[mapserver-commits] r8247 - in trunk/mapserver_demos/samples: .
hello_world relative_positioning
svn at osgeo.org
svn at osgeo.org
Tue Dec 16 23:57:22 EST 2008
Author: sdlime
Date: 2008-12-16 23:57:22 -0500 (Tue, 16 Dec 2008)
New Revision: 8247
trunk/mapserver_demos/samples/hello_world/index.html
trunk/mapserver_demos/samples/relative_positioning/index.html
trunk/mapserver_demos/samples/samples.css
Cleaned up the CSS a bit and standardized the two sample index.html pages built so far.
Modified: trunk/mapserver_demos/samples/hello_world/index.html
--- trunk/mapserver_demos/samples/hello_world/index.html 2008-12-16 19:46:39 UTC (rev 8246)
+++ trunk/mapserver_demos/samples/hello_world/index.html 2008-12-17 04:57:22 UTC (rev 8247)
@@ -7,16 +7,18 @@
<body>
<div id="samples_window">
- <p>Files: <a href="sample.map">sample.map</a></p>
+ <h1>Hello World</h1>
- <p>Notes:</p>
+ <div class="content"><span class="content_label">Files:</span> <a class="file" href="sample.map">sample.map</a></div>
- <p>Output:<br>
+ <div class="content"><span class="content_label">Notes:</span> The classic <em>hello world</em> example. Highlights inline features.</div>
+ <div class="content"><span class="content_label">Output:</span><br/>
<script language="javascript">
var url = samples_mapserver + "?map=" + samples_location + "hello_world/sample.map&mode=map";
- document.write("<a target=new href=\"" + url + "\"><img alt=\"open in new window\" src=\"" + url + "\"></a>");
+ document.write("<a target=new href=\"" + url + "\"><img title=\"open image in new window\" alt=\"open image in new window\" src=\"" + url + "\"></a>");
</script>
- </p>
+ </div>
</div>
</body>
Modified: trunk/mapserver_demos/samples/relative_positioning/index.html
--- trunk/mapserver_demos/samples/relative_positioning/index.html 2008-12-16 19:46:39 UTC (rev 8246)
+++ trunk/mapserver_demos/samples/relative_positioning/index.html 2008-12-17 04:57:22 UTC (rev 8247)
@@ -7,14 +7,18 @@
<body>
+ <h1>Relative Positioning</h1>
- <p>Notes: Relative positioning allows you to draw features (most often defined inline) relative to something other than the
- upper left-hand corner of the image. For example, you might want to always place a copyright statement in the lower left-hand
- corner of a map regardless of image size. A layer's TRANSFORM property is used to define relative positioning (default is UL).
- Feature coordinates can be given in pixels, the default, or in percentages (doubles between 0 and 1).</p>
- <p>Output:<br>
+ Relative positioning allows you to draw features (most often defined inline) relative to something other than the
+ upper left-hand corner of the image. For example, you might want to always place a copyright statement in the lower left-hand
+ corner of a map regardless of image size. A layer's TRANSFORM property is used to define relative positioning (default is UL).
+ Feature coordinates can be given in pixels, the default, or in percentages (doubles between 0 and 1).
+ </div>
+ <div class="content"><span class="content_label">Output:</span><br>
var url = samples_mapserver + "?map=" + samples_location + "relative_positioning/sample.map&mode=map";
@@ -27,7 +31,7 @@
url = samples_mapserver + "?map=" + samples_location + "relative_positioning/sample.map&mode=map&mapsize=400+250";
</script>
- </p>
+ </div>
</div>
</body>
Modified: trunk/mapserver_demos/samples/samples.css
--- trunk/mapserver_demos/samples/samples.css 2008-12-16 19:46:39 UTC (rev 8246)
+++ trunk/mapserver_demos/samples/samples.css 2008-12-17 04:57:22 UTC (rev 8247)
@@ -43,6 +43,36 @@
background-color:#EEEECC;
+h1, h2, h3, h4, h5, h6 {
+ -x-system-font:none;
+ background-color:transparent;
+ color:#000000;
+ font-family:'Lucida Grande',Verdana,Geneva,Lucida,Arial,Helvetica,sans-serif;
+ font-size:100%;
+ font-size-adjust:none;
+ font-stretch:normal;
+ font-style:normal;
+ font-variant:normal;
+ font-weight:normal;
+ line-height:normal;
+ margin:0;
+ padding-top:0.5em;
+h1 {
+ border-bottom: 1px solid #FCB100;
+ margin-bottom:0.5em;
+ font-size:120%;
+.content_label {
+ font-weight:bold;
+.content {
+ padding:0.5em;
form {
padding:5px;
\ No newline at end of file
More information about the mapserver-commits
