[mapserver-commits] r8309 - trunk/docs
svn at osgeo.org
svn at osgeo.org
Mon Dec 29 08:16:34 EST 2008
Author: tomkralidis
Date: 2008-12-29 08:16:33 -0500 (Mon, 29 Dec 2008)
New Revision: 8309
trunk/docs/glossary.txt
alphabetize, expand OGC def
Modified: trunk/docs/glossary.txt
--- trunk/docs/glossary.txt 2008-12-29 13:09:25 UTC (rev 8308)
+++ trunk/docs/glossary.txt 2008-12-29 13:16:33 UTC (rev 8309)
@@ -53,11 +53,6 @@
reading and writing library. It is used as the primary mechanism for
reading raster data in MapServer. It is hosted at http://www.gdal.org/
- GPX
- `GPS eXchange <http://en.wikipedia.org/wiki/GPX_(data_transfer)>`__
- Format is an XML Schema for describing GPS data. :term:`OGR` can
- be used to transform and render this data with MapServer.
`Geometry Engine Open Source <http://trac.osgeo.org/geos>`__ is a
C/C++ port of the `Java Topology Suite
@@ -67,6 +62,19 @@
of two or more polygons. MapServer optionally uses GEOS for geometric
algebra operations.
+ GML
+ `Geography Markup Language <http://www.opengeospatial.org/standards/gml>`__
+ is an :term:`OGC` standard which defines an abstract model for geographic
+ features
+ .. seealso::
+ :ref:`wfs_server`
+ GPX
+ `GPS eXchange <http://en.wikipedia.org/wiki/GPX_(data_transfer)>`__
+ Format is an XML Schema for describing GPS data. :term:`OGR` can
+ be used to transform and render this data with MapServer.
Map Scale
A treatise of mapping scale can be found on
`about.com <http://geography.about.com/cs/maps/a/mapscale.htm>`_.
@@ -88,16 +96,29 @@
OGC
The `Open Geospatial Consortium <http://www.opengeospatial.org>`_ is a
- standards organization body in the GIS domain. Many of its web
- standards are implemented in MapServer.
+ standards organization body in the GIS domain. MapServer supports
+ numerous OGC standards.
+ .. seealso::
+ :ref:`wms_server` and :ref:`wms_client` and :ref:`sos_server`
+ and :ref:`wfs_server` and :ref:`wfs_client` and :ref:`map_context`
+ and :ref:`sld` and :ref:`filter_encoding` and :ref:`wcs_server`
OGR
- `OGR <http://www.gdal.org/ogr>`__ is the vector data access portion of
- the :term:`GDAL` library. It provides access to a multitude of data
- formats.
+ `OGR <http://www.gdal.org/ogr>`__ is the vector data access portion of
+ the :term:`GDAL` library. It provides access to a multitude of data
+ formats.
.. seealso::
:ref:`ogr`
+ OM
+ `Observations and Measurements <http://www.opengeospatial.org/standards/om>`__
+ is an :term:`OGC` standard which defines an abstract model for sensor based
+ data.
+ .. seealso::
+ :ref:`sos_server`
`OpenLayers <http://openlayers.org>`__ is a JavaScript library for
@@ -148,13 +169,6 @@
is a term used to describe the :ref:`PROJECTION` used by many
commercial API providers.
- SWF
- `Shockwave Flash <http://en.wikipedia.org/wiki/SWF>`__ format that
- MapServer can generate for output.
- .. seealso::
- :ref:`flash`
SVG
`Scalable Vector Graphics <http://en.wikipedia.org/wiki/SVG>`__ is
an XML format that MapServer can output. It is frequently used in
@@ -163,6 +177,13 @@
.. seealso::
:ref:`svg`
+ SWF
+ `Shockwave Flash <http://en.wikipedia.org/wiki/SWF>`__ format that
+ MapServer can generate for output.
+ .. seealso::
+ :ref:`flash`
SWIG
`Simplified Wrapper Interface Generator <http://www.swig.org>`__ is the
library that MapServer uses for generating the language bindings for
More information about the mapserver-commits
