[mapserver-commits] r8292 - trunk/docs
Fri Dec 26 16:23:35 EST 2008
Author: hobu
Date: 2008-12-26 16:23:35 -0500 (Fri, 26 Dec 2008)
New Revision: 8292
   trunk/docs/errors.txt
clean up headings levels
Modified: trunk/docs/errors.txt
--- trunk/docs/errors.txt	2008-12-26 21:21:16 UTC (rev 8291)
+++ trunk/docs/errors.txt	2008-12-26 21:23:35 UTC (rev 8292)
@@ -299,7 +299,7 @@
 Valid Examples
 4.0 and newer:
@@ -353,7 +353,7 @@
 will not work because it will be looking for an *EPSG* file in uppercase.
 Setting the location of the epsg file
 There are a few options available if you need to set the epsg location:
