[mapserver-commits] r8273 - in trunk/docs: . images
svn at osgeo.org
svn at osgeo.org
Mon Dec 22 21:52:52 EST 2008
Author: hobu
Date: 2008-12-22 21:52:51 -0500 (Mon, 22 Dec 2008)
New Revision: 8273
Added:
trunk/docs/images/bluemarble-boundaries.jpg
trunk/docs/images/bluemarble-rendered.jpg
trunk/docs/images/bluemarble-ski-label.jpg
trunk/docs/images/bluemarble-ski.jpg
trunk/docs/images/bluemarble-style.jpg
trunk/docs/introduction.txt
add introduction to mapfile section from jmckenna
Added: trunk/docs/images/bluemarble-boundaries.jpg
(Binary files differ)
Property changes on: trunk/docs/images/bluemarble-boundaries.jpg
___________________________________________________________________
+ application/octet-stream
Added: trunk/docs/images/bluemarble-rendered.jpg
Property changes on: trunk/docs/images/bluemarble-rendered.jpg
Added: trunk/docs/images/bluemarble-ski-label.jpg
Property changes on: trunk/docs/images/bluemarble-ski-label.jpg
Added: trunk/docs/images/bluemarble-ski.jpg
Property changes on: trunk/docs/images/bluemarble-ski.jpg
Added: trunk/docs/images/bluemarble-style.jpg
Property changes on: trunk/docs/images/bluemarble-style.jpg
Modified: trunk/docs/introduction.txt
--- trunk/docs/introduction.txt 2008-12-23 00:09:29 UTC (rev 8272)
+++ trunk/docs/introduction.txt 2008-12-23 02:52:51 UTC (rev 8273)
@@ -245,9 +245,343 @@
DHTML/Javascript, Java, databases, expressions, compiling, and scripting may
be very useful.
-Building your first MapServer Application
+Introduction to the :ref:`Mapfile <mapfile>`
+The .map file is the basic configuration file for data access and styling for
+MapServer. The file is an ASCII text file, and is made up of different
+objects. Each object has a variety of parameters available for it. All .map
+file (or mapfile) parameters are documented at :ref:`mapfile`. A simple
+mapfile example displaying only one layer follows, as well as the map image
+output:
+ NAME "sample"
+ STATUS ON
+ SIZE 600 400
+ SYMBOLSET "../etc/symbols.txt"
+ EXTENT -180 -90 180 90
+ UNITS DD
+ SHAPEPATH "../data"
+ IMAGECOLOR 255 255 255
+ FONTSET "../etc/fonts.txt"
+ # Start of web interface definition
+ WEB
+ IMAGEPATH "/ms4w/tmp/ms_tmp/"
+ IMAGEURL "/ms_tmp/"
+ END
+ # Start of layer definitions
+ LAYER
+ NAME 'global-raster
+ TYPE RASTER
+ STATUS DEFAULT
+ END
+.. figure:: ./images/bluemarble-rendered.jpg
+ :alt: Rendered Bluemarble Image
+ Rendered Bluemarble Image
+.. note::
+ * Comments in a mapfile are specified with a '#' character
+ * MapServer parses mapfiles from top to bottom, therefore layers at the
+ end of the mapfile will be drawn last (meaning they will be displayed on
+ top of other layers)
+ * Using relative paths is always recommended
+ * Paths should be quoted (single or double quotes are accepted)
+:ref:`MAP` Object
+ MAP
+ NAME "sample"
+ EXTENT -180 -90 180 90 # Geographic
+ SIZE 800 400
+ IMAGECOLOR 128 128 255
+ END
+* EXTENT is the output extent in the units of the output map
+* SIZE is the width and height of the map image in pixels
+* IMAGECOLOR is the default image background color
+:ref:`LAYER` Object
+* starting with MapServer 5.0, there is no limit to the number of layers in a
+ mapfile
+* DATA parameter is relative to the SHAPEPATH parameter the :ref:`MAP` object
+* if no DATA extension is provided in the filename, MapServer will assume it is
+ an ESRI shapefile (.shp)
+Raster Layers
+ LAYER
+ NAME bathymetry
+ TYPE RASTER
+ STATUS DEFAULT
+ DATA bath_mapserver.tif
+ END
+.. seealso::
+ :ref:`raster`
+Vector Layers
+Vector layers of TYPE point, line, or polygon can be displayed. The following
+example shows how to display only lines from a TYPE polygon layer, using the
+OUTLINECOLOR parameter:
+ LAYER
+ NAME "world_poly"
+ DATA 'shapefile/countries_area.shp'
+ STATUS ON
+ TYPE POLYGON
+ CLASS
+ NAME 'The World'
+ STYLE
+ OUTLINECOLOR 0 0 0
+ END
+ END
+ END # layer
+.. seealso::
+ :ref:`vector`
+.. figure:: ./images/bluemarble-boundaries.jpg
+ Rendered Bluemarble image with vector boundaries
+:ref:`CLASS` and :ref:`STYLE` Objects
+* typical styling information is stored within the :ref:`CLASS` and
+ :ref:`STYLE` objects of a :ref:`LAYER`
+* starting with MapServer 5.0, there is no limit to the number of classes or
+ styles in a mapfile
+* the following example shows how to display a road line with two colors by
+ using overlayed STYLE objects
+ CLASS
+ NAME "Primary Roads"
+ STYLE
+ SYMBOL "circle"
+ COLOR 178 114 1
+ SIZE 15
+ END #style1
+ STYLE
+ SYMBOL "circle"
+ COLOR 254 161 0
+ SIZE 7
+ END #style2
+ END
+.. figure:: ./images/bluemarble-style.jpg
+ Rendered Bluemarble image with styled roads
+:ref:`SYMBOLs <SYMBOL>`
+* can be defined directly in the mapfile, or in a separate file
+* the separate file method must use the SYMBOLSET parameter in the MAP object:
+ MAP
+ NAME "sample"
+ SIZE 800 400
+ END
+where symbols.txt might contain:
+ Symbol
+ Name 'ski'
+ Type PIXMAP
+ IMAGE "ski.gif"
+ END
+and the mapfile would contain:
+ LAYER
+ CLASS
+ NAME "Ski Area"
+ STYLE
+ SYMBOL "ski"
+ END
+ END
+ END # layer
+.. figure:: ./images/bluemarble-ski.jpg
+ :alt: Rendered Bluemarble Image Skier
+ Rendered Bluemarble image with skier symbol
+.. seealso::
+ :ref:`sym_construction`, :ref:`sym_examples`, and :ref:`symbol`
+:ref:`LABEL`
+* defined within a :ref:`LAYER` object
+* the LABELITEM parameters in the :ref:`LAYER` object can be used to label by
+ a specific column in the data refer to a :ref:`FONTSET` file, that is set in
+ the :ref:`MAP` object, that contains a reference to the available font names
+An example :ref:`LABEL` object that references one of the above fonts might
+look like:
+ LABEL
+ FONT "sans-bold"
+ TYPE truetype
+ SIZE 10
+ POSITION LC
+ PARTIALS FALSE
+ COLOR 100 100 100
+ OUTLINECOLOR 242 236 230
+ END # label
+.. figure:: ./images/bluemarble-ski-label.jpg
+ Rendered Bluemarble image with skier symbol and a label
+.. seealso::
+ :ref:`label`, :ref:`fontset`
+:ref:`CLASS` :ref:`Expressions <expressions>`
+MapServer supports three types of :ref:`CLASS` expressions in a :ref:`LAYER`:
+1) String comparisons
+ (EXPRESSION "africa")
+2) Regular expressions
+ (EXPRESSION /^9|^10/)
+3) Logical expressions
+ ([POPULATION] > 50000 AND '[LANGUAGE]' eq 'FRENCH')
+An important note is that logical expressions should be avoided wherever
+possible as they are very costly in terms of drawing time.
+.. seealso::
+ :ref:`expressions`
+:ref:`INCLUDE`
+Added to MapServer 4.10, any part of the mapfile can now be stored in a
+separate file and added to the main mapfile using the :ref:`INCLUDE`
+parameter. The filename to be included can have any extension, and it is
+always relative to the main .map file.
+Here are some potential uses:
+* :ref:`LAYER` s can be stored in files and included to any number of applications
+* :ref:`STYLE` s can also be stored and included in multiple applications
+The following is an example of using :ref:`mapfile <mapfile>` :ref:`includes
+<include>` to include a layer definition in a separate file:
+If 'shadedrelief.lay' contains:
+ LAYER
+ NAME 'shadedrelief'
+ STATUS ON
+ TYPE RASTER
+ DATA 'GLOBALeb3colshade.jpg'
+ END
+therefore the main mapfile would contain:
+ MAP
+ INCLUDE "shadedrelief.lay"
+ END
+The following is an example of a mapfile where all :ref:`LAYER` s are in
+separate .lay files, and all other objects (:ref:`WEB`, :ref:`REFERENCE`,
+:ref:`SCALEBAR`, etc.) are stored in a ".ref" file:
+ NAME "base"
+ # include reference objects
+ INCLUDE "../templates/template.ref"
+ INCLUDE "../layers/usa/usa_outline.lay"
+ INCLUDE "../layers/canada/base/1m/provinces.lay"
+ INCLUDE "../layers/canada/base/1m/roads_atlas_of_canada_1m.lay"
+ INCLUDE "../layers/canada/base/1m/roads_atlas_of_canada_1m_shields.lay"
+ INCLUDE "../layers/canada/base/1m/populated_places.lay"
+ END # Map File
+.. warning::
+ :ref:`Mapfiles <mapfile>` must end with the ``.map`` extension or
+ MapServer will not recognize them. Include files can have any extension
+ you want, however.
Get MapServer Running
More information about the mapserver-commits
