[mapserver-commits] r8267 - trunk/docs/mapscript/php
svn at osgeo.org
svn at osgeo.org
Fri Dec 19 10:46:13 EST 2008
Author: aboudreault
Date: 2008-12-19 10:46:13 -0500 (Fri, 19 Dec 2008)
New Revision: 8267
trunk/docs/mapscript/php/index.txt
Added hashTableObj in php documentation
Modified: trunk/docs/mapscript/php/index.txt
--- trunk/docs/mapscript/php/index.txt 2008-12-19 15:21:43 UTC (rev 8266)
+++ trunk/docs/mapscript/php/index.txt 2008-12-19 15:46:13 UTC (rev 8267)
@@ -696,6 +696,7 @@
int num_processing
string requires
string labelrequires
+hashTableObj metadata
@@ -996,6 +997,7 @@
int numstyles
string keyimage
string group
Methods
@@ -1262,6 +1264,7 @@
string queryformat
string legendformat
string browseformat
Methods
@@ -2307,3 +2310,39 @@
string getvaluebyname(string name)
Return the value associated with the parameter *name*.
+hashTableObj Class
+Constructor
+Instance of hashTableObj is always embedded inside the LayerObj, WebObj
+and ClassObj. It is uses a read only.
+.. code-block:: php
+ $hashTable = $oLayer->metadata;
+ $key = null;
+ while ($key = $hashTable->nextkey($key))
+ echo "Key: ".$key." value: ".$hashTable->get($key)."<br/>";
+Methods
+string get(string key)
+ Fetch class metadata entry by name. Returns "" if no entry
+ matches the name. Note that the search is case sensitive.
+int set(string key, string value)
+ Set a metadata entry in the hashTable. Returns MS_SUCCESS/MS_FAILURE.
+int remove(string key)
+ Remove a metadata entry in the hashTable. Returns MS_SUCCESS/MS_FAILURE.
+void clear()
+ Clear all items in the hashTable (To NULL).
+string nextkey(string previousKey)
+ Return the next key or first key if previousKey = NULL.
+ Return NULL if no item is in the hashTable or end of hashTable is reached
More information about the mapserver-commits
