[mapserver-commits] r8361 - trunk/docs/installation
svn at osgeo.org
svn at osgeo.org
Wed Dec 31 09:54:28 EST 2008
Author: tomkralidis
Date: 2008-12-31 09:54:28 -0500 (Wed, 31 Dec 2008)
New Revision: 8361
trunk/docs/installation/php.txt
point to internal refs instead of old site
Modified: trunk/docs/installation/php.txt
--- trunk/docs/installation/php.txt 2008-12-31 14:51:15 UTC (rev 8360)
+++ trunk/docs/installation/php.txt 2008-12-31 14:54:28 UTC (rev 8361)
@@ -62,7 +62,7 @@
- The old `MapServer Wiki`_ also has PHP/MapScript build and installation notes
and some php code snippets.
-- Questions regarding the module should be forwarded to the `MapServer mailing list`_.
+- Questions regarding the module should be forwarded to the :ref:`MapServer mailing list <lists>`.
Obtaining, Compiling, and Installing PHP and the PHP/MapScript Module
@@ -76,7 +76,7 @@
- The PHP source or the Win32 binaries can be obtained from the `PHP web site`_.
- Once you have verified that PHP is installed and is running, you need to get
- the latest `MapServer source`_ and compile MapServer and the PHP module.
+ the latest :ref:`MapServer source <download>` and compile MapServer and the PHP module.
Setting Up PHP on Your Server
@@ -451,7 +451,6 @@
.. _`MapServer Wiki`: http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScript
.. _`MapServer mailing list`: http://mapserver.gis.umn.edu/community/mailinglists/
.. _`PHP web site`: http://www.php.net/
-.. _`MapServer source`: http://mapserver.gis.umn.edu/download
.. _`Installation on Unix systems`: http://php.net/manual/en/install.unix.php
.. _`MS4W (MapServer For Windows)`: http://www.maptools.org/ms4w/
.. _`Installing Apache, PHP and MySQL on Windows tutorial`: http://www.php-mysql-tutorial.com/install-apache-php-mysql.php
More information about the mapserver-commits
