[mapserver-commits] r8320 - trunk/docs/development
Mon Dec 29 13:29:39 EST 2008
Author: hobu
Date: 2008-12-29 13:29:39 -0500 (Mon, 29 Dec 2008)
New Revision: 8320
Added:
   trunk/docs/development/documentation.txt
Removed:
   trunk/docs/development/doc_style_guide.txt
   trunk/docs/development/index.txt
rename
Deleted: trunk/docs/development/doc_style_guide.txt
--- trunk/docs/development/doc_style_guide.txt	2008-12-29 18:28:28 UTC (rev 8319)
+++ trunk/docs/development/doc_style_guide.txt	2008-12-29 18:29:39 UTC (rev 8320)
@@ -1,119 +0,0 @@
- Documentation Style Guide
-:Author:  Howard Butler
-:Contact: hobu.inc at gmail.com
-:Author:  Jeff McKenna
-:Contact: jmckenna at gatewaygeomatics.com
-:Revision: $Revision$
-:Date: $Date$
-:Last Updated: 2008/12/29
-.. contents:: Table of Contents
-    :depth: 2
-    :backlinks: top
-Background
-The current structure of the MapServer documentation process is for
-developers with :ref:`SVN` commit access to maintain their documents
-in reStructuredText format, and therefore all documents live in the
-/docs directory in SVN.  The `Sphinx`_ documentation generator is
-used to convert the reStructuredText files to html, and the live
-website is then updated on an hourly basis.
-General Guidelines
-* MapServer instead of mapserver, map server, Map Server or map Server.
-* MapScript instead of mapscript, Mapscript, or map script.
-* PostGIS instead of postgis.
-* HowTo instead of howto or HOWTO.
-* Email addresses should be manually spam protected:
-      hobu.inc at gmail.com instead of hobu.inc at gmail.com
-reStructuredText Reference Guides
-* `Quick reStructuredText`_
-reStructuredText Formatting
-* All text should be hard breaks at or around the 80 column mark, just as
-  the source code.
-* No ``.. sectnum::`` in the contents directives
-* All external links should live at the bottom of your document, under
-  the heading:
-      .. #### rST Link Section ####
-* Always include and update the 'Last Updated:' date at the top of your
-  document
-Installing Sphinx for rst-html Generation
-#. install `Python 2.X`_
-#. download `setuptools`_
-#. For Windows users: make sure that the 'C:\Python2X\Scripts'
-   directory is your path
-#. execute the following at commandline:
-       easy_install Sphinx
-   ...you should see message: "Finished processing dependencies for Sphinx"
-#. inside the /docs directory, create \build\doctrees and \build\html
-   directories
-#. inside the /docs directory, execute:
-       sphinx-build -b html -d build\doctrees . build\html
-   ...you should see a message: "build succeeded, ..."
-Alternatively, if you are on *nix, you can issue
-    make html
-or
-    make latex
-to build the documentation using `make`.
-Reference Labels
-.. include:: ../include/labels.inc
-Regenerating the reference labels
-You can regenerate the reference labels by issuing:
-    make labels
-from the docs directory like when you are building the html or latex versions
-.. #### rST Link Section ####
-.. _`Sphinx`: http://sphinx.pocoo.org/index.html
-.. _`Quick reStructuredText`: http://docutils.sourceforge.net/docs/user/rst/quickref.html
-.. _`setuptools`: http://pypi.python.org/pypi/setuptools#windows
-.. _`Python 2.X`: http://www.python.org/
Copied: trunk/docs/development/documentation.txt (from rev 8319, trunk/docs/development/doc_style_guide.txt)
--- trunk/docs/development/documentation.txt	                        (rev 0)
+++ trunk/docs/development/documentation.txt	2008-12-29 18:29:39 UTC (rev 8320)
@@ -0,0 +1,121 @@
+.. _documentation_development:
+ Documentation Development Guide
+:Author:  Howard Butler
+:Contact: hobu.inc at gmail.com
+:Author:  Jeff McKenna
+:Contact: jmckenna at gatewaygeomatics.com
+:Revision: $Revision$
+:Date: $Date$
+:Last Updated: 2008/12/29
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+Background
+The current structure of the MapServer documentation process is for
+developers with :ref:`SVN` commit access to maintain their documents
+in reStructuredText format, and therefore all documents live in the
+/docs directory in SVN.  The `Sphinx`_ documentation generator is
+used to convert the reStructuredText files to html, and the live
+website is then updated on an hourly basis.
+General Guidelines
+* MapServer instead of mapserver, map server, Map Server or map Server.
+* MapScript instead of mapscript, Mapscript, or map script.
+* PostGIS instead of postgis.
+* HowTo instead of howto or HOWTO.
+* Email addresses should be manually spam protected:
+      hobu.inc at gmail.com instead of hobu.inc at gmail.com
+reStructuredText Reference Guides
+* `Quick reStructuredText`_
+reStructuredText Formatting
+* All text should be hard breaks at or around the 80 column mark, just as
+  the source code.
+* No ``.. sectnum::`` in the contents directives
+* All external links should live at the bottom of your document, under
+  the heading:
+      .. #### rST Link Section ####
+* Always include and update the 'Last Updated:' date at the top of your
+  document
+Installing Sphinx for rst-html Generation
+#. install `Python 2.X`_
+#. download `setuptools`_
+#. For Windows users: make sure that the 'C:\Python2X\Scripts'
+   directory is your path
+#. execute the following at commandline:
+       easy_install Sphinx
+   ...you should see message: "Finished processing dependencies for Sphinx"
+#. inside the /docs directory, create \build\doctrees and \build\html
+   directories
+#. inside the /docs directory, execute:
+       sphinx-build -b html -d build\doctrees . build\html
+   ...you should see a message: "build succeeded, ..."
+Alternatively, if you are on *nix, you can issue
+    make html
+or
+    make latex
+to build the documentation using `make`.
+Reference Labels
+.. include:: ../include/labels.inc
+Regenerating the reference labels
+You can regenerate the reference labels by issuing:
+    make labels
+from the docs directory like when you are building the html or latex versions
+.. #### rST Link Section ####
+.. _`Sphinx`: http://sphinx.pocoo.org/index.html
+.. _`Quick reStructuredText`: http://docutils.sourceforge.net/docs/user/rst/quickref.html
+.. _`setuptools`: http://pypi.python.org/pypi/setuptools#windows
+.. _`Python 2.X`: http://www.python.org/
Modified: trunk/docs/development/index.txt
--- trunk/docs/development/index.txt	2008-12-29 18:28:28 UTC (rev 8319)
+++ trunk/docs/development/index.txt	2008-12-29 18:29:39 UTC (rev 8320)
@@ -11,7 +11,7 @@
    sponsors
    bugs
    svn
-   doc_style_guide
+   documentation
    tests/index
    rfc/index
    editing/index
