[mapserver-commits] r8318 - trunk/docs/development
svn at osgeo.org
svn at osgeo.org
Mon Dec 29 13:00:50 EST 2008
Author: jmckenna
Date: 2008-12-29 13:00:50 -0500 (Mon, 29 Dec 2008)
New Revision: 8318
trunk/docs/development/doc_style_guide.txt
add background, installation sections
Modified: trunk/docs/development/doc_style_guide.txt
--- trunk/docs/development/doc_style_guide.txt 2008-12-29 17:52:52 UTC (rev 8317)
+++ trunk/docs/development/doc_style_guide.txt 2008-12-29 18:00:50 UTC (rev 8318)
@@ -4,15 +4,29 @@
:Author: Howard Butler
:Contact: hobu.inc at gmail.com
+:Author: Jeff McKenna
+:Contact: jmckenna at gatewaygeomatics.com
:Revision: $Revision$
:Date: $Date$
-:Last Updated: 2008/11/23
+:Last Updated: 2008/12/29
.. contents:: Table of Contents
:depth: 2
:backlinks: top
+Background
+The current structure of the MapServer documentation process is for
+developers with :ref:`SVN` commit access to maintain their documents
+in reStructuredText format, and therefore all documents live in the
+/docs directory in SVN. The `Sphinx`_ documentation generator is
+used to convert the reStructuredText files to html, and the live
+website is then updated on an hourly basis.
+General Guidelines
* MapServer instead of mapserver, map server, Map Server or map Server.
* MapScript instead of mapscript, Mapscript, or map script.
* PostGIS instead of postgis.
@@ -22,17 +36,61 @@
hobu.inc at gmail.com instead of hobu.inc at gmail.com
+reStructuredText Reference Guides
-ReStructured Text Formatting
+* `Quick reStructuredText`_
-All text should be hard breaks at or around the 80 column mark, just as
-the source code.
+reStructuredText Formatting
-no ``.. sectnum::`` in the contents directives
+* All text should be hard breaks at or around the 80 column mark, just as
+ the source code.
+* No ``.. sectnum::`` in the contents directives
+* All external links should live at the bottom of your document, under
+ the heading:
+ .. #### rST Link Section ####
+* Always include and update the 'Last Updated:' date at the top of your
+ document
+Installing Sphinx for rst-html Generation
+#. install `Python 2.X`_
+#. download `setuptools`_
+#. For Windows users: make sure that the 'C:\Python2X\Scripts'
+ directory is your path
+#. execute the following at commandline:
+ easy_install Sphinx
+ ...you should see message: "Finished processing dependencies for Sphinx"
+#. inside the /docs directory, create \build\doctrees and \build\html
+ directories
+#. inside the /docs directory, execute:
+ sphinx-build -b html -d build\doctrees . build\html
+ ...you should see a message: "build succeeded, ..."
Reference Labels
.. include:: ../include/labels.inc
+.. #### rST Link Section ####
+.. _`Sphinx`: http://sphinx.pocoo.org/index.html
+.. _`Quick reStructuredText`: http://docutils.sourceforge.net/docs/user/rst/quickref.html
+.. _`setuptools`: http://pypi.python.org/pypi/setuptools#windows
+.. _`Python 2.X`: http://www.python.org/
More information about the mapserver-commits
