[mapserver-commits] r8255 - in trunk/docs: . _templates management
utilities
svn at osgeo.org
svn at osgeo.org
Thu Dec 18 11:55:50 EST 2008
Author: hobu
Date: 2008-12-18 11:55:49 -0500 (Thu, 18 Dec 2008)
New Revision: 8255
Added:
trunk/docs/contents.txt
trunk/docs/utilities/manage.txt
Removed:
trunk/docs/management/systemmanage.txt
trunk/docs/_templates/layout.html
trunk/docs/conf.py
trunk/docs/documentation.txt
trunk/docs/utilities/index.txt
tweak layout, move management doc
Modified: trunk/docs/_templates/layout.html
--- trunk/docs/_templates/layout.html 2008-12-17 17:24:29 UTC (rev 8254)
+++ trunk/docs/_templates/layout.html 2008-12-18 16:55:49 UTC (rev 8255)
@@ -6,7 +6,7 @@
<div style="padding: 10px 10px 15px 15px; background-color: white; text-align: right; float: right; vertical-align: bottom;">
<a href="http://svn.osgeo.org/mapserver">Source</a> |
-<a href="http://trac.osgeo.org/trac">Bugs</a> |
+<a href="http://trac.osgeo.org/mapserver">Bugs</a> |
<a href="{{ pathto('documentation') }}">Docs</a> (<a href="/MapServer.pdf">pdf</a>) |
<a href="{{ pathto('download') }}">Download </a>
</div>
Modified: trunk/docs/conf.py
--- trunk/docs/conf.py 2008-12-17 17:24:29 UTC (rev 8254)
+++ trunk/docs/conf.py 2008-12-18 16:55:49 UTC (rev 8255)
@@ -35,7 +35,7 @@
#source_encoding = 'utf-8'
# The master toctree document.
-master_doc = 'documentation'
+master_doc = 'contents'
# General information about the project.
project = u'MapServer'
@@ -165,7 +165,7 @@
# Grouping the document tree into LaTeX files. List of tuples
# (source start file, target name, title, author, document class [howto/manual]).
latex_documents = [
- ('documentation', 'MapServer.tex', ur'MapServer Documentation',
+ ('contents', 'MapServer.tex', ur'MapServer Documentation',
ur'The MapServer Team', 'manual', False),
Added: trunk/docs/contents.txt
--- trunk/docs/contents.txt (rev 0)
+++ trunk/docs/contents.txt 2008-12-18 16:55:49 UTC (rev 8255)
@@ -0,0 +1,21 @@
+.. _contents:
+ Contents page for TOC
+.. toctree::
+ :maxdepth: 1
+ new_users
+ installation/index
+ mapfile/index
+ mapscript/index
+ input/index
+ output/index
+ ogc/index
+ optimization/index
+ utilities/index
+ cgi/index
+ development/index
\ No newline at end of file
Modified: trunk/docs/documentation.txt
--- trunk/docs/documentation.txt 2008-12-17 17:24:29 UTC (rev 8254)
+++ trunk/docs/documentation.txt 2008-12-18 16:55:49 UTC (rev 8255)
@@ -1,21 +1,7 @@
.. _documentation:
- MapServer Documentation
+ MapServer |release| Documentation
-.. toctree::
- :maxdepth: 1
- new_users
- installation/index
- mapfile/index
- mapscript/index
- input/index
- output/index
- ogc/index
- optimization/index
- utilities/index
- cgi/index
- development/index
+Some docs...
Deleted: trunk/docs/management/systemmanage.txt
--- trunk/docs/management/systemmanage.txt 2008-12-17 17:24:29 UTC (rev 8254)
+++ trunk/docs/management/systemmanage.txt 2008-12-18 16:55:49 UTC (rev 8255)
@@ -1,49 +0,0 @@
-File Placement
-MapServer requires a number of different files to execute. Except for graphics
-that are referenced in output templates (i.e. web pages) none of the data or
-configuration files need be accessible via a web server. File naming for
-MapServer follows two rules:
-1. Files may be given using their full system path. *or*
-2. Files may be given using a relative path where the path is relative to
- the location of the file they are being referenced from.
-So, for files referenced in the Mapfile they can be given relative
-to the location of the Mapfile. Same holds true for symbol sets and font sets.
-Temporary Files
-MapServer also can produce a number of files (i.e. maps, legends, scalebars, etc...).
-These files **must** be accessible using a web server. To accomplish this
-MapServer creates these files in a scratch directory. The location of that
-directory is given using the IMAGEPATH and IMAGEURL parameters in the web
-section of a Mapfile. The scratch directory must be writable by the user that
-the web server runs under, usually *nobody*. It is recommended for security
-reasons that the web user own the scratch directory rather than making it
-world writable. The scratch area will need to be cleaned periodically.
-On busy sites this may need to happen several times an hour. Here's an
-example shell script that could be run using *cron*:
- #!/bin/csh
- find /usr/local/www/docs/tmp -follow -name "*.gif" -exec rm {} \;
-Windows
-The following *.bat* file can be used in 'Scheduled Tasks' to remove these
-temporary images daily:
- REM this script deletes the contents of the ms_tmp directory
- REM (i.e. the MapServer-created gifs)
- cd D:\ms4w\tmp\ms_tmp
- echo Y | del *.*
Modified: trunk/docs/utilities/index.txt
--- trunk/docs/utilities/index.txt 2008-12-17 17:24:29 UTC (rev 8254)
+++ trunk/docs/utilities/index.txt 2008-12-18 16:55:49 UTC (rev 8255)
@@ -18,4 +18,5 @@
sortshp
sym2img
tile4ms
+ management
Copied: trunk/docs/utilities/manage.txt (from rev 8246, trunk/docs/management/systemmanage.txt)
--- trunk/docs/utilities/manage.txt (rev 0)
+++ trunk/docs/utilities/manage.txt 2008-12-18 16:55:49 UTC (rev 8255)
@@ -0,0 +1,55 @@
+.. _management:
+ Management
+File Placement
+MapServer requires a number of different files to execute. Except for graphics
+that are referenced in output templates (i.e. web pages) none of the data or
+configuration files need be accessible via a web server. File naming for
+MapServer follows two rules:
+1. Files may be given using their full system path. *or*
+2. Files may be given using a relative path where the path is relative to
+ the location of the file they are being referenced from.
+So, for files referenced in the Mapfile they can be given relative
+to the location of the Mapfile. Same holds true for symbol sets and font sets.
+Temporary Files
+MapServer also can produce a number of files (i.e. maps, legends, scalebars, etc...).
+These files **must** be accessible using a web server. To accomplish this
+MapServer creates these files in a scratch directory. The location of that
+directory is given using the IMAGEPATH and IMAGEURL parameters in the web
+section of a Mapfile. The scratch directory must be writable by the user that
+the web server runs under, usually *nobody*. It is recommended for security
+reasons that the web user own the scratch directory rather than making it
+world writable. The scratch area will need to be cleaned periodically.
+On busy sites this may need to happen several times an hour. Here's an
+example shell script that could be run using *cron*:
+ #!/bin/csh
+ find /usr/local/www/docs/tmp -follow -name "*.gif" -exec rm {} \;
+Windows
+The following *.bat* file can be used in 'Scheduled Tasks' to remove these
+temporary images daily:
+ REM this script deletes the contents of the ms_tmp directory
+ REM (i.e. the MapServer-created gifs)
+ cd D:\ms4w\tmp\ms_tmp
+ echo Y | del *.*
More information about the mapserver-commits
