[mapserver-commits] r8194 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Dec 4 13:36:59 EST 2008
Author: tomkralidis
Date: 2008-12-04 13:36:59 -0500 (Thu, 04 Dec 2008)
New Revision: 8194
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapwms.c
cleanup warnings with recent gcc versions (#2822)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-12-04 18:04:34 UTC (rev 8193)
+++ trunk/mapserver/HISTORY.TXT 2008-12-04 18:36:59 UTC (rev 8194)
@@ -12,6 +12,8 @@
Current Version (5.3-dev, SVN trunk):
+- mapwms.c: cleanup warnings with recent gcc versions (#2822)
- mapogcsos.c: Cleanup warning and error messages
- mapagg.cpp: Fix center of rotation for truetype marker symbols
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c 2008-12-04 18:04:34 UTC (rev 8193)
+++ trunk/mapserver/mapwms.c 2008-12-04 18:36:59 UTC (rev 8194)
@@ -648,7 +648,7 @@
** Validate first against epsg in the map and if no matching srs is found
** validate all layers requested.
- if (epsgbuf && strlen(epsgbuf) > 1)
+ if (epsgbuf != NULL && strlen(epsgbuf) > 1)
epsgvalid = MS_FALSE;
projstring = msOWSGetEPSGProj(&(map->projection), &(map->web.metadata),
@@ -747,7 +747,7 @@
** have a projection. This will prevent problems when users forget to
** explicitly set a projection on all layers in a WMS mapfile.
- if ((srsbuffer && strlen(srsbuffer) > 1) || nonsquare_enabled)
+ if ((srsbuffer != NULL && strlen(srsbuffer) > 1) || nonsquare_enabled)
projectionObj newProj;
@@ -761,7 +761,7 @@
msInitProjection(&newProj);
- if (srsbuffer && strlen(srsbuffer) > 1 &&
+ if (srsbuffer != NULL && strlen(srsbuffer) > 1 &&
msLoadProjectionString(&newProj, srsbuffer) != 0)
msFreeProjection(&newProj);
@@ -803,7 +803,7 @@
/* apply the srs to the map file. This is only done after validating */
/* that the srs given as parameter is valid for all layers */
- if (srsbuffer && strlen(srsbuffer) > 1)
+ if (srsbuffer != NULL && strlen(srsbuffer) > 1)
if (msLoadProjectionString(&(map->projection), srsbuffer) != 0)
return msWMSException(map, nVersion, NULL);
More information about the mapserver-commits
