[mapserver-commits] r8243 - in trunk/docs: community ogc
svn at osgeo.org
svn at osgeo.org
Tue Dec 16 12:13:14 EST 2008
Author: hobu
Date: 2008-12-16 12:13:14 -0500 (Tue, 16 Dec 2008)
New Revision: 8243
trunk/docs/community/lists.txt
trunk/docs/ogc/mapscript.txt
add Tom's OGC example code
Modified: trunk/docs/community/lists.txt
--- trunk/docs/community/lists.txt 2008-12-16 16:05:35 UTC (rev 8242)
+++ trunk/docs/community/lists.txt 2008-12-16 17:13:14 UTC (rev 8243)
@@ -90,3 +90,13 @@
Please send a note to Howard Butler if you know of more MapServer
mailing lists in additional languages
+Downloading list archives
+The MapServer-Users and MapServer-Dev mailing lists have been migrated to the
+new OSGeo list server. One of the benefits of this migration is that you no
+longer need an account to download or read the archives. To access the
+MapServer archives, simply point your browser to
+http://lists.osgeo.org/pipermail/mapserver-users/ and download the gzipped
+file or click on the link. For MapServer-Dev archives, go to
+http://lists.osgeo.org/pipermail/mapserver-dev/.
Modified: trunk/docs/ogc/mapscript.txt
--- trunk/docs/ogc/mapscript.txt 2008-12-16 16:05:35 UTC (rev 8242)
+++ trunk/docs/ogc/mapscript.txt 2008-12-16 17:13:14 UTC (rev 8243)
@@ -136,6 +136,127 @@
so you cannot call msIO_getStdoutBufferBytes(), and so cannot manipulate
binary results.
+More Perl example code
+.. code-block:: perl
+ #!/usr/bin/perl
+ # Name: wxs.pl
+ # Project: MapServer
+ # Purpose: MapScript WxS example
+ # Author: Tom Kralidis
+ # Copyright (c) 2007, Tom Kralidis
+ # Permission is hereby granted, free of charge, to any person obtaining a
+ # copy of this software and associated documentation files (the "Software"),
+ # to deal in the Software without restriction, including without limitation
+ # the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ # and/or sell copies of the Software, and to permit persons to whom the
+ # Software is furnished to do so, subject to the following conditions:
+ # The above copyright notice and this permission notice shall be included in
+ # all copies of this Software or works derived from this Software.
+ # THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
+ # OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ # FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ # THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ # LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ # FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ # DEALINGS IN THE SOFTWARE.
+ use CGI::Carp qw(fatalsToBrowser);
+ use mapscript;
+ use strict;
+ use warnings;
+ use XML::LibXSLT;
+ use XML::LibXML;
+ my $dispatch;
+ # uber-trivial XSLT document, as a file
+ my $xsltfile = "/tmp/foo.xslt";
+ # here's the actual document inline for
+ # testing save and alter $xsltFile above
+ =comment
+ <?xml version="1.0" encoding="UTF-8"?>
+ <xsl:stylesheet version="1.0"
+ xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
+ xmlns:wfs="http://www.opengis.net/wfs">
+ <xsl:output method="xml" indent="yes"/>
+ <xsl:template match="/">
+ <WFSLayers>
+ <xsl:for-each select="//wfs:FeatureType">
+ <wfs_layer>
+ <name><xsl:value-of select="wfs:Name"/></name>
+ <title><xsl:value-of select="wfs:Title"/></title>
+ </wfs_layer>
+ </xsl:for-each>
+ </WFSLayers>
+ </xsl:template>
+ </xsl:stylesheet>
+ =cut
+ my $mapfile = "/tmp/config.map";
+ # init OWSRequest object
+ my $req = new mapscript::OWSRequest();
+ # pick up CGI paramters passed
+ $req->loadParams();
+ # init mapfile
+ my $map = new mapscript::mapObj($mapfile);
+ # if this is a WFS GetCapabilities request, then intercept
+ # what is normally returned, process with an XSLT document
+ # and then return that to the client
+ if ($req->getValueByName('REQUEST') eq "GetCapabilities" && $req->getValueByName('SERVICE') eq "WFS") {
+ # push STDOUT to a buffer and run the incoming request
+ my $io = mapscript::msIO_installStdoutToBuffer();
+ $dispatch = $map->OWSDispatch($req);
+ # at this point, the client's request is sent
+ # pull out the HTTP headers
+ my $ct = mapscript::msIO_stripStdoutBufferContentType();
+ # and then pick up the actual content of the response
+ my $content = mapscript::msIO_getStdoutBufferString();
+ my $xml = XML::LibXML->new();
+ my $xslt = XML::LibXSLT->new();
+ # load XML content
+ my $source = $xml->parse_string($content);
+ # load XSLT document
+ my $style_doc = $xml->parse_file($xsltfile);
+ my $stylesheet = $xslt->parse_stylesheet($style_doc);
+ # invoke the XSLT transformation
+ my $results = $stylesheet->transform($source);
+ # print out the result (header + content)
+ print "Content-type: $ct\n\n";
+ print $stylesheet->output_string($results);
+ # else process as normal
+ else {
Java Example
More information about the mapserver-commits
