[mapserver-commits] r8230 - in trunk/docs: howto installation
    svn at osgeo.org
    svn at osgeo.org
    Tue Dec  9 21:19:05 EST 2008
Author: hobu
Date: 2008-12-09 21:19:05 -0500 (Tue, 09 Dec 2008)
New Revision: 8230
Added:
   trunk/docs/installation/oracle.txt
Removed:
   trunk/docs/howto/Configure Oracle and UMN.txt
   trunk/docs/installation/index.txt
move to installation directory
Deleted: trunk/docs/howto/Configure Oracle and UMN.txt
--- trunk/docs/howto/Configure Oracle and UMN.txt	2008-12-10 02:18:26 UTC (rev 8229)
+++ trunk/docs/howto/Configure Oracle and UMN.txt	2008-12-10 02:19:05 UTC (rev 8230)
@@ -1,258 +0,0 @@
-.. _oci_install:
- Oracle Installation
-:Author: Till Adams
-:Last Updated: 2007/02/16
-.. contents:: Table of Contents
-    :depth: 2
-    :backlinks: top
-.. index::
-    pair: Oracle, install
-Preface
-This document explains the whole configuration needed to get the connect
-between MapServer :ref:`cgi` and an Oracle database server on a linux (Ubuntu)
-box. The aim of this document is just to put a lot of googled knowledge in ONE
-place. Hopefully it will preserve many of people spending analog amount of
-time than I did!
-This manual was written, because I spent several days googling around to get
-my UMN having access to an oracle database. I'm NOT an oracle expert, so the
-aim of this document is just to put a lot of googled knowledge in ONE place.
-Hopefully it will preserve many of people spending analog amount of time than
-I did! (Or: If you have the choice: Try :ref:`PostGIS <input_postgis>` ;-))
-Before we start, some basic knowledge, I didn't know before:
-* Mapserver can access oracle spatial as well as geodata from any oracle
-  locator installation! Oracle locator comes with every oracle instance, there
-  is no need for an extra license.
-* There is no need for further installation of any packages beside
-  oracle/oracle OCI
-System Assumptions
-We assume that Oracle is already installed, there is a database and there is
-some geodata in the database. The following paths should be known by the
-reader:
-* ORACLE_HOME
-* ORACLE_SID
-* ORACLE_BASE
-* LD_LIBRARY_PATH
-We also assume that you have installed **apache2** (our version was 2.0.49)
-and you are used to work with Linux/UNIX systems. We also think you are able
-to handle the editor :ref:`vi/vim <vim>`.
-We ensure that the Oracle user who later accesses the database has
-write-access to the oracle_home directory.
-We also assume, that you already have setup the tnsnames.ora file. It should
-look like that:
-    MY_ORACLE =
-        (DESCRIPTION =
-            (ADDRESS = (PROTOCOL = TCP)(HOST = host)(PORT = 1521))
-            (CONNECT_DATA =
-                (SERVICE_NAME = your_name)
-It is important that you know the NAME of the datasource, in this example this
-is "MY_ORACLE" and will be used further on. Done that, you're fine using
-``User/Password at MY_ORACLE`` in your mapfile to connect to the oracle database.
-But first we have to do some more stuff.
-Compile MapServer
-Compile as normal compilation and set this flag:
-    --with-oraclespatial=/path/to/oracle/home/</p>
-If MapServer configure and make runs well, try
-    ./mapserv -v
-This should at least give this output:
-    INPUT=ORACLESPATIAL
-If you got that, you're fine from the MapServer point of view.
-Set Environment Variables
-It is important to set all environment variables correctly. There are one the
-one hand system-wide environment variables to be set, on the other hand there
-should be set some for the cgi-directory in your Apache configuration.
-System Variables
-On Ubuntu (and on many other systems) there is the file "/etc/profile" which
-sets environment variables for all users on the system (you may also dedicate
-user-specific environment variables by editing the users ".profile" file in
-their home directory, but usually the oracle database users are not users of
-the system with their own home)
-Set the following variables:
-    $ cd /etc
-    $ echo export ORACLE_HOME=/path/to/oracle/home >> /etc/profile
-    # **(e.g. ORACLE_HOME=/app/oracle/ora10g)
-    $ echo export ORACLE_BASE=path/to/oracle >> /etc/profile
-    # **(e.g. ORACLE_HOME=/app/oracle)
-    $ echo export ORACLE_SID=MY_ORACLE >> /etc/profile
-    $ echo export LD_LIBRARY_PATH=path/to/oracle/home/lib >> /etc/profile
-    # **(e.g. ORACLE_HOME=/app/oracle/ora10g/lib)
-The command comes silent, so there is no system output if you didn't mistype
-anything!
-Setting the Apache Environment
-Sometimes it is confusing WHERE to set WHAT in the splitted
-apache2.conf-files. In the folder "/etc/apache2/sites_available" you find your
-sites-file. If you did not do sth. Special e.g. installing virtual hosts, the
-file is named "default". In this file, the apache cgi-directory is defined.
-Our file looks like this:
-    ScriptAlias /cgi-bin/ /var/www/cgi-bin/
-    <Directory "/var/www/cgi-bin">
-           AllowOverride None
-           Options ExecCGI -MultiViews +SymLinksIfOwnerMatch
-           Order allow,deny
-           Allow from all
-    </Directory></p>
-In this file, the local apache
-environment variables must be set. We did it within a location-block
-like this:
-    <Location "/cgi-bin/">
-        SetEnv ORACLE_HOME "/path/to/oracle/home"
-    </Location></p>
-Where /cgi-bin/ in the opening location block refers to the script alias
-/cgi-bin/ and the TNS_ADMIN directory point to the location of the
-tnsnames.ora file.
-Then restart apache:
-    $ /etc/init.d/apache2 force-reload
-Create mapfile
-Before we start creating our mapfile ensure that you have a your access data
-(User/Password) and that you know the Oracle SRID, which could be different
-from the proj-EPSG!
-The data access Parameters:
-* CONNECTIONTYPE oraclespatial
-* CONNECTION 'user/password at MY_ORACLE'
-* DATA 'GEOM FROM MY_LAYER USING SRID 82032'
-Where:
-* GEOM is the name of the geometry column
-* MY_LAYER the name of the table
-* 82032 is equivalent to the EPSG code 31468 (German projection system)
-Testing & Error handling
-So you are fine now. Load the mapfile in your application and try it. If
-everything goes well: Great, if not, possibly this ugly error-emssage occurs
-(this one cmae by querying MapServer through the WMS interface as a
-GetMap-request):
-    <ServiceExceptionReport version="1.0.1">
-        <ServiceException>
-            msDrawMap(): Image handling error. Failed to draw layer named 'test1'.
-            msOracleSpatialLayerOpen(): OracleSpatial error. Cannot create OCI Handlers.
-            Connection failure. Check the connection string. Error: .
-        </ServiceException>
-    </ServiceExceptionReport>
-This points us towards, that there might be a problem with the connection to
-the database. First of all, let's check, if the mapfile is all right.
-Therefore we use the MapServer utility program :ref:`shp2img_utility`.
-Let's assume you are in the directory, where you compiled MapServer and run
-shp2img:
-    $ cd /var/src/mapserver_version/
-    $ shp2img -m /path/to/mapfile/mapfile.map -i png -o /path/to/output/output.png
-The output of the command should look like this:
-[Fri Feb  2 14:32:17 2007].522395 msDrawMap(): Layer 0 (test1), 0.074s
-[Fri Feb  2 14:32:17 2007].522578 msDrawMap(): Drawing Label Cache, 0.000s
-[Fri Feb  2 14:32:17 2007].522635 msDrawMap() total time: 0.075s
-If not, this possibly points you towards any error in your mapfile or in the
-way to access the data directly. In this case, take a look at :ref:`oci`. If
-there is a problem with your oracle connect, the same message as above
-(MsDrawMap() ...) occurs. Check your mapfile syntax and/or the environment
-settings for Oracle.
-For Debian/Ubuntu it's worth also checking the file "/etc/environment" and
-test-wise to add the system variables comparable to `System Variables`_
-If the output is OK, you may have a look at the generated image (output.png).
-Then your problem reduces to the access of apache to oracle home directory.
-Carefully check your apache configuration. Please note, that the apache.config
-file differs in several linux-distributions. For this paper we talk about
-Ubuntu, which should be the same as Debian.
Modified: trunk/docs/installation/index.txt
--- trunk/docs/installation/index.txt	2008-12-10 02:18:26 UTC (rev 8229)
+++ trunk/docs/installation/index.txt	2008-12-10 02:19:05 UTC (rev 8230)
@@ -13,4 +13,5 @@
    php
    dotnet
    iis
+   oracle
Copied: trunk/docs/installation/oracle.txt (from rev 8229, trunk/docs/howto/Configure Oracle and UMN.txt)
--- trunk/docs/installation/oracle.txt	                        (rev 0)
+++ trunk/docs/installation/oracle.txt	2008-12-10 02:19:05 UTC (rev 8230)
@@ -0,0 +1,258 @@
+.. _oci_install:
+ Oracle Installation
+:Author: Till Adams
+:Last Updated: 2007/02/16
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+.. index::
+    pair: Oracle, install
+Preface
+This document explains the whole configuration needed to get the connect
+between MapServer :ref:`cgi` and an Oracle database server on a linux (Ubuntu)
+box. The aim of this document is just to put a lot of googled knowledge in ONE
+place. Hopefully it will preserve many of people spending analog amount of
+time than I did!
+This manual was written, because I spent several days googling around to get
+my UMN having access to an oracle database. I'm NOT an oracle expert, so the
+aim of this document is just to put a lot of googled knowledge in ONE place.
+Hopefully it will preserve many of people spending analog amount of time than
+I did! (Or: If you have the choice: Try :ref:`PostGIS <input_postgis>` ;-))
+Before we start, some basic knowledge, I didn't know before:
+* Mapserver can access oracle spatial as well as geodata from any oracle
+  locator installation! Oracle locator comes with every oracle instance, there
+  is no need for an extra license.
+* There is no need for further installation of any packages beside
+  oracle/oracle OCI
+System Assumptions
+We assume that Oracle is already installed, there is a database and there is
+some geodata in the database. The following paths should be known by the
+reader:
+* ORACLE_HOME
+* ORACLE_SID
+* ORACLE_BASE
+* LD_LIBRARY_PATH
+We also assume that you have installed **apache2** (our version was 2.0.49)
+and you are used to work with Linux/UNIX systems. We also think you are able
+to handle the editor :ref:`vi/vim <vim>`.
+We ensure that the Oracle user who later accesses the database has
+write-access to the oracle_home directory.
+We also assume, that you already have setup the tnsnames.ora file. It should
+look like that:
+    MY_ORACLE =
+        (DESCRIPTION =
+            (ADDRESS = (PROTOCOL = TCP)(HOST = host)(PORT = 1521))
+            (CONNECT_DATA =
+                (SERVICE_NAME = your_name)
+It is important that you know the NAME of the datasource, in this example this
+is "MY_ORACLE" and will be used further on. Done that, you're fine using
+``User/Password at MY_ORACLE`` in your mapfile to connect to the oracle database.
+But first we have to do some more stuff.
+Compile MapServer
+Compile as normal compilation and set this flag:
+    --with-oraclespatial=/path/to/oracle/home/</p>
+If MapServer configure and make runs well, try
+    ./mapserv -v
+This should at least give this output:
+    INPUT=ORACLESPATIAL
+If you got that, you're fine from the MapServer point of view.
+Set Environment Variables
+It is important to set all environment variables correctly. There are one the
+one hand system-wide environment variables to be set, on the other hand there
+should be set some for the cgi-directory in your Apache configuration.
+System Variables
+On Ubuntu (and on many other systems) there is the file "/etc/profile" which
+sets environment variables for all users on the system (you may also dedicate
+user-specific environment variables by editing the users ".profile" file in
+their home directory, but usually the oracle database users are not users of
+the system with their own home)
+Set the following variables:
+    $ cd /etc
+    $ echo export ORACLE_HOME=/path/to/oracle/home >> /etc/profile
+    # **(e.g. ORACLE_HOME=/app/oracle/ora10g)
+    $ echo export ORACLE_BASE=path/to/oracle >> /etc/profile
+    # **(e.g. ORACLE_HOME=/app/oracle)
+    $ echo export ORACLE_SID=MY_ORACLE >> /etc/profile
+    $ echo export LD_LIBRARY_PATH=path/to/oracle/home/lib >> /etc/profile
+    # **(e.g. ORACLE_HOME=/app/oracle/ora10g/lib)
+The command comes silent, so there is no system output if you didn't mistype
+anything!
+Setting the Apache Environment
+Sometimes it is confusing WHERE to set WHAT in the splitted
+apache2.conf-files. In the folder "/etc/apache2/sites_available" you find your
+sites-file. If you did not do sth. Special e.g. installing virtual hosts, the
+file is named "default". In this file, the apache cgi-directory is defined.
+Our file looks like this:
+    ScriptAlias /cgi-bin/ /var/www/cgi-bin/
+    <Directory "/var/www/cgi-bin">
+           AllowOverride None
+           Options ExecCGI -MultiViews +SymLinksIfOwnerMatch
+           Order allow,deny
+           Allow from all
+    </Directory></p>
+In this file, the local apache
+environment variables must be set. We did it within a location-block
+like this:
+    <Location "/cgi-bin/">
+        SetEnv ORACLE_HOME "/path/to/oracle/home"
+    </Location></p>
+Where /cgi-bin/ in the opening location block refers to the script alias
+/cgi-bin/ and the TNS_ADMIN directory point to the location of the
+tnsnames.ora file.
+Then restart apache:
+    $ /etc/init.d/apache2 force-reload
+Create mapfile
+Before we start creating our mapfile ensure that you have a your access data
+(User/Password) and that you know the Oracle SRID, which could be different
+from the proj-EPSG!
+The data access Parameters:
+* CONNECTIONTYPE oraclespatial
+* CONNECTION 'user/password at MY_ORACLE'
+* DATA 'GEOM FROM MY_LAYER USING SRID 82032'
+Where:
+* GEOM is the name of the geometry column
+* MY_LAYER the name of the table
+* 82032 is equivalent to the EPSG code 31468 (German projection system)
+Testing & Error handling
+So you are fine now. Load the mapfile in your application and try it. If
+everything goes well: Great, if not, possibly this ugly error-emssage occurs
+(this one cmae by querying MapServer through the WMS interface as a
+GetMap-request):
+    <ServiceExceptionReport version="1.0.1">
+        <ServiceException>
+            msDrawMap(): Image handling error. Failed to draw layer named 'test1'.
+            msOracleSpatialLayerOpen(): OracleSpatial error. Cannot create OCI Handlers.
+            Connection failure. Check the connection string. Error: .
+        </ServiceException>
+    </ServiceExceptionReport>
+This points us towards, that there might be a problem with the connection to
+the database. First of all, let's check, if the mapfile is all right.
+Therefore we use the MapServer utility program :ref:`shp2img_utility`.
+Let's assume you are in the directory, where you compiled MapServer and run
+shp2img:
+    $ cd /var/src/mapserver_version/
+    $ shp2img -m /path/to/mapfile/mapfile.map -i png -o /path/to/output/output.png
+The output of the command should look like this:
+[Fri Feb  2 14:32:17 2007].522395 msDrawMap(): Layer 0 (test1), 0.074s
+[Fri Feb  2 14:32:17 2007].522578 msDrawMap(): Drawing Label Cache, 0.000s
+[Fri Feb  2 14:32:17 2007].522635 msDrawMap() total time: 0.075s
+If not, this possibly points you towards any error in your mapfile or in the
+way to access the data directly. In this case, take a look at :ref:`oci`. If
+there is a problem with your oracle connect, the same message as above
+(MsDrawMap() ...) occurs. Check your mapfile syntax and/or the environment
+settings for Oracle.
+For Debian/Ubuntu it's worth also checking the file "/etc/environment" and
+test-wise to add the system variables comparable to `System Variables`_
+If the output is OK, you may have a look at the generated image (output.png).
+Then your problem reduces to the access of apache to oracle home directory.
+Carefully check your apache configuration. Please note, that the apache.config
+file differs in several linux-distributions. For this paper we talk about
+Ubuntu, which should be the same as Debian.
More information about the mapserver-commits
