[mapserver-commits] r8342 - trunk/docs/development
Tue Dec 30 08:46:06 EST 2008
Author: jmckenna
Date: 2008-12-30 08:46:06 -0500 (Tue, 30 Dec 2008)
New Revision: 8342
   trunk/docs/development/documentation.txt
specify which docs directory
Modified: trunk/docs/development/documentation.txt
--- trunk/docs/development/documentation.txt	2008-12-30 13:29:05 UTC (rev 8341)
+++ trunk/docs/development/documentation.txt	2008-12-30 13:46:06 UTC (rev 8342)
@@ -10,7 +10,7 @@
 :Contact: jmckenna at gatewaygeomatics.com
 :Revision: $Revision$
 :Date: $Date$
-:Last Updated: 2008/12/29
+:Last Updated: 2008/12/30
 .. contents:: Table of Contents
     :depth: 2
@@ -74,7 +74,7 @@
        easy_install Sphinx
    ...you should see message: "Finished processing dependencies for Sphinx"
-#. inside the /docs directory, create \build\doctrees and \build\html
+#. inside the MapServer /docs directory, create \build\doctrees and \build\html
    directories
 #. inside the /docs directory, execute:
