[mapserver-commits] r8294 - in trunk/docs: . cgi community development installation mapfile mapscript ogc optimization output utilities
Fri Dec 26 17:04:45 EST 2008
Author: hobu
Date: 2008-12-26 17:04:45 -0500 (Fri, 26 Dec 2008)
New Revision: 8294
   trunk/docs/cgi/index.txt
   trunk/docs/community/index.txt
   trunk/docs/development/index.txt
   trunk/docs/documentation.txt
   trunk/docs/index.txt
   trunk/docs/installation/index.txt
   trunk/docs/installation/win32.txt
   trunk/docs/mapfile/index.txt
   trunk/docs/mapscript/index.txt
   trunk/docs/ogc/index.txt
   trunk/docs/optimization/index.txt
   trunk/docs/output/index.txt
   trunk/docs/utilities/index.txt
remove docnav include for now
Modified: trunk/docs/cgi/index.txt
--- trunk/docs/cgi/index.txt	2008-12-26 21:49:09 UTC (rev 8293)
+++ trunk/docs/cgi/index.txt	2008-12-26 22:04:45 UTC (rev 8294)
@@ -20,8 +20,5 @@
    controls
    runsub
    wrapper
-.. include:: ../include/docnav.inc
Modified: trunk/docs/community/index.txt
--- trunk/docs/community/index.txt	2008-12-26 21:49:09 UTC (rev 8293)
+++ trunk/docs/community/index.txt	2008-12-26 22:04:45 UTC (rev 8294)
@@ -10,6 +10,3 @@
    lists
    irc
Modified: trunk/docs/development/index.txt
--- trunk/docs/development/index.txt	2008-12-26 21:49:09 UTC (rev 8293)
+++ trunk/docs/development/index.txt	2008-12-26 22:04:45 UTC (rev 8294)
@@ -11,9 +11,8 @@
    sponsors
    bugs
    svn
+   doc_style_guide
    tests/index
    rfc/index
    editing/index
-   doc_style_guide
\ No newline at end of file
Modified: trunk/docs/documentation.txt
--- trunk/docs/documentation.txt	2008-12-26 21:49:09 UTC (rev 8293)
+++ trunk/docs/documentation.txt	2008-12-26 22:04:45 UTC (rev 8294)
@@ -4,9 +4,7 @@
  MapServer |release| Documentation
-.. include:: ./include/docnav.inc
 .. toctree::
    :maxdepth: 2
Modified: trunk/docs/index.txt
--- trunk/docs/index.txt	2008-12-26 21:49:09 UTC (rev 8293)
+++ trunk/docs/index.txt	2008-12-26 22:04:45 UTC (rev 8294)
@@ -56,8 +56,9 @@
 - A multitude of raster and vector data formats
   - TIFF/GeoTIFF, EPPL7, and many others via :term:`GDAL`
-  - :ref:`ESRI shapfiles <shapefiles>`, :ref:`PostGIS <input_postgis>`, :ref:`ESRI ArcSDE <arcsde>`, :ref:`Oracle Spatial <oci>`, :ref:`MySQL <mysql>` and many
-    others via :term:`OGR`
+  - :ref:`ESRI shapfiles <shapefiles>`, :ref:`PostGIS <input_postgis>`,
+    :ref:`ESRI ArcSDE <arcsde>`, :ref:`Oracle Spatial <oci>`, :ref:`MySQL
+    <mysql>` and many others via :term:`OGR`
   - :term:`Open Geospatial Consortium <OGC` (OGC) web
     specifications
Modified: trunk/docs/installation/index.txt
--- trunk/docs/installation/index.txt	2008-12-26 21:49:09 UTC (rev 8293)
+++ trunk/docs/installation/index.txt	2008-12-26 22:04:45 UTC (rev 8294)
@@ -14,5 +14,3 @@
    dotnet
    iis
    oracle
Modified: trunk/docs/installation/win32.txt
--- trunk/docs/installation/win32.txt	2008-12-26 21:49:09 UTC (rev 8293)
+++ trunk/docs/installation/win32.txt	2008-12-26 22:04:45 UTC (rev 8294)
@@ -114,7 +114,7 @@
 of the source code can be obtained from SVN; however, the SVN respository does
 not contain several important source files (maplexer.c, mapparser.c and
 mapparser.h) normally generated on unix, so if possible, using a nightly
-snaphot is substantially easier than working directly from :ref:`subversion`.
+snaphot is substantially easier than working directly from :ref:`svn`.
 **Required Libraries**
Modified: trunk/docs/mapfile/index.txt
--- trunk/docs/mapfile/index.txt	2008-12-26 21:49:09 UTC (rev 8293)
+++ trunk/docs/mapfile/index.txt	2008-12-26 22:04:45 UTC (rev 8294)
@@ -88,5 +88,3 @@
   also available on most UNIX's. Since these RegEx's are POSIX compliant, they
   should be the same on Windows as well, so windows users can try searching
   the web for "man 7 regex" since man pages are available all over the web.
Modified: trunk/docs/mapscript/index.txt
--- trunk/docs/mapscript/index.txt	2008-12-26 21:49:09 UTC (rev 8293)
+++ trunk/docs/mapscript/index.txt	2008-12-26 22:04:45 UTC (rev 8294)
@@ -21,6 +21,4 @@
    querying
    variables
Modified: trunk/docs/ogc/index.txt
--- trunk/docs/ogc/index.txt	2008-12-26 21:49:09 UTC (rev 8293)
+++ trunk/docs/ogc/index.txt	2008-12-26 22:04:45 UTC (rev 8294)
@@ -21,6 +21,4 @@
    sos_server
    mapscript
Modified: trunk/docs/optimization/index.txt
--- trunk/docs/optimization/index.txt	2008-12-26 21:49:09 UTC (rev 8293)
+++ trunk/docs/optimization/index.txt	2008-12-26 22:04:45 UTC (rev 8294)
@@ -12,6 +12,4 @@
    raster
    fastcgi
    tileindex
Modified: trunk/docs/output/index.txt
--- trunk/docs/output/index.txt	2008-12-26 21:49:09 UTC (rev 8293)
+++ trunk/docs/output/index.txt	2008-12-26 22:04:45 UTC (rev 8294)
@@ -18,4 +18,3 @@
    svg
    tile_mode
Modified: trunk/docs/utilities/index.txt
--- trunk/docs/utilities/index.txt	2008-12-26 21:49:09 UTC (rev 8293)
+++ trunk/docs/utilities/index.txt	2008-12-26 22:04:45 UTC (rev 8294)
@@ -19,5 +19,4 @@
    sym2img
    tile4ms
    manage
