[mapserver-commits] r8315 - trunk/docs
svn at osgeo.org
svn at osgeo.org
Mon Dec 29 12:43:26 EST 2008
Author: hobu
Date: 2008-12-29 12:43:26 -0500 (Mon, 29 Dec 2008)
New Revision: 8315
trunk/docs/errors.txt
add misclassed FAQ item
Modified: trunk/docs/errors.txt
--- trunk/docs/errors.txt 2008-12-29 17:42:59 UTC (rev 8314)
+++ trunk/docs/errors.txt 2008-12-29 17:43:26 UTC (rev 8315)
@@ -383,4 +383,50 @@
SetEnv PROJ_LIB C:/somedir/proj/nad/
+msQueryByPoint: search returned no results
+Why do I get the message "msQueryByPoint(): Search returned no
+results. No matching record(s) found" when I query a feature known to
+exists?
+The query feature requires a TEMPLATE object in the CLASS object of
+your LAYER definition. The value points to a html fragment using
+MapServer template syntax.
+Example MapFile fragment:
+.. code-block:: mapfile
+ LAYER
+ NAME "Parcel9"
+ TYPE POLYGON
+ STATUS OFF
+ DATA "Parcels/area09_parcels"
+ CLASS
+ STYLE
+ OUTLINECOLOR 128 128 128
+ COLOR 153 205 255
+ END
+ TEMPLATE "templates/Parcels/area09_parcels.html"
+ END
+ HEADER "templates/Parcels/area09_parcels_header.html"
+ FOOTER "templates/Parcels/area09_parcels_footer.html"
+ END
+Example Template:
+ <tr>
+ <td>[lrn]</td>
+ <td>[PIN]</td>
+ </tr>
+The [lrn] is a special keyword that indicates the resulting line
+number which starts at 1. [PIN] is the name of a feature attribute.
More information about the mapserver-commits
