[mapserver-commits] r8202 - in trunk/docs: mapfile ogc
svn at osgeo.org
svn at osgeo.org
Sun Dec 7 17:43:56 EST 2008
Author: hobu
Date: 2008-12-07 17:43:55 -0500 (Sun, 07 Dec 2008)
New Revision: 8202
trunk/docs/mapfile/class.txt
trunk/docs/ogc/wms_server.txt
formatting
Modified: trunk/docs/mapfile/class.txt
--- trunk/docs/mapfile/class.txt 2008-12-07 22:08:52 UTC (rev 8201)
+++ trunk/docs/mapfile/class.txt 2008-12-07 22:43:55 UTC (rev 8202)
@@ -97,6 +97,8 @@
.. index::
pair: KEYIMAGE; CLASS
+.. _KEYIMAGE:
KEYIMAGE [filename]
Full filename of the legend image for the :ref:`CLASS`. This image is used
Modified: trunk/docs/ogc/wms_server.txt
--- trunk/docs/ogc/wms_server.txt 2008-12-07 22:08:52 UTC (rev 8201)
+++ trunk/docs/ogc/wms_server.txt 2008-12-07 22:43:55 UTC (rev 8202)
@@ -465,12 +465,14 @@
3. On IIS servers (Windows), you can use the following ASP script:
- *Note that the script below, while functional, is intended only as an example of
- using ASP to filter Mapserver requests. Using ASP in a production WMS server will
- likely require additional ASP especially in the area of error handling and setting
- timeouts.*
+ .. note::
+ The script below, while functional, is intended only as an example of
+ using ASP to filter Mapserver requests. Using ASP in a production WMS
+ server will likely require additional ASP especially in the area of
+ error handling and setting timeouts.*
+ .. code-block:: guess
Server.ScriptTimeout = 360
@@ -540,13 +542,14 @@
- **RULE** - (Optional) Specify the name of the CLASS to generate the legend image
for (as opposed to generating an icon and label for ALL classes for the layer).
-Note that all rules that are used to draw the legend in normal CGI mode apply here.
-See the :ref:`CGI Reference doc <cgi>` if necessary.
+.. note::
-The :ref:`CLASS` object's KEYIMAGE parameter can also be used to specify a legend image for a
-CLASS. See the :ref:`MapFile Reference doc <mapfile>` if necessary.
-Example Request
+ All rules that are used to draw the legend in normal CGI mode apply here.
+ See the :ref:`CGI Reference doc <cgi>` if necessary.
+The :ref:`CLASS` object's KEYIMAGE parameter can also be used to specify a
+legend image for a CLASS. See the :ref:`MapFile Reference doc <mapfile>` if
+necessary. Example Request
An example request might look like:
@@ -572,11 +575,18 @@
**ows_http_max_age**
-- *Description:* (Optional) an integer (in seconds) to specify how long a given map response should be considered new. Setting this directive allows for aware WMS clients to use this resulting HTTP header value as a means to optimize (and minimize) requests to a WMS Server. More info is available at http://www.mnot.net/cache_docs/#CACHE-CONTROL
+- *Description:* (Optional) an integer (in seconds) to specify how long a
+ given map response should be considered new. Setting this directive allows
+ for aware WMS clients to use this resulting HTTP header value as a means to
+ optimize (and minimize) requests to a WMS Server. More info is available at
+ http://www.mnot.net/cache_docs/#CACHE-CONTROL
**ows_updatesequence**
-- *Description:* (Optional) The updateSequence parameter can be used for maintaining the consistency of a client cache of the contents of a service metadata document. The parameter value can be an integer, a timestamp in [ISO 8601:2000] format, or any other number or string.
+- *Description:* (Optional) The updateSequence parameter can be used for
+ maintaining the consistency of a client cache of the contents of a service
+ metadata document. The parameter value can be an integer, a timestamp in
+ [ISO 8601:2000] format, or any other number or string.
**ows_schemas_location**
@@ -591,42 +601,44 @@
**wms_abstract**
- *WMS TAG Name:* Abstract (WMS1.1.1, sect. 7.1.4.2)
-- *Description:* (Optional) A blurb of text providing more information about the WMS server.
+- *Description:* (Optional) A blurb of text providing more information about
+ the WMS server.
**wms_accessconstraints**
- *WMS TAG Name:* AccessConstraints (WMS1.1.1, sect. 7.1.4.2)
-- *Description:* (Optional) Access constraints information. Use the reserved word "none"
- if there are no access constraints.
+- *Description:* (Optional) Access constraints information. Use the reserved
+ word "none" if there are no access constraints.
**wms_addresstype, wms_address, wms_city, wms_stateorprovince, wms_postcode, wms_country**
- *WMS TAG Name:* ContactAddress and family (WMS1.1.1, sect. 7.1.4.2)
-- *Description:* Optional contact address information. If provided then all six metadata
- items are required.
+- *Description:* Optional contact address information. If provided then all
+ six metadata items are required.
**wms_attribution_logourl_format**
-- *Description:* (Optional) The MIME type of the logo image. (e.g. "image/png"). Note that
- the other wms_attribution_logourl_* metadata must also be specified.
+- *Description:* (Optional) The MIME type of the logo image. (e.g.
+ "image/png"). Note that the other wms_attribution_logourl_* metadata must
+ also be specified.
- refer to section 7.1.4.5.11 of the WMS 1.1.1 spec.
**wms_attribution_logourl_height**
-- *Description:* (Optional) Height of the logo image in pixels. Note that the other
- wms\_attribution_logourl\_\* metadata must also be specified.
+- *Description:* (Optional) Height of the logo image in pixels. Note that the
+ other wms\_attribution_logourl\_\* metadata must also be specified.
**wms_attribution_logourl_href**
-- *Description:* (Optional) URL of the logo image. Note that the other wms_attribution_logourl\_\*
- metadata must also be specified.
+- *Description:* (Optional) URL of the logo image. Note that the other
+ wms_attribution_logourl\_\* metadata must also be specified.
**wms_attribution_logourl_width**
-- *Description:* (Optional) Width of the logo image in pixels. Note that the other
- wms_attribution_logourl\_\* metadata must also be specified.
+- *Description:* (Optional) Width of the logo image in pixels. Note that the
+ other wms_attribution_logourl\_\* metadata must also be specified.
**wms_attribution_onlineresource**
@@ -651,8 +663,8 @@
**wms_contactperson, wms_contactorganization, wms_contactposition**
-- *WMS TAG Name:* ContactInformation, ContactPerson, ContactOrganization, ContactPosition
- (WMS1.1.1, sect. 7.1.4.2)
+- *WMS TAG Name:* ContactInformation, ContactPerson, ContactOrganization,
+ ContactPosition (WMS1.1.1, sect. 7.1.4.2)
- *Description:* Optional contact information. If provided then all three metadata
items are required.
@@ -664,79 +676,83 @@
**wms_encoding**
- *WMS TAG Name:* Encoding
-- *Description:* Optional XML capabilities encoding type. The default is ISO-8859-1.
+- *Description:* Optional XML capabilities encoding type. The default is
+ ISO-8859-1.
**wms_feature_info_mime_type**
- *WMS TAG Name:* Feature_info_mime_type
- *Description:*
- - Used to specify an additional MIME type that can be used when responding to the
- GetFeature request.
+ - Used to specify an additional MIME type that can be used when responding
+ to the GetFeature request.
- For example if you want to use the layer's HTML template as a base for its
- response, you need to add "WMS_FEATURE_INFO_MIME_TYPE" "text/html". Setting
- this will have the effect of advertizing text/html as one of the MIME types
- supported for a GetFeature request. You also need to make sure that the layer
- points to a valid html template. The client can then call the server with
- INFO_FORMAT=text/html.
+ For example if you want to use the layer's HTML template as a base for its
+ response, you need to add "WMS_FEATURE_INFO_MIME_TYPE" "text/html".
+ Setting this will have the effect of advertizing text/html as one of the
+ MIME types supported for a GetFeature request. You also need to make sure
+ that the layer points to a valid html template. The client can then call
+ the server with INFO_FORMAT=text/html.
- If not specified, MapServer by default has text/plain and GML implemented.
- - Note that for GML to be returned the layer in the wms-server mapfile must be set
- to DUMP TRUE.
+ - Note that for GML to be returned the layer in the wms-server mapfile must
+ be set to DUMP TRUE.
**wms_fees**
- *WMS TAG Name:* Fees (WMS1.1.1, sect. 7.1.4.2)
-- *Description:* (Optional) Fees information. Use the reserved word "none" if there
- are no fees.
+- *Description:* (Optional) Fees information. Use the reserved word "none" if
+ there are no fees.
**wms_keywordlist**
- *WMS TAG Name:* KeywordList (WMS1.1.1, sect. 7.1.4.2)
-- *Description:* (Optional) A comma-separated list of keywords or keyword phrases to
- help catalog searching. As of WMS 1.1.0 no controlled vocabulary has been defined.
+- *Description:* (Optional) A comma-separated list of keywords or keyword
+ phrases to help catalog searching. As of WMS 1.1.0 no controlled vocabulary
+ has been defined.
**wms_onlineresource**
- *WMS TAG Name:* OnlineResource (WMS1.1.1, sect. 6.2.2)
-- *Description:* (Recommended) The URL that will be used to access this WMS server.
- This value is used in the GetCapabilities response.
-- See Also: sections "Setup a Mapfile / wms_onlineresource metadata" and "More About the Online
- Resource URL" above.
+- *Description:* (Recommended) The URL that will be used to access this WMS
+ server. This value is used in the GetCapabilities response.
+- See Also: sections "Setup a Mapfile / wms_onlineresource metadata" and "More
+ About the Online Resource URL" above.
**wms_resx, wms_resy**
- *WMS TAG Name:* BoundingBox (WMS1.1.1, sect. 6.5.6)
-- *Description:* (Optional) Used in the BoundingBox tag to provide info about spatial
- resolution of the data, values are in map projection units.
+- *Description:* (Optional) Used in the BoundingBox tag to provide info about
+ spatial resolution of the data, values are in map projection units.
**wms_service_onlineresource**
-- *Description:* (Optional) Top-level onlineresource URL. MapServer uses the
+- *Description:* (Optional) Top-level onlineresource URL. MapServer uses the
onlineresource metadata (if provided) in the following order:
1. wms_service_onlineresource
2. ows_service_onlineresource
- 3. wms_onlineresource (or automatically generated URL, see the onlineresource section
- of this document)
+ 3. wms_onlineresource (or automatically generated URL, see the
+ onlineresource section of this document)
**wms_srs**
- *WMS TAG Name:* SRS (WMS1.1.1, sect. 6.5.5)
-- *Description:* (Recommended) Contains a list of EPSG projection codes that should be
- advertized as being available for all layers in this server. The value can contain
- one or more EPSG:<code> pairs separated by spaces (e.g. "EPSG:4269 EPSG:4326") This
- value should be upper case (EPSG:42304.....not epsg:42304) to avoid problems with case
- sensitive platforms.
-- See Also: section "Setup a Mapfile / Map PROJECTION and wms_srs metadata" above.
+- *Description:* (Recommended) Contains a list of EPSG projection codes that
+ should be advertized as being available for all layers in this server. The
+ value can contain one or more EPSG:<code> pairs separated by spaces (e.g.
+ "EPSG:4269 EPSG:4326") This value should be upper case (EPSG:42304.....not
+ epsg:42304) to avoid problems with case sensitive platforms.
+- See Also: section "Setup a Mapfile / Map PROJECTION and wms_srs metadata"
+ above.
**wms_timeformat**
-- *Description:* The time format to be used when a request is sent. (e.g. "wms_timeformat"
- "%Y-%m-%d %H, %Y-%m-%d %H:%M"). Please see the :ref:`WMS Time Support HowTo <wms_time>` for more information.
+- *Description:* The time format to be used when a request is sent. (e.g.
+ "wms_timeformat" "%Y-%m-%d %H, %Y-%m-%d %H:%M"). Please see the :ref:`WMS
+ Time Support HowTo <wms_time>` for more information.
**wms_title**
@@ -748,12 +764,12 @@
**gml_exclude_items**
-- *Description:* (Optional, applies only to GetFeatureInfo GML requests) A comma
- delimited list of items to exclude. As of MapServer 4.6, you can control
- how many attributes (fields) you expose for your data layer with metadata.
- The previous behaviour was simply to expose all attributes all of the time.
- The default is to expose no attributes at all. An example excluding a specific
- field would be:
+- *Description:* (Optional, applies only to GetFeatureInfo GML requests) A
+ comma delimited list of items to exclude. As of MapServer 4.6, you can
+ control how many attributes (fields) you expose for your data layer with
+ metadata. The previous behaviour was simply to expose all attributes all of
+ the time. The default is to expose no attributes at all. An example
+ excluding a specific field would be:
@@ -780,11 +796,12 @@
**gml_include_items**
-- *Description:* (Optional, applies only to GetFeatureInfo GML requests) A comma delimited
- list of items to include, or keyword "all". As of MapServer 4.6, you can control how
- many attributes (fields) you expose for your data layer with this metadata. The previous
- behaviour was simply to expose all attributes all of the time. You can enable full exposure
- by using the keyword "all", such as:
+ comma delimited list of items to include, or keyword "all". As of MapServer
+ 4.6, you can control how many attributes (fields) you expose for your data
+ layer with this metadata. The previous behaviour was simply to expose all
+ attributes all of the time. You can enable full exposure by using the
+ keyword "all", such as:
@@ -800,9 +817,9 @@
**gml_[item name]_alias**
-- *Description:* (Optional, applies only to GetFeatureInfo GML requests) An alias
- for an attribute's name. The served GML will refer to this attribute by the alias.
- Here is an example:
+- *Description:* (Optional, applies only to GetFeatureInfo GML requests) An
+ alias for an attribute's name. The served GML will refer to this attribute
+ by the alias. Here is an example:
@@ -810,13 +827,14 @@
**gml_[item name]_type**
-- *Description:* (Optional, applies only to GetFeatureInfo GML requests) Specifies
- the type of the attribute. Valid values are Integer|Real|Character|Date|Boolean.
+ Specifies the type of the attribute. Valid values are
+ Integer|Real|Character|Date|Boolean.
**gml_xml_items**
- delimited list of items that should not be XML-encoded.
+ comma delimited list of items that should not be XML-encoded.
**wms_abstract**
@@ -824,26 +842,27 @@
@@ -871,31 +890,34 @@
**wms_extent**
-- *Description:* (Optional) Used for the layer's BoundingBox tag for cases where it
- is impossible (or very inefficient) for MapServer to probe the data source to figure
- its extents. The value for this metadata is "minx miny maxx maxy" separated by
- spaces, with the values in the layer's projection units. If wms_extent is provided
- then it has priority and MapServer will NOT try to read the source file's extents.
+- *Description:* (Optional) Used for the layer's BoundingBox tag for cases
+ where it is impossible (or very inefficient) for MapServer to probe the data
+ source to figure its extents. The value for this metadata is "minx miny maxx
+ maxy" separated by spaces, with the values in the layer's projection units.
+ If wms_extent is provided then it has priority and MapServer will NOT try to
+ read the source file's extents.
- For Rasters served through WMS, MapServer can now use the wms_extent metadata
- parameter to register the image. If a .wld file cannot be found, MapServer will
- then look for the wms_extent metadata parameter and use the extents of the image
- and the size of the image for georegistration.
+ For Rasters served through WMS, MapServer can now use the wms_extent
+ metadata parameter to register the image. If a .wld file cannot be found,
+ MapServer will then look for the wms_extent metadata parameter and use the
+ extents of the image and the size of the image for georegistration.
**wms_group_abstract**
-- *Description:* (Optional) A blurb of text providing more information about the group.
- Only one layer for the group needs to contain wms_group_abstract, MapServer will
- find and use the value. The value found for the first layer in the group is used. So
- if multiple layers have wms_group_abstract set then only the first value is used.
+ the group. Only one layer for the group needs to contain wms_group_abstract,
+ MapServer will find and use the value. The value found for the first layer
+ in the group is used. So if multiple layers have wms_group_abstract set then
+ only the first value is used.
**wms_group_title**
- *WMS TAG Name:* Group_title (WMS1.1.1, sect. 7.1.4.1)
-- *Description:* (Optional) A human-readable name for the group that this layer belongs to.
- Only one layer for the group needs to contain wms_group_title, MapServer will find and use
- the value. The value found for the first layer in the group is used. So if multiple layers
- have wms_group_title set then only the first value is used.
+- *Description:* (Optional) A human-readable name for the group that this
+ layer belongs to. Only one layer for the group needs to contain
+ wms_group_title, MapServer will find and use the value. The value found for
+ the first layer in the group is used. So if multiple layers have
+ wms_group_title set then only the first value is used.
**wms_keywordlist**
@@ -903,19 +925,21 @@
**wms_layer_group**
-- *Description:* (Optional) Can be used to assign a layer to a number of hierarchically
- nested groups. This grouped hierarchy will be expressed in the capabilities.
+- *Description:* (Optional) Can be used to assign a layer to a number of
+ hierarchically nested groups. This grouped hierarchy will be expressed in
+ the capabilities.
- WMS_LAYER_GROUP is different from the GROUP keyword in that it does not publish
- the name of the group in the capabilities, only the title. As a consequence the
- groups set with WMS_LAYER_GROUP can not be requested with a GetMap or GetFeatureInfo
- request (see section 7.1.4.5.2 of the WMS implementation specification version 1.1.1.
- (OGC 01-068r2)). Another difference is that GROUP does not support nested groups.
- The purpose of this metadata setting is to enable making a WMS client aware of layer
- grouping.
+ WMS_LAYER_GROUP is different from the GROUP keyword in that it does not
+ publish the name of the group in the capabilities, only the title. As a
+ consequence the groups set with WMS_LAYER_GROUP can not be requested with a
+ GetMap or GetFeatureInfo request (see section 7.1.4.5.2 of the WMS
+ implementation specification version 1.1.1. (OGC 01-068r2)). Another
+ difference is that GROUP does not support nested groups. The purpose of this
+ metadata setting is to enable making a WMS client aware of layer grouping.
- All group names should be preceded by a forward slash (/). It is not allowed to use
- both the WMS_LAYER_GROUP setting and the GROUP keyword for a single layer.
+ All group names should be preceded by a forward slash (/). It is not allowed
+ to use both the WMS_LAYER_GROUP setting and the GROUP keyword for a single
+ layer.
@@ -936,32 +960,33 @@
**wms_metadataurl_format**
-- *Description:* (Optional) The file format MIME type of the metadata record (e.g.
- "text/plain"). The layer metadata wms_metadataurl_type and wms_metadataurl_href must
- also be specified.
+- *Description:* (Optional) The file format MIME type of the metadata record
+ (e.g. "text/plain"). The layer metadata wms_metadataurl_type and
+ wms_metadataurl_href must also be specified.
- refer to section 7.1.4.5.10 of the WMS 1.1.1 spec.
**wms_metadataurl_href**
-- *Description:* (Optional) The URL to the layer's metadata. The layer metadata
- wms_metadataurl_format and wms_metadataurl_type must also be specified.
+- *Description:* (Optional) The URL to the layer's metadata. The layer
+ metadata wms_metadataurl_format and wms_metadataurl_type must also be
+ specified.
**wms_metadataurl_type**
-- *Description:* (Optional) The standard to which the metadata complies. Currently
- only two types are valid: "TC211" which refers to [ISO 19115], and "FGDC" which
- refers to [FGDC-STD-001-1988]. The layer metadata wms_metadataurl_format and
- wms_metadataurl_href must also be specified.
+- *Description:* (Optional) The standard to which the metadata complies.
+ Currently only two types are valid: "TC211" which refers to [ISO 19115], and
+ "FGDC" which refers to [FGDC-STD-001-1988]. The layer metadata
+ wms_metadataurl_format and wms_metadataurl_href must also be specified.
**wms_opaque**
- *WMS TAG Name:* Opaque (WMS1.1.1, sect. 7.1.4.6.3)
-- *Description:* (Optional) Set this metadata to "1" to indicate that the layer
- represents an area-filling coverage of space (e.g. a bathymetry and elevation layer).
- This should be taken by the client as a hint that this layer should be placed at
- the bottom of the stack of layers.
+- *Description:* (Optional) Set this metadata to "1" to indicate that the
+ layer represents an area-filling coverage of space (e.g. a bathymetry and
+ elevation layer). This should be taken by the client as a hint that this
+ layer should be placed at the bottom of the stack of layers.
**wms_srs**
@@ -969,55 +994,63 @@
**wms_style**
-- *Description:* (Optional) The LegendURL style name. Requires the following metadata:
- wms_style_<style's_name>_width, wms_style_<style's_name>_legendurl_height,
- wms_style_<style's_name>_legendurl_format, wms_style_<style's_name>_legendurl_href
+- *Description:* (Optional) The LegendURL style name. Requires the following
+ metadata: wms_style_<style's_name>_width,
+ wms_style_<style's_name>_legendurl_height,
+ wms_style_<style's_name>_legendurl_format,
+ wms_style_<style's_name>_legendurl_href
- refer to section 7.1.4.5.4 of the WMS 1.1.1 spec.
**wms_style_<style's_name>_legendurl_height**
-- *Description:* (Optional) The height of the legend image in pixels. Requires the
- following metadata: wms_style_<style's_name>_width, wms_style,
- wms_style_<style's_name>_legendurl_format, wms_style_<style's_name>_legendurl_href.
+- *Description:* (Optional) The height of the legend image in pixels. Requires
+ the following metadata: wms_style_<style's_name>_width, wms_style,
+ wms_style_<style's_name>_legendurl_href.
**wms_style_<style's_name>_legendurl_href**
-- *Description:* (Optional) The URL to the layer's legend. Requires the following
- metadata: wms_style_<style's_name>_width, wms_style_<style's_name>_legendurl_height,
+- *Description:* (Optional) The URL to the layer's legend. Requires the
+ following metadata: wms_style_<style's_name>_width,
wms_style_<style's_name>_legendurl_format, wms_style.
**wms_style_<style's_name>_legendurl_format**
-- *Description:* (Optional) The file format MIME type of the legend image. Requires the
- following metadata: wms_style_<style's_name>_width, wms_style_<style's_name>_legendurl_height,
- wms_style, wms_style_<style's_name>_legendurl_href.
+- *Description:* (Optional) The file format MIME type of the legend image.
+ Requires the following metadata: wms_style_<style's_name>_width,
+ wms_style_<style's_name>_legendurl_height, wms_style,
**wms_style_<style's_name>_legendurl_width**
-- *Description:* (Optional) The width of the legend image in pixels. Requires the
- following metadata: wms_style_<style's_name>_format, wms_style_<style's_name>_legendurl_height,
+- *Description:* (Optional) The width of the legend image in pixels. Requires
+ the following metadata: wms_style_<style's_name>_format,
**wms_timedefault**
-- *Description:* (Optional for Time Support) This value is used if it is defined
- and the Time value is missing in the request. Please see the :ref:`WMS Time Support HowTo <wms_time>`
- for more information.
+- *Description:* (Optional for Time Support) This value is used if it is
+ defined and the Time value is missing in the request. Please see the
+ :ref:`WMS Time Support HowTo <wms_time>` for more information.
**wms_timeextent**
-- *Description:* (Mandatory for Time Support) This is used in the capabilities to return
- the valid time values for the layer. The value defined here should be a valid time range.
- Please see the :ref:`WMS Time Support HowTo <wms_time>` for more information.
+- *Description:* (Mandatory for Time Support) This is used in the capabilities
+ to return the valid time values for the layer. The value defined here should
+ be a valid time range. Please see the :ref:`WMS Time Support HowTo
+ <wms_time>` for more information.
**wms_timeitem**
-- *Description:* (Mandatory for Time Support) This is the name of the field in the DB that
- contains the time values. Please see the :ref:`WMS Time Support HowTo <wms_time>` for more information.
+- *Description:* (Mandatory for Time Support) This is the name of the field in
+ the DB that contains the time values. Please see the :ref:`WMS Time Support
+ HowTo <wms_time>` for more information.
**wms_title**
More information about the mapserver-commits
