19:39 UTC (rev 8180)
@@ -750,29 +750,40 @@
int renderGlyphs(double x, double y, agg::rgba8 &color, agg::rgba8 &outlinecolor,
double size, char *font, char *thechars, double angle,
agg::rgba8 &shadowcolor, double shdx, double shdy,
- int outlinewidth) {
+ int outlinewidth, bool isMarker=false) {
if(!m_feng.load_font(font, 0, agg::glyph_ren_outline)) {
msSetError(MS_TTFERR, "AGG error loading font (%s)", "renderGlyphs()", font);
return MS_FAILURE;
ras_aa.filling_rule(agg::fill_non_zero);
- agg::trans_affine mtx;
- mtx *= agg::trans_affine_translation(-x,-y);
- /*agg angles are antitrigonometric*/
- mtx *= agg::trans_affine_rotation(-angle);
- mtx *= agg::trans_affine_translation(x,y);
+ const agg::glyph_cache* glyph;
+ int unicode;
m_feng.hinting(true);
m_feng.height(size);
m_feng.resolution(96);
m_feng.flip_y(true);
font_curve_type m_curves(m_fman.path_adaptor());
- const agg::glyph_cache* glyph;
- int unicode;
+ double ox=0,oy=0;
+ if(isMarker) {
+ //is we're rendering a marker symbol, it has to be centered
+ //on the label point (the default is the lower left of the
+ //text)
+ //this block computes the offset between the lower left corner
+ //of the character and it's center for the given rotaion. this
+ //offset will then be used in the following agg::trans_affine_translation
+ msUTF8ToUniChar(thechars, &unicode);
+ glyph=m_fman.glyph(unicode);
+ ox=glyph->bounds.x1+(glyph->bounds.x2-glyph->bounds.x1)/2.;
+ oy=glyph->bounds.y1+(glyph->bounds.y2-glyph->bounds.y1)/2.;
+ agg::trans_affine_rotation(-angle).transform(&ox,&oy);
+ agg::trans_affine mtx;
+ mtx *= agg::trans_affine_translation(-x,-y);
+ /*agg angles are antitrigonometric*/
+ mtx *= agg::trans_affine_rotation(-angle);
+ mtx *= agg::trans_affine_translation(x-ox,y-oy);
double fx=x,fy=y;
const char *utfptr=thechars;
agg::path_storage glyphs;
@@ -1243,14 +1254,8 @@
case(MS_SYMBOL_TRUETYPE): {
char* font = msLookupHashTable(&(symbolset->fontset->fonts), symbol->font);
if(!font) return;
- double x,y;
- rectObj bounds;
- if(ren->getLabelSize(symbol->character,font,size,&bounds,NULL)!=MS_SUCCESS)
- return;
- x = p->x + ox - bounds.minx - (bounds.maxx-bounds.minx)/2.;
- y = p->y + oy - bounds.maxy + (bounds.maxy-bounds.miny)/2.;
- ren->renderGlyphs(x,y,agg_color,agg_ocolor,
- size,font,symbol->character,angle_radians,AGG_NO_COLOR,0,0,MS_NINT(style->width));
+ ren->renderGlyphs(p->x+ox,p->y+oy,agg_color,agg_ocolor,
+ size,font,symbol->character,angle_radians,AGG_NO_COLOR,0,0,MS_NINT(style->width),true);
break;
case(MS_SYMBOL_PIXMAP): {
More information about the mapserver-commits
