[mapserver-commits] r8183 - in trunk/docs: cgi howto
svn at osgeo.org
svn at osgeo.org
Wed Dec 3 10:29:32 EST 2008
Author: hobu
Date: 2008-12-03 10:29:32 -0500 (Wed, 03 Dec 2008)
New Revision: 8183
Added:
trunk/docs/cgi/wrapper.txt
Removed:
trunk/docs/howto/cgi-wrapper-script.txt
trunk/docs/cgi/index.txt
move the wrapper script howto into cgi section
Modified: trunk/docs/cgi/index.txt
--- trunk/docs/cgi/index.txt 2008-12-03 15:28:33 UTC (rev 8182)
+++ trunk/docs/cgi/index.txt 2008-12-03 15:29:32 UTC (rev 8183)
@@ -19,6 +19,7 @@
mapcontext
controls
runsub
+ wrapper
Copied: trunk/docs/cgi/wrapper.txt (from rev 8172, trunk/docs/howto/cgi-wrapper-script.txt)
--- trunk/docs/cgi/wrapper.txt (rev 0)
+++ trunk/docs/cgi/wrapper.txt 2008-12-03 15:29:32 UTC (rev 8183)
@@ -0,0 +1,67 @@
+.. _wrapper:
+ A Simple CGI Wrapper Script
+:Author: Steven Monai
+:Revision: $Revision$
+:Date: $Date$
+:Last Updated: 2006/01/26
+.. contents:: Table of Contents
+ :depth: 2
+ :backlinks: top
+Introduction
+This document presents a simple shell script that can be used to "wrap" the
+MapServer CGI, in order to avoid having to specify the 'map' parameter (or any
+other chosen parameters) in your MapServer URLs.
+Script Information
+If you want to avoid having to specify the 'map' parameter in your MapServer
+URLs, one solution is to use a "wrapper". Basically, a wrapper is a CGI program
+that receives an incoming CGI request, modifies the request parameters in some
+way, and then hands off the actual processing to another CGI program (e.g.
+MapServer).
+The following shell script is a wrapper for CGI GET requests that should be
+generic enough to run on any OS with /bin/sh:
+ #!/bin/sh
+ MAPSERV="/path/to/my/mapserv"
+ MAPFILE="/path/to/my/mapfile.map"
+ if [ "${REQUEST_METHOD}" = "GET" ]; then
+ if [ -z "${QUERY_STRING}" ]; then
+ QUERY_STRING="map=${MAPFILE}"
+ else
+ QUERY_STRING="map=${MAPFILE}&${QUERY_STRING}"
+ fi
+ exec ${MAPSERV}
+ else
+ echo "Sorry, I only understand GET requests."
+ fi
+ exit 1
+ # End of Script
+You should set the MAPSERV and MAPFILE variables as appropriate for your
+configuration. MAPSERV points to your MapServer executable, and MAPFILE points
+to the mapfile you want MapServer to use. Both variables should be absolute
+file paths that your webserver has permission to access, although they need not
+(and probably should not) be in web-accessible locations. Then put the script
+in your web server's cgi-bin directory, and make it executable.
+Although this script only sets the 'map' parameter, it is easily modified to
+set any number of other MapServer parameters as well. For example, if you want
+to force your MapServer to 'map' mode, you can simply add 'mode=map' to the
+front of the QUERY_STRING variable. Just remember to separate your parameters
+with ampersands ('&').
+Finally, note that the script only works for GET requests.
Deleted: trunk/docs/howto/cgi-wrapper-script.txt
--- trunk/docs/howto/cgi-wrapper-script.txt 2008-12-03 15:28:33 UTC (rev 8182)
+++ trunk/docs/howto/cgi-wrapper-script.txt 2008-12-03 15:29:32 UTC (rev 8183)
@@ -1,66 +0,0 @@
- A Simple CGI Wrapper Script
-:Author: Steven Monai
-:Revision: $Revision$
-:Date: $Date$
-:Last Updated: 2006/01/26
-.. sectnum::
-.. contents:: Table of Contents
- :depth: 2
- :backlinks: top
-Introduction
-This document presents a simple shell script that can be used to "wrap" the
-MapServer CGI, in order to avoid having to specify the 'map' parameter (or any
-other chosen parameters) in your MapServer URLs.
-Script Information
-If you want to avoid having to specify the 'map' parameter in your MapServer
-URLs, one solution is to use a "wrapper". Basically, a wrapper is a CGI program
-that receives an incoming CGI request, modifies the request parameters in some
-way, and then hands off the actual processing to another CGI program (e.g.
-MapServer).
-The following shell script is a wrapper for CGI GET requests that should be
-generic enough to run on any OS with /bin/sh:
- #!/bin/sh
- MAPSERV="/path/to/my/mapserv"
- MAPFILE="/path/to/my/mapfile.map"
- if [ "${REQUEST_METHOD}" = "GET" ]; then
- if [ -z "${QUERY_STRING}" ]; then
- QUERY_STRING="map=${MAPFILE}"
- else
- QUERY_STRING="map=${MAPFILE}&${QUERY_STRING}"
- fi
- exec ${MAPSERV}
- else
- echo "Sorry, I only understand GET requests."
- fi
- exit 1
- # End of Script
-You should set the MAPSERV and MAPFILE variables as appropriate for your
-configuration. MAPSERV points to your MapServer executable, and MAPFILE points
-to the mapfile you want MapServer to use. Both variables should be absolute
-file paths that your webserver has permission to access, although they need not
-(and probably should not) be in web-accessible locations. Then put the script
-in your web server's cgi-bin directory, and make it executable.
-Although this script only sets the 'map' parameter, it is easily modified to
-set any number of other MapServer parameters as well. For example, if you want
-to force your MapServer to 'map' mode, you can simply add 'mode=map' to the
-front of the QUERY_STRING variable. Just remember to separate your parameters
-with ampersands ('&').
-Finally, note that the script only works for GET requests.
More information about the mapserver-commits
