[mapserver-commits] r8269 - trunk/docs/mapfile
svn at osgeo.org
svn at osgeo.org
Mon Dec 22 10:24:17 EST 2008
Author: aboudreault
Date: 2008-12-22 10:24:17 -0500 (Mon, 22 Dec 2008)
New Revision: 8269
trunk/docs/mapfile/template.txt
Updated template documentation.
Modified: trunk/docs/mapfile/template.txt
--- trunk/docs/mapfile/template.txt 2008-12-22 14:48:10 UTC (rev 8268)
+++ trunk/docs/mapfile/template.txt 2008-12-22 15:24:17 UTC (rev 8269)
@@ -74,6 +74,11 @@
below. HTML templates can include just about anything including JavaScript and
Java calls.
+In HTML files, the attribute values can be inside quotes(""). Writing
+attribute values inside quotes allows you to set special characters in
+value that you couldn't use normaly (ie: ],=," and space). To write a
+single quote in a attribute value, just use two quotes ("").
General
@@ -699,4 +704,4 @@
.. #### rST Link Section ####
-.. _`MapServer ticket#1102`: http://trac.osgeo.org/mapserver/ticket/1102
\ No newline at end of file
+.. _`MapServer ticket#1102`: http://trac.osgeo.org/mapserver/ticket/1102
More information about the mapserver-commits
