[mapserver-commits] r8216 - in trunk/docs: input/vector output
svn at osgeo.org
svn at osgeo.org
Tue Dec 9 02:03:52 EST 2008
Author: hobu
Date: 2008-12-09 02:03:52 -0500 (Tue, 09 Dec 2008)
New Revision: 8216
trunk/docs/input/vector/index.txt
trunk/docs/output/svg.txt
can only have 3 levels of headings or latex can't build
Modified: trunk/docs/input/vector/index.txt
--- trunk/docs/input/vector/index.txt 2008-12-09 07:03:29 UTC (rev 8215)
+++ trunk/docs/input/vector/index.txt 2008-12-09 07:03:52 UTC (rev 8216)
@@ -32,46 +32,7 @@
From: http://coris.noaa.gov/glossary/glossary_l_z.html#v
-MapServer can access vector file formats and database connections. It can also
-access raster or image data. This is a summary of the vector and database
-formats with particular focus on how to use them in a MapServer map file and
-access them using command line tools like **ogrinfo**.
-MapServer and vector data access
-MapServer has two main methods for accessing data:
-* Through built-in, format-specific, data access capabilities.
-.. note::
- The most basic form of data access uses the built-in capabilities
- that were linked into MapServer when it was compiled. These
- capabilities are limited to only a few types of vector data,
- such as ESRI Shapefile, PostGIS, Oracle Spatial and ArcSDE. The
- default, built-in, format for MapServer is the ESRI Shapefile format.
-* Using the capabilities of third-party data access libraries.
-.. note::
- One of the most powerful features of MapServer is the ability to use data
- formats through a pseudo plug-in environment. The most significant
- third party library being used is GDAL/OGR. This includes raster
- (GDAL) and vector (OGR) data.
-Using OGR
-OGR is used behind the scenes by MapServer when requested. MapServer does not
-require OGR in order to run. Some users may never need the additional
-capabilities OGR offers, but many users find them absolutely necessary. Because
-MapServer is capable of accessing data via OGR, there is less need to program
-specific types of data format support directly into MapServer. Instead, further
-additions can be made to OGR and then be used by MapServer. In essence, the
-background libraries allow MapServer to bring the data into an internal,
-memory-based format that MapServer can use. For the most part, using
-OGR-related formats is seamless and intuitive.
.. toctree::
:maxdepth: 1
Modified: trunk/docs/output/svg.txt
--- trunk/docs/output/svg.txt 2008-12-09 07:03:29 UTC (rev 8215)
+++ trunk/docs/output/svg.txt 2008-12-09 07:03:52 UTC (rev 8216)
@@ -322,7 +322,7 @@
Specific FORMATOPTIONs Related to goSVG
GOSVG
should be set to TRUE. The default is false.
More information about the mapserver-commits
