[mapserver-commits] r8263 - in trunk/docs: . images
svn at osgeo.org
svn at osgeo.org
Fri Dec 19 00:11:44 EST 2008
Author: hobu
Date: 2008-12-19 00:11:44 -0500 (Fri, 19 Dec 2008)
New Revision: 8263
Added:
trunk/docs/images/osgeo4w-install-verify.png
trunk/docs/new_users.txt
more porting
Added: trunk/docs/images/osgeo4w-install-verify.png
(Binary files differ)
Property changes on: trunk/docs/images/osgeo4w-install-verify.png
___________________________________________________________________
+ application/octet-stream
Modified: trunk/docs/new_users.txt
--- trunk/docs/new_users.txt 2008-12-19 04:55:39 UTC (rev 8262)
+++ trunk/docs/new_users.txt 2008-12-19 05:11:44 UTC (rev 8263)
@@ -150,14 +150,14 @@
2) Execute (double-click) the .exe
-3) Choose "Express" or "Advanced" install type
+3) Choose "Advanced" install type
.. image:: ./images/osgeo4w-install-start.png
.. note::
Express contains options for higher-level packages such as MapServer,
GRASS, and uDig. Advanced gives you full access to choosing
- commandline tools and applications for MapServer, that are not
+ commandline tools and applications for MapServer that are not
included in the Express install
4) Select packages to install
@@ -174,11 +174,28 @@
.. image:: ./images/osgeo4w-install-fetch.png
-6) Test your installation
+6) Run the apache-install.bat script to install the Apache Service.
+ .. note::
+ You must run this script under the "OSGeo4W Shell". This is usually
+ available as a shortcut on your desktop
+ .. note::
+ A apache-uninstall.bat script is also available to remove the
+ Apache service installation.
+7) Start Apache from the OSGeo4W shell and navigate to http://127.0.0.1
+ apache-restart.bat
.. image:: ./images/osgeo4w-install-complete.png
+8) Verify that MapServer is working
+ .. image:: ./images/osgeo4w-install-verify.png
Hardware Requirements
More information about the mapserver-commits
