[mapserver-commits] r8302 - trunk/docs/utilities
Sun Dec 28 19:19:15 EST 2008
Author: tomkralidis
Date: 2008-12-28 19:19:15 -0500 (Sun, 28 Dec 2008)
New Revision: 8302
   trunk/docs/utilities/shptree.txt
remove bad link
Modified: trunk/docs/utilities/shptree.txt
--- trunk/docs/utilities/shptree.txt	2008-12-28 23:35:51 UTC (rev 8301)
+++ trunk/docs/utilities/shptree.txt	2008-12-29 00:19:15 UTC (rev 8302)
@@ -20,9 +20,8 @@
 a file of the same name as your shapefile, with a *.qix* file extension.
 The quadtree method breaks the file into 4 quadrants, recursively until only a few shapes
 are contained in each quadrant.  This minimum number can be set with the <depth> parameter
-of the command.  More information on this command can be found at:
-http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?ShpTree
+of the command.
 Syntax
